Question about Maytag MSD2651 HE Side by Side Refrigerator
MAYTAG REFRIDGERATOR NOT COOLING
Maytag side-by-side unit (model# MSD2651HEQ) has power, but the refridgerator part is not cooling. Freezer is fine. Light is working in refridgerator - just not cooling. Thermostat is turned all the way up to cool, but again, is not cooling. Any thoughts?
  • Anonymous Mar 20, 2014
    nothing works, it dies have power to unit
    power to unit but nothing works, total black out
    Sergeant:
    Champion:
  • 235 Answers
Check to see if the evaporator fan is blowing. Sometimes removing the back panel to expose the fan and hand turning it can make it come back on. If this doesn't work then the fan is bad. Also make sure that there is good circulation to the fridge side. Food can sometimes block air flow.
Posted on Jul 01, 2009
Refridgerator will not cool. Freezer works fine. Noticed a pool of water on floor then started to cool again. after a few days quit cooling.
Check the water drain hole in bottom of unit. If plugged water cannot get to catch and pan and evaporate with the heating element.
Aug 25, 2011 | Maytag MZD2766GES Side by Side...
FREEZER NOT FREEZING
Hello Drdean825,
I understand that you are having a problem with your Refridgerator. The problem is that your unit is not cooling/freezing. I have a tip that you can follow that will show you how to check the mechanical side of your Maytag Refrigerator. If after you follow this tip you can not find what is wrong with the unit you can repost with make and model of your unit.
Tip for Mechanics on Refridgerator
Thank you for choosing FixYa.com
Justin
May 11, 2011 | Maytag MTB1891ARW 18 cu. ft. Top Mount...
Water leaking in freezer Maytag MSD2651HEQ side by side
you need to open the back of your freezer there is a hole for drain in the bottom...
clean it with hot water and pump so that way you clean the path to the drain pan next to the compressor.
The path might be frozen so use hair dryer at first... good luck let me know if you need more help.
Arik
Jan 11, 2010 | Refrigerators
Maytag MSD2651HEQ frige not cooling; can hear/feel fan blowing
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 16, 2009 | Maytag MSD2651 HE Side by Side...
Maytag refridgerator not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 06, 2009 | Maytag MSD2651 HE Side by Side...
Maytag Refridgerator and not cooling or freezing
sounds as if perhaps the overload replay has burnt up on the compressor, you can see it by removing the back cover, unplug unit and remove the starter from the side of compressor. if burnt up or melted youll need to replace it.. before you do i would call the manufacture with model and serial theyve experienced issue with some of these depending on model and serail they may cover repair
Mar 10, 2009 | Maytag MSD2651 HE Side by Side...
Maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Jun 20, 2008 | Maytag MSD2651 HE Side by Side...
Maytag MSD2651 HE Side by Side Refrigerator Logo
571 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
