Question about Kodak EASYSHARE V1253 Digital Camera
Easy share V1253...will not stay on...lens will not telescope
Battery is good.....?
  • 3 Answers
I have had the same issue were the lens would not retract. took it in for extended warranty work. lens now retracts but takes lousy pictures.
When I purchased this camera family members ran out and bought thiers shortly after I did. One by one the same issue has happend to their v1253's.
I dissmantled one and found that there is a tiny battery on the power board inside of the camera. apparently the tiny battery's life is about 1 1/2 years. This battery is not serviceable as it is welded in place. I am not one hundred percent sure if this is the cause but it makes sense.
It would be nice if kodak would own up to this issue and make good on repairs as they did with my kodak 5500 all-in-one printer and it's crappy print head. Kodak has sent me 4 print heads in the 2 years I have owned it.
I have 5 of the v1253's in my family and every one of the are dead. I would think a $250 product should last longer than 1 1/2 years.
Hope this helps you out.
Posted on Dec 01, 2009
My problem is that the lens stays open, all the lights flash, I hear a very low set of tones and then it shuts off. I recharged the batter and tried all the fixes except taking it apart
Sounds like a stuck lens. Happens to V1253 / V1233 often. These lens can't stand dust, dirt or sand. The lens has to be taken apart and cleaned. It's not very easy, also it involves some soldering. I suggest you give it to a local repair shop (if you think it's worth it). I could offer you a repair, but I'm in Germany.
I have worked at a Kodak service center as a technician.
Tom
Mar 04, 2011 | Kodak EASYSHARE V1253 Digital Camera
Can i use my kodak easy share v1253 as web cam
No. The V1253 is designed to store images and videos to memory, not to stream live video to another device.
Oct 23, 2010 | Kodak EASYSHARE V1253 Digital Camera
Lens won't retract. Camera powers off immediately after powering on without retracting lens. New battery didn't help.
Are you using the recommnded battery KODAK Li-Ion Rechargeable Digital Camera Battery KLIC-7004
first you need to do make sure the battery is fully charged., now if you if this solution will not resolve the issue it means that the Gear Lens is defective thats why your Lens will not retract and camera will not stay On. you need to call kodak to send your camera for repair call toll free 1 800 235 6325., Gudluck!
Oct 31, 2009 | Kodak EASYSHARE V1253 Digital Camera
THE LENS COMES OUT BUT GOES RIGHT BACK IN AND
I had the same problem. All I did was hold the lens out when it tun so that when it shuts off, the lens is still out. Then I moved it around a bit. Something was stuck in the lens and when I moved the lens around, it came out. So now it functions normally :] I hope I helped!
Jul 07, 2009 | Kodak EASYSHARE M1063 Digital Camera
I have a digital camera kodak easyshare V1253 and when i turn on, the lens go out ,but inmediately the camera turn off and the lens go in back ,I check the batery in a especial store and is in a good...
Remove the batteries and clean the battery contacts inside the camera with a soft cloth (a heavy buildup on the contacts may require cleaning with a fine wire brush, steel wool, or sandpaper). Remove any residue that the cleaning leaves in the camera, and then reinstall the batteries. This clears most power-on problems, but if yours persists, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Mar 13, 2009 | Kodak EASYSHARE V1253 Digital Camera
V1253 Kodak Lens stuck open, will not power on
hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.
Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u rate me!!!
Feb 12, 2009 | Kodak EASYSHARE V1253 Digital Camera
Lens jammed on a kodak v1253
I fixed my v1253 following these steps:
1. Pulled the battery when the lens starts to come out before it could power itself off.
2. Gently pull the telescope out until it clicks.
3. Use a fine tip paint brush to clear debris out of the cracks.
Camera works just fine now.
Jan 30, 2009 | Kodak EASYSHARE V1253 Digital Camera
Hi kodak v1253
I have the same problem, but it only started after I went to the beach and dropped the camera in the sand, it landed on its edge and did not go into the sand deep. I checked it thouroghly and did not see sand grains in the ports etc. I blew it off with compressed air lightly and checked again for sand. It looked clean to me. Then it started. It opened and then closed and I couldn't do anything to fix it. This is my second camera. The first one didn't open right either from the box, but I grabbed the lens as it opened and pulled it a bit until it popped and then it worked.
I fixed the problem on this camera.. so far. I turned it on and let the lens open. I figured the computer was getting, or not getting, a signal to keep it open. At the very base of the telescope lense i turned it a bit more in the direction it was already turning as it tried to open. I noticed that it stopped just short and as i applied a bit of pressure it moved another few milimeters...and whalahh, it stayed open and the camera worked. I turned it off and on and did not touch it, and then it closed again!! So I turned it back on and "forced" it a bit at the lowest telescope base again to make sure it was rotating fully and it moved again a few mm's... and then stayed on. Then I looked really really close at the rim around the lens and did see some "junk" I took a very thin, flat piece of metal, some kind of binder clip my wife had on the computer desk. It was very, very thin and I used it to "clear" around the channel of the telescoping lens and then blew it out again with air. Now the camera works without the little "twist" I had to give it to help it open. Maybe the camera has some sort of sensor that if the lense is not all the way engaged open, it shuts back down. Anyway, it worked for me.
Feb 11, 2008 | Cameras
Kodak EASYSHARE V1253 Digital Camera Logo
291 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
