Question about HP ScanJet 4200Cxi Flatbed Scanner
Scanjet 4200c Software and Windows XP SP2
For some reason when I download and run the H P software update for XP the software runs really slowly and crashes my computer. I have goofled extensively and tried a number of different approaches - all without success. Any suggestions?
  • 2,985 Answers
Check out the 'Compatibility mode in the Help section of My computer.
Reset the computer to run the software as for Win98.
However if this is a Win 98 scanner then difficulties must be expected.
Scanners nde for Win95/98/Me expect to receive instruction from computer in DOS.
XP is NTFS and many scanners simply do not work with NTFS- not withstand makers having kludges of drivers to download - in general they did not work.
Posted on Nov 08, 2007
Error bigpipe win xp professional sp2
This is due to a security flaw in SP2. You will need to download SP3 update from Microsoft!
IF you go to Microsoft XP SP3 Manual Update, follow this link and download the update then run it. This will correct the issue.
I also suggest that turn on automatic updates. Although XP is no longer supported by Microsoft you will still get all the old updates.
Oct 16, 2013 | Microsoft Windows XP Pro W/MUI SP2...
Installing scanjet 4200c to windows 7
no updating driver for this scanner it can only be use in win xp bot if u can only manage it with win vista bot it cant work with win7
Jun 22, 2011 | HP Scanjet 4200c Flatbed Scanner
I cannot download HP 4200c wto my computer with the update xp disk. please help
hi bryant8362 !
You can download your driver from here :
Please note : nomore driver available beyond Win XP !
Best regards ,
fanaudi .
Feb 23, 2011 | HP Scanjet 4200c Flatbed Scanner
Hi, I have HP ProBook with a ScanJet 4200C which I can't find any drivers to.
Please download the driver from below link.
for more assistance stay connected with us.
Thanks for joining us. Have a nice day.
Jan 14, 2011 | HP Scanjet 4200c Flatbed Scanner
It says that itunes requires that your computer is running xp sp2 or newer what can i do?
Update your PC/laptop using the Microsoft Update.
You can check the requirement in installing Microsoft XP Service Packs to your system @
Aug 09, 2010 | Computers & Internet
How to installation windows xp in hindi lenguage with picture
  1. Step 1 Open Windows Update (located in the Windows XP Control Panel), and see if SP2 is on the list of available updates. If you don't have Windows Update installed or turned on, visit the Windows Update website in order to get the latest Windows Update software.
  2. Step 2 Select the Windows XP SP2 item from the list of available updates, and click the "Install" button. Windows Update will begin downloading Service Pack 2 (a process that may take up to 20 minutes or longer, depending on how fast your Internet connectionmag-glass_10x10.gif is), and will then launch the installation program once downloading is complete.
  3. Step 3 Follow the on-screen prompts to complete the Windows XP Service Pack 2 installation. You will be asked to accept the terms of the licensing agreement before the actual installation takes place. Installation may take up to 20 or 30 minutes, after which you will be required to reboot your computer in order for the changes to the operating system to take effect.
  4. Step 4 Should you have problems installing XP Service Pack 2 through Windows Update, download the stand-alone executable from Microsoft in order to install the software update manually. The Service Pack executable is designed to make it easier for IT professionals to update multiple computers without having to download the Service Pack onto each one. Run the installer program once you've finished downloading it, and follow the on-screen instructions as mentioned above.
May 30, 2010 | Microsoft Windows XP Professional SP2
Can I get the hp 4200c flatbed scanner to work on a windows 7-64 bit PC?
There doesn't seem to be one:,39043052,50002418r-39502891s,00.htm
HP says they will not even provide a driver update for Vista.
You can try this procedure for VISTA: (This is a download link.)
Mar 02, 2010 | HP Scanjet 4200c Flatbed Scanner
Is Software available for Vista?
According to HP, no. See link.
However, you might be able to install the Windows XP drivers and run the driver in 'Compatibility Mode' for XP SP2.
First, un-install any drivers you have installed for the scanner (if you have tried any).
Second, disconnect the scanner from your computer.
Download the driver and the software update from the provided link (above).
Once you have downloaded the driver (ps804en.exe) right click it, select the Properties/Compatibility Tab and check 'Use Compatibility Mode' and set it for Windows XP SP2, and also check 'Run as Administrator'
Then click ok.
Now run ps804en.exe and do not connect your scanner until the installation is finished (unless it specifically asks you to connect the scanner).
Now right click the updated software (ps803mu.exe),select the Properties/Compatibility Tab and check 'Use CompatibilityMode' and set it for Windows XP SP2, and also check 'Run asAdministrator'
Then click ok.
Now run ps803mu.exe
With any luck this might work.
Sep 25, 2009 | HP Photosmart s20 Film Scanner
Software can not find Scanner
ok connect your scanner in other usb port also check that all usb proper working.
then try to change cable.
may be your xp sp3 virsion not detect your scanner install proper driver for that.
Nov 18, 2008 | HP Scanjet 4200c Flatbed Scanner
Hewlet Packard Scanner on XP
absolutely not, (MS) it could be for many reasons like incompatible drivers, incompatible OS, mind you if you can double check the right OS platform you have downloaded and the right bit as well, (32 or 64), XP or Vista, can you double check pls, these are some reson why it become too slow
you might want to check on uninstalling this again
Jul 28, 2008 | Office Equipment & Supplies
HP ScanJet 4200Cxi Flatbed Scanner Logo
94 people viewed this question
Ben Johnson
