Question about Dell Computers & Internet
Dell Dimension E521 ''Diskette Drive 0 seek failure''
An over anxious teen decided to help with the pc... Hard drive was reformated. I installed recovery cd's, sp3, all updates. It runs like normal. Except that, when you turn the pc on, it displays this error. It then gives you the option to F1-continue or F2-setup. You hit F1 it boots up and runs great. If you hit F2, it takes you to setup, but to make changes you need admin password, which I do not have. Any ideas?
  • 558 Answers
Is there a diskette drive installed?The bios is looking for a device that was enable but not there.If you prefer to ignore this problem you may do so,however the fix is very simple,unplug the computer remove the cover,there is a coin battery which stores the configuration of the computer you may need to remove it.This will erase the configuration stored in the bios,or you can install a jumper on the motherboard which will clear the bios setting .Remember to return the jumper on the pins it was on.
good luck
Posted on Sep 14, 2009
My dell c521 says diskette drive 0 seek failure
You need to press f2 then go to Standard CMOS Features, then highlight drive A. Change it to none. You should not have anything in there enless you have floppy drive
Jan 14, 2014 | Dell Dimension C521 PC Desktop
Floppy diskette seek failure
The floppy disk or drive is damaged, or if your trying to boot your computer and you have a floppy in the drive that is not bootable. It will try and boot from floppy first then cd then hard drive usually but floppy's are stupid and only return an error and then stops. Remove the floppy disk and boot
Dec 06, 2013 | Dell Dimension 5100 (D51L1) PC Desktop
DISKETTE DRIVE 0 SEEK FAILURE
Make sure everything is hooked up correctly did you install the disc that came with this first. If not undo the device and install the software that came with it. Also you can disconnect the device completely, then power the computer completely down. Push the power button 1-2 seconds. You will not see the device because it is unhooked, by doing this you can start fresh and re-install the device again with power completely off, then restart computer again check in the device manager to see if it loaded this time. John
Apr 19, 2012 | Dell Dimension E521 AMD Athlon 64 X2...
No boot device available stike f1 to retry boot and f2 for setup utility diskette drive 0 seek failure a dell dimension 2400 series
Your computer cannot find a boot-able storage device, i.e. hard disk drive, to boot from. Either your hard disk drive is defective or the OS (operating system software) is corrupted and needs to be re-installed.
Jul 27, 2011 | Dell Dimension 2400 PC Desktop
Boot up screen says "diskette drive 0 seek failure"
Press F2 look through the menus and remove / disable 3.5 floppy drives.
Jan 06, 2010 | Dell Dimension 8400 PC Desktop
Diskette drive 0 seeks failure;password
Open the case and reset the BIOS using the jumper: move it from 1-2 pins to 2-3 for 5 minutes.
Jan 02, 2010 | Dell Dimension 2400 PC Desktop
Dell dimension 2400 diskette drive 0 seek failure
Check your BIOS setting to see if it detects the hard drive (Primary disk 0). If it can't detect the hard drive then the hard drive maybe faulty. Open the case unpluge the IDE cable from the hard drive and reconnect it again, also unplug the IDE cable at the motherboard and reconnect it again including the power connector on the hard drive.
There maybe an option to test the hard drive in the BIOS, if so use it to test the hard drive.
If the hard drive is faulty, you need to replace it and install Windows, the various device drivers and your programs to get a functioning computer again.
You might consider buying a new computer (it will be faster & better than the old Dell) and you have your new monitor to go with it.
May 21, 2009 | Dell Dimension 2400 PC Desktop
Boot into setup by pressing F2 or F10 depending on your bios and disable the floppy drive setting.
Jan 14, 2009 | Computers & Internet
Diskette driv 0 seek failure
press f2 go to the boot priority and select harddrive to the first boot.
Nov 22, 2008 | Dell Dimension C521 PC Desktop
My pc go to diskette drive 0 seek failure
U'r hard drive is not communicating with the system. Open the pc (power off) and check the cable connections. While U'r there, clean with blow or vac. U'r HD may have died. The data may still be there and got to with a new hd.
May 23, 2008 | Dell Computers & Internet
Computers & Internet Logo
1,721 people viewed this question
Alun Cox
