Question about Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M
The filter in the gas tank came off.
The product is a weedeater featherlite blower. The filter inside the tank is disconnected. There are two fuel lines ine tank. One is smaller than the other. My probem is that I don't know how the two lines and the filter go back togher. The larger fuel line has a fitting attached to it. I can pull the two lines through the fuel inlet. However, I don't understand how to attach the lines and the filter inside the tank. Any advice would be greatly appreciated. Thank you,.
  • Anonymous Mar 27, 2014
    Larger vent line filter in tank
    President:
  • 1,776 Answers
The filter should only fit in the end of one of the lines (probably the larger diameter one) The smaller line usually goes from the tank to the primer bulb and the larger one goes to the carburator. The filter just sticks in the end of the fuel line.
Posted on Jul 08, 2009
Tip
Easy way to install fuel line and primer bulb return line into gas tank
Chainsaw fuel lines enter the gas tank from holes in top of tank. They are sized for a tight fit to prevent leakage. Make it easy on yourself when pushing the line through the tank by cutting a long lengthwise taper cut with razor knife 3 inches or longer to easily feed through that tight hole. Once started you will then have to grab it through the gas cap hole with needle nose pliers, then cut the tapered end flush and add fuel filter. Readjust inside length by pulling from above, then cut to length to upper carb fitting. If connecting to primer bulb a filter is not required and make sure the line goes to fitting on primer bulb marked tank.
on Nov 17, 2015 | Fuel Line & Primer Bulb Repair Kits 2...
What would be wrong with my weedeater when i press the primer bulb gas will start to come out of the gas cap ?
You could have a clogged tube from the primer into the carb, but it also sounds like the fuel tank is overfilled.
Jul 14, 2014 | Fuel Line & Primer Bulb Repair Kits 2...
I have a weedeater model Featherlite 711334 and the gas lines crumbled to nothing. Not sure how the set up was inside the gas tank as to which line goes where and hooked up to what inside the tank.
There are two lines from the tank to the carburator. One picks up gas and fills the prime bulb, the other is a return line. The pickup line should have a filter on the end of it that is in the tank. The other line just dumps back in the tank. Usually the reason these lines deteriorate is because of ethanol in the gas. Make sure you're using ethanol free gas.
Sep 30, 2010 | Weedeater Gas Powered Hedgetrimmer...
Gas does not seem to be getting to the carburetor
Check the fuel lines going to the carburetor from the tank to make sure none of lines have decomposed or gotten soft also check the fuel filter inside the tank to make sure gas can get through...if the lines or filter are bad... replace them...bulk fuel line and filters available at any mower shop or mower parts house....a fairly easy job !!! hope this helps... ;-D
Aug 11, 2010 | Weedeater Gas Blower
Gas problem
Check gas cap to make sure breather holes aren't plugged. Check screen inside tank where shut-off valve is to make sure it isn't clogged.
Apr 18, 2010 | Poulan Featherlite Gas Blower, with Low...
I am needing a repair kit for gas tank on the weedeater featherlite 1500 where do I get repair parts at?
I have a Weedeater Featherlite SST and need to replace the fuel lines but do not know where they go is there a diagram that will show me this?
Nov 11, 2009 | Poulan Featherlite Gas Blower, with Low...
I have a featherlite that will not run
Does it have a primer bulb? If so, check it for cracks, also check the fuel lines and the uptake filter in the fuel tank which may be clogged, check all the seals of the carb inder a magnifier to check for dirt or cracks...this is going to sound stupid but are you sure you put the carb back together correctly?
Sep 07, 2009 | Garden
On weedeater blower and vac gas line is broke from carb into tank does it just connect to fuel filter in tank model 1925
Yes if your asking about the fuel line yes it hooks to the filter out thru the wall of the gas tank straight into the carb. if it broke out side the tank you can try a smaller plastic hose to stick inside to reconnect the two parts. if it broke inside the tank try to replace as one hose.
Jul 12, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
I am trying to repair the fuel intake on a featherlite weed eater
replaced fuel lines on sear weedeater and primer button still acts like it is suching against a vacume. push it in and it won`t release. this unit in same as my featherlite carb and tank. What do I look for line are not restricted, but car not drawing fuel?????
Jul 08, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M Logo
467 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
