Question about Westinghouse L1975NW Monitor
L1975NW Monitor will eventually light up a boot up
This is my daughter's monitor. She has it connected to a Mac mini. It has worked fine for around 2 years. It now takes up to 15 minutes to display a picture after the computer boots up. I have it now hooked to an old powerbook and have found that if I unplug the monitor from the wall socket (after the computer boots up), and then wait 30 seconds and plug it back in, the monitor light changes to green and the display comes on. If I do a restart on the computer the monitor comes back on like it should. It is only when the monitor sits for a long period of time that the problem occurs.
I did do a reset from the computer's menu, but it still has the same problem. I have switched out VGA cables and the DVI / VGA adapter with no change. She is now using another monitor from a friend and it works fine, so don't think the computer is at fault.
  • 1,869 Answers
Your cold cathodes (tiny fluoresent lamps) and, the inverter (ballast) board in the monitor's screen; need to be replaced
Posted on Jul 01, 2009
Acer s211hl picture unstable
Can you try a different monitor? A friend's?
Or connect the monitor to another computer?
If this Maverick then you may need an updated driver.
Apr 02, 2014 | Acer S211HL Monitor
Mac Mini - Signal is not compatible with this intput
Can you change the signal format in the display settiings? 1080p is the native one on your monitor, try difrent ones if availabe. also test difrent resolutions.
Jul 06, 2008 | Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD...
When i plug up the L1975NW lcd monitor what should show up ?
"no input" means that there is no signal from computer or the monitor cable is unplugged. When you first turn on monitor it usually does a self test and then looks for signal. Not connected to PC will give a no signal. If it is connected but PC is off (not unplugged) then it should go into standby as you vid card will be sending a standby signal to any monitor connected. Sometimes the Plug and Play monitors need to register before it will recognize a standby signal from PC, so plug it up and boot up PC. Then shutdown normally, your monitor should go into standby when the PC shuts down.
Nov 11, 2013 | Westinghouse L1975NW Monitor
The monitor is black with a error message :input signal out of range We are connected to a Mac Mini This problem seemed to happen after the monitor was accidently disconnected and then when it was...
Can you please get me the make and model of the monitor? Also did you check to see if the refresh rate of the monitor matches with that of the mac mini?
Nov 21, 2010 | Hannspree Computers & Internet
Everytime i conect my monitor into my mac mini the screen shows up for a brief second and disapeers. How can i fix this
You need to lower down the screen resolution. Check the setting of your mac mini then adjust the screen resolution to the lowest.
Jun 09, 2010 | Acer V193w LCD Monitor
DVI-D cable not working with Westinghouse L1975NW...
If the monitor has two video inputs - a DVI-D and a DSub VGA then the monitor needs to be switched to the DVI-D video input.
Jan 26, 2010 | Westinghouse L1975NW Monitor
I am trying to re-connect a Mac Mini DVI output to an old (original model) Gateway42" plasma TELEVISION. The problem is I re-set the display on the Mac Mini to a widescreen resolution, which the TV will...
Unplug both from power , and remove mac battery, restart first mac then TV, already connected.
Check source with tv remote, and ensure mac res is correct.
Mar 28, 2009 | Televison & Video
Mac mini will not produce video
Hi, Sorry you are having problems,
Well, that sounds pretty bad. Does the Mac make the start-up sound when you turn it on?
Does the little light in front turn on ?
Do you hear the hard drive spinning up and working to boot the mac ?
So, if all these questions are answered Yes.... sounds like the video connection has blown.
If you say the Mac is almost new, Apple should cover this with the one year warranty.
Good luck.
Oct 31, 2008 | Computers & Internet
Westinghouse L1975NW Monitor Logo
151 people viewed this question
Top Westinghouse Computers & Internet Experts
Matthew Spark
Matthew Spark
Paul Bade
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
