The fan is working but the air conditioner unit is not working
  • 8,220 Answers
Lets take a moment to see what exactly is inside the condenser (that's an outside unit) You have a compressor, a fan, a contactor, a coil, and a capacitor. How does it work? The condenser is connected to the house via an electrical box called a yank out. It is a quick way to kill power to the unit. Note: this is not the breaker to the unit. That would be in the main panel by the meter. People always assume this is the only safety. It is put there by law to kill the power to the unit for service personel. Pull out the connection to kill the power before checking the unit. The first thing to look for is a swolen capacitor the fan is working but the air conditioner unit is - failed%20cap.jpg. If it swells it fails and the unit don't function too well. The next thing to look for is contactor problems. Their are small wires coming from the inside control panel that power up the 24 volt coil that yanks down the contactor. That coil might be bad. If it has no continuity(open) it is in need of replacement. A critter could get between the contacts and fry them as well. Look on the compressor for burnt wires and loose connections (very common). The fan motor should be very easy to turn so if it is stiff then it probably is in need of lubrication. The standard oil in the HVAC world is Zoomoil. It is hi temp resistant, will not lose viscosity and is non flammable. If a weed eater should kill the thermstat wires going outside noting will work because the contactor won't pull down. if the contactor coil is open then it won't pull down and engage the compressor and fan. if a critter crawled under the contacts nothing will happen. of course if the compressor pins are shorted to the copper piping or there is a hole in it or it has an open winding between pins it is shot.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 01, 2009
Pro Standard Fan mount
Since the failure of an air conditioner to turn on, loss of air conditioner cooling capacity, reduced air conditioning output temperatures, loss of cool air supply, or even loss of air flow entirely can be due to a variety of problems with one or more components of an air conditioner or air conditioning system, after reviewing the lost air conditioner cooling diagnosis procedures described in this article, be sure to also review the diagnostic procedures at each of the individual air conditioning diagnosis and repair major topics listed just below. To return to our air conditioning and refrigeration home page go to AIR CONDITIONING & HEAT PUMP SYSTEMS.
Electrical problems on HVAC systems: Keep in mind that despite the depth of technical detail you will find here about all components of air conditioners and heat pumps, most service calls for non-working air conditioners or heat pumps turn up an electrical problem. So if your A/C system is just not working at all be sure to check all of our electrical and control setting suggestions first.
Mechanical problems on HVAC systems: tend to fall into these groups: refrigerant leaks, dirty condenser coil or unit, dirty evaporator or cooling coil, or burned out (or hard-starting) compressor motors. We have also seen a number of problems with fans and fan motors in both the compressor/condenser unit and in the air handler/blower fan unit. Some of those fan problems are mechanical - like a loose fan belt or blade. MORE DETAILS
Nov 13, 2012 | Heating & Cooling
Is the fan on the outside unit supposed to turn when the heat is on or only for the air conditioner? Our unit is omitting a strange odor and the fan will not move even if we switch the unit to air...
The outside fan is used when ever the compresser needs to be cooled. So depending upon the outside temp as well as the temp of the refrigeration, it may not come on. When you say "our unit is ommiting a strange odor" are you refering to the outside condenser? or from the air handler? and what does it smell like? Please give us more to work with to be able to help you. Yes there are people looking and working on problems here at Fixya.com.
Jan 22, 2011 | Ruud UAKA042 Air Conditioner
The fan on my outdoor compresser unit has stopped working the motor is humming and the fan doesn't turn if you manually push the fan blades around the fan will spin but at a very slow speed. The unit was...
It could be either one or both...usually I like to do both at once because either one can cause the other to fail...that problem is a common one for air conditioning units...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 23, 2010 | Bryant 463AAC008BA Air Conditioner
Unit turns on but fan does not work. When we turn unit on, it makes a low "whirring" sound, but no air comes out of unit.
Try turning fan by hand. If it turns easy, replace fan capacitor.
If hard to turn, replace motor.
Jul 11, 2010 | Frigidaire FAH125P2T Air Conditioner
Outside unit kicks on but inside fan sometime works and sometimes won't and i have replaced thermostat to get to work i have to turn the fan to on and back to auto several times and finally the fan inside...
Goodman air handlers (inside unit) fan have a delay timer that turn on the fan ,sometimes up to 3 minutes after the outside unit is on,this makes the a/c more efficiency.
Sep 19, 2009 | Goodman CKL36AR36 Air Conditioner
THE MONITOR OF INDOOR UNIT DISPLY ALL THE
This could be caused by a blown circuit breaker or fuse inside the unit, a damaged compressor or fan motor, faulty wires connecting the compressor or fans to the control board unit, a faulty or hung relay on the control board (this can sometimes be solved by tapping the relay with a screwdriver), or the starter capacitor for the compressor or fan motor.
Sep 17, 2009 | Samsung AQ24 Air Conditioner
Danby DAC5020 Air Conditioner fan works but not compressor
It could be as simple as being low on refrigerant. Depends on how expensive the unit is if its worth recharging and how big the unit is. Some small units will need to have a recharge point fitted which cost more of course.
Jul 02, 2009 | Danby DAC5020 Air Conditioner
Fan doesn't work
(BACK TRACK FROM THE FAN VOLTAGES BACK........)
May 25, 2008 | Goodman PHKJ048-1 Air Conditioner
Air Conditioner unit won't switch on outdoors
can you give us some model numbers and a make? Get both the inside and outdoor unit numbers please. Thanks.
Oct 10, 2007 | GE AJCH10ACB Built-In Room Air Cool Unit
Heating & Cooling Logo
126 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
