I'm new here, so I hope I'm not being redundant, as I've posted this problem a min.ago. Sharp XM-2710 "Professional Series" (it says on the front of the set)suddenly got wierd tint problem, trying to adjust it under menu section does nothing. Looks REALLY toooo brite, reds and greens.
  • 1,056 Answers
Look in the back of the printer that is where the model number is. That is not the model number. I will try to help you.
Posted on Jul 01, 2009
Is the Hannspree XM M19W1 a HD moniter
This is the specs of this monitor.
HANNspree XM Boston M19W1 19"
1440 x 900, 700:1, 5 ms, VGA, DVI, Audio
Apr 16, 2013 | Hannspree 19" Widescreen LCD Flat Panel...
Delphi roady2 SA10085 XM Radio Receiver with Car Kit
Sounds like its the dock itself. Have you tried using the home dock with the vehicle power or visa versa? This should help you confirm what the problem is. You can get a replacement power adapter here:
http://www.tss-radio.com/products/xm-car-power-adapter-for-6-volt-receivers
A cradle may be difficult to find, but TSS Radio can help you look.
Jun 05, 2012 | Delphi Roady2 SA10085 XM Radio Receiver...
IS there an online .pdf copy of the manual available?
Yes, you can download it here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 23, 2011 | Delta Machinery Delta 37-275X X SERIES 6"...
We have a sharp R-967 combination microwave/conventional oven. It now switches itself off after 59 seconds of operation regardless of which time and/or which function has been selected. Can this be easiliy...
I see its some time ago now that you posted this and perhaps you've fixed your micro already or replaced with a new one. I have the same Sharp r-967 microwave which had the same 59 second problem. I researched a bit online found the sevice manuals and tracked the problem down to be the damper motor. I managed to buy one online and replace it quite easily. There are some diagrams online when searching for this problem but for different sharp models where the damper is near the door fixings. Its not the case on r967, its behind the circuit board and easy to remove with a stubby screwdriver. You can find spares from this place. 5 minute job. The 59 second thing is likely to be the either the door switches or the damper motor. Switches are between £5-10. All mine were fine so didnt have to replace any. A quick voltmeter test can check them.
http://www.sharp-parts.co.uk/shopexd.asp?id=76
I paid £26 in delivery. Hope it helps if not too late!
cheers
Jan 04, 2011 | Sharp R-1850A Convection/Microwave Oven
I have a 1999 Honda Accord with a CD radio with no extenal speaker connection. I have a new XM radio and want to connect the radio to the speaker system. How do I find the place to acces the cars...
Hello! Pull the radio...There is a connector with the following speaker wire colors...
Front driver door + Red/Green
Front driver door - Brown/Black
Front pass. door +Blue/Green
Front pass. door -Gray/Black
Left rear+ Blue/Yellow
Left rear - Gray/White
Right rear + Red/Yellow
Right rear - Brown/White
If the vehicle is an EX the left and right Tweeter's are the same as the Front drivers/Passenger door speakers and merely connect to them...
Guru...saailer
Dec 25, 2010 | 1999 Honda Accord
Front panel display dim, can't see the
I see this post has been here for quite some time. Sorry you haven't had an answer yet, while I can't say why, If you still are inquiring, the problem lies in the control and harness assembly. In my professional experience with almost all thermador of this era it's sometimes a bad solder on the control pin connector from the display,(which can be fixed by a proficient soldering person or conversely destroyed by a poor one) a bad transformer integrated onto said control, or other times just a bad harness, you'll likely need a control in any event. When you purchase a control ( # 1051714 for 302-double or 1051712 for 301 single oven models, and around $200US check your local parts depot or service center.) they should have new harness enclosed in the packaging of the control.
I just joined here less than a month ago, so I'm starting to see alot of post's I haven't seen before (there are many) and likely some may never get answered directly, but alot are the same if you search out similarities.
hope this helps.
**I should add this could be a job for a professional tech, who depending on how proficient they are or how the environment is set up, could handle this in 30-45 min or so. It is quite straight forward for one experienced with servicing thermador units. I would suggest you insist on an authorized b/s/h tech, they tend to have more of the update info if any or reworks etc.**
The above (re: hiring a tech) is just my opinion based on my professional experience and there may be opposing opinions, in the end you are the authority.
hope I've been helpful to you,
Good Luck
Jun 29, 2009 | Thermador C302U Electric Double Oven
Fan flow error 1611 I/O
The ProLiant DL380 G3 server requires that both primary and redundant fans exist in a specific configuration in order to perform optimally. Any deviation from the specified configuration will cause one of the above error messages to occur and the internal Health LED to illuminate. In a ProLiant DL380 G3 server without the redundant fan option, the server will shut down after the error message is displayed. In a server with the redundant fan option, the internal Health LED will illuminate and the appropriate error message regarding fan redundancy will be displayed. The purpose of this document is to detail the required configuration for both primary and redundant fans.
DETAILS Both primary and redundant fans in the ProLiant DL380 G3 server must be configured to meet specific requirements in order to avoid the error messages above and in some instances, subsequent shutdown of the server.
All primary fan locations (2, 4, 5, 6 and 7) must be populated with a fan before the redundant fan locations (1, 3, or 8) are populated. If a primary fan location is left unpopulated, the server will display one or more of the error messages shown above. In addition, the internal Health LED (the top LED on the front panel of the server) will display the status of the fans.
When the redundant fan option is used, all redundant fan locations must be populated. ProLiant servers do not support partial population of redundant fans. If any redundant fan location is populated without also populating all other redundant fan locations in the server, the fan system will not be fully redundant and one or more of the error messages above will be displayed.
Figure 1 below illustrates a ProLiant DL380 G3 server configured with all eight fans installed for fan redundancy. The server airflow is divided into three zones: processor, I/O and power supply. Shared fans 4 and 7 each provide airflow for two zones. If a shared fan fails, the failure is experienced in both zones.
Figure 1: ProLiant DL380 G3 server configured with all eight fans installed for fan redundancy
The internal Health LED (the top LED on the front panel of the server) indicates failed or missing components. The internal Health LED should be observed to determine the status of the fans as follows:
RED LED: A red LED indicates that the minimum fan requirements have not been met. Minimum fan requirements indicate that all primary fan slots must be populated with functioning fans.
  • If the 1611 fan "x" is not present (where "x" is the fan location) error message is displayed at POST and the internal Health LED is red , then a primary fan is missing.
  • If the 1611 fan "x" failure (where "x" is the fan location) error message is displayed at POST and the internal Health LED is red , then a primary fan has failed.
AMBER LED: An amber LED indicates that the minimum fan requirements have been met; however, requirements for redundant fan configuration have not been met. This means that all primary fan slots are populated with functioning fans, but at least one redundant fan has either failed or is missing.
  • If the 1611 fan "x" is not present (where "x" is the fan location) error message is displayed at POST and the internal Health LED is amber , then a redundant fan is missing.
  • If the 1611 fan "x" failure (where "x" is the fan location) error message is displayed at POST and the internal Health LED is amber , then a redundant fan has failed.
Note: In a redundant fan configuration, the error message fan system not fully redundant will also be displayed at POST if any redundant fan slot is left unpopulated or if a redundant fan has failed.
Nov 21, 2008 | HP Compaq ProLiant DL580 G4 (430811001)...
F o8 in my washing machines
heater relay stuck check pressure switch, heater and module connections poss pressure switch fault
Jan 17, 2008 | Hotpoint Ultima WF860 Front Load Washer
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
