Suddenly, color is all screwed up. Everything looks VERY brite, like the tint is turned way up, but when I check in menu, it says normal. Every channel is like this. Very green & brite brite red.
  • 2,071 Answers
Just click below for convergence repair kit;
http://servicemanuals.vstore.ca/
images are tinted and colors are brite .Blue,red and yellow wave coming up from the bottom of the screen on the lower left and fuzzy images this is a symptom for faulty convergence IC,you must replaced this IC in order that will works better again.STK 392-xxx ICs and it's associated resistor,this resistor automatically change value,can caused truoble even though you change the ICs.If you bring this to a service center they cost you $600 to $700,but if you buy the repair kit you can save more,don't wory it is very easy because there is intallation guide including in the repair kit. Feel free to ask whatever the result... click the link for sample picture guide step by step installation;
Hope this may help;
Regards,
VOTIT
Posted on Jul 01, 2009
Everything works but when you look through the lense it show's yellowish tint and that's it
Yellowish color, hey. Didn't let the dog hiest his leg did ya. Normally because of coating on the image tube plate it should be green. Let me ask a few question. Are you constently replacing batteries? What color is it when you turn off the NV devise. If you can see the white color on the plate it only 18mm in diameter. Just remove the eye pieace and lens it screws into the base.
If that small plate is off colored and there are glass tinting on back/front of the image tube. Then it has gone back to Red Star. It on it last leg, sorry, stewbison
Jul 03, 2011 | Night Owl Optics Explorer NOCX3 Monocular
Panasonic TC-P42U1 plasma. Lost it's vivid colors basic color is black and white and green and blue if tint color tone etc. Is turned up. However a blue ray video plays with full color. Could it be a lose...
I have an old Toshiba TV and was going to replace it with a new plasma because it has suddenly (the week of July 19, 2010) lost color. It has only green and blue tint. Changing the "tint" on the menu didn't help. The color comes and goes relative to nothing that I can measure, such as how long it is turned on, etc. Reading other complaints from owners of Plasmas, I am thinking it is cable related. I have Charter Cable. Playing a DVD, I have to readjust the tint back to normal. Hope this info gives clues.
Jun 27, 2010 | Panasonic TC-P42U1 42 in. Plasma HDTV
Images on screen are very red. Tried adjusting everything in the menu but still every thing is like glowing red.
Color balance is labeled "Tint"
Color amount is labeled "Color"
Both are in the "picture" adjustments menu.
Either your tint is swung too far to red, or the color setting is wide open making normally pink faces look sunburned...likely it's a combination of the two; Too much red, and a bit too much color.
Going back to the "default factory setting" in "setup" will also drop all settings to center.
Mar 30, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Color problem
It sounds like the set has become magnetized. It could possibly be from an external speaker magnet or some other magnetic field (ie. a vacuum motor). It could also be a malfunction in the built in demagnetizer circuit. Color picture tubes are very sensitive to magnetism. Because of this there is a built in demagnetizer circuit. If this circuit malfunctions it can cause the same problem. Turn the set off and unplug it for 30 minutes or so. This will allow the circuit to cool off and reset. Turn the set back on and see if it returns to normal. Also, dropping the set or a heavy jar can warp the shadow mask inside the tube causing the same problem. If the unplugging method does not work, have a shop check it for you. Thanks for using fixya.
Mar 02, 2010 | Panasonic Televison & Video
My toshiba 61h71 has a reddish tint to it. Turned it off one night and it looked fine, next morning it got this reddish tint. Tried resetting the convergence but that didn't change the situation at all....
A Reddish tint means that the Green signal is missing. Does the on screen menu look normal? If so, this points to the signal source. The fact that this happend suddenly, I would check your cables first.
Using YUV?
If the TV's Menu also looks reddish then there is an internal problem with the display.
Good luck
Dec 30, 2009 | Toshiba 61H71 61" Rear Projection...
What are the optimal settings for color, tint and sharpness on a panasonic tc-l26x1?
those setting are adjustable so you can adjust to your personal preferance but reset back to factory or dynamic is good but i would suggest you play with the settings to your taste put on a newws show and asjust the briteness and contrast so you can see the seperation of a mans lapel color to just below half tint in the middle fase tone so people look naterial
Dec 23, 2009 | Panasonic TC-L26X1 26 in. HDTV LCD
Picture and menus are red-tinted all over
check system mode on dvd player,should be on pal
Jul 12, 2009 | Televison & Video
The flat screen panasonic TV has a green tint to it suddenly.
IN THE MENU GO TO COLOR CONVERSION ,,TO REALIGN THE COLORS
May 15, 2009 | Panasonic PT-52LCX65 44" HDTV
Viewsonic VG919S 19" LCD
Hi
You must focus to mainboard of LCD monitor find the voltage regulator IC. Voltage test the regulator IC use digital or analog multimeter range 10v dc connect the negative to cold ground, these regulator providing a constant supply of 2.5 - 5v to all IC in the mainboard. check the scalar IC. Because scalar IC will convert analog input signal of Red, Green & Blue. Lastly check the controller board, check the ribbon cable connector from mainboard to
controller board for lose, check the fuse inside controller. I think the exact problem of your monitor could be either the (mainboard) or (LCD panel where the controller board is located).
Oct 06, 2007 | ViewSonic VG910S (Black, Silver) 19" LCD...
Sanyo Tv color problem
I would check the green signal all the wat to the display screen to determine is this is a signal problem or a system short. I would recommend that you take this set to a qualified electronics technician
Sep 10, 2007 | Sanyo DS27910 27" TV
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
