HP Deskjet 2460 InkJet Printer Logo
Posted on Jul 01, 2009
The on off button of our printer is always blinking and coudnt print
Anonymous
Level 1:
  • Contributor 56 Answers
  • Posted on Jul 01, 2009
Anonymous
Contributor
Level 1:
Answers
56
Questions
0
Helped
15020
Points
91
Www1.hp.com/ewfrf/wc/document?docname=c00866324&lc=en&dlc=en&cc=us&lang=en&rule=21120&product=2510767
follow this link ur problem will be solved
  • Anonymous Jul 01, 2009
    man ..let me knw if ur problem is solved
Anonymous
Level 1:
  • Contributor 1 Answer
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
485
Points
I had same problem, resolved by testing every cartridge alone, the color one was the problem; need to buy new one.
Anonymous
Level 1:
  • Posted on Oct 04, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
485
Points
It's really normal if the on and off button is blinking. try pressing it a little long and it will stop blinking and it will print. It was my problem too. but now, i solved it. I tried pressing it a little long.
1helpful
Printer is Always On
Hey Vilma,
Try working through this document to see if it helps get you back online: Blinking Power Light Let me know if this fixes the issue. HP Printer Support
My printer always blinking
You can do the following options...
  • Press the paper load button.
  • Reboot your computer and printer.
  • Uninstall printer driver and then reinstall it.
If you need any kind of technical assistance you can contact support cell at http://vtechsquad.com/printer-support/
13helpful
2answers
Printer hp 2210 always says Press Enter to Align Cartridges. When I press enter it aligns and than says the same thing. When I try to print it won't print from the email or when I'm on line. When I press...
You press Enter , but the error message does not go away ? You have to bypass the cartridge alignment -
  1. Press and hold the Setup button.
  2. Press the Options button. The printer should be ready to print.
2helpful
Printer light always blinking
either out of paper and something still waiting to print or inks low
hope this helps :)
Epson 900 won't print
Try this if you try to print then have end of life wording on your screen with an X mark.
  • Pressing and holding LOAD/EJECT and CLEANING buttons
  • press POWER button, You will see blinking INK OUT led
  • Release all buttons
  • In 2-3 seconds time press and hold CLEANING button for 10-12 seconds.
Or use SSC. Read tutorial first before doing so.
The printer apear to be dead!
Buttons and lights on the printer Two buttons and three lights are located on the front of an HP Deskjet printer.
  • The lights tell when the printer is working or when it needs attention.
  • The buttons help control the printer.
Buttons and lights Purpose c00123886.jpg POWER button and light Push the POWER button to turn the printer off and on. When lit, the light shows that the printer is turned on. c00123889.jpg RESUME button and light The light blinks when there is a problem with paper. When the problem is corrected, press the button. c00123892.jpg Print cartridge light The light blinks when there is a problem with a print cartridge. When the problem is corrected and the top cover is closed, the light will stop blinking. Troubleshooting blinking printer lights Blinking lights Reason c00123895.jpg
All lights are off. The printer is off (asleep).
Press the POWER buttonc00123886.jpg to turn the printer on.
The printer should turn on automatically when a print job is sent to it. c00123898.jpg
The POWER (top) light is on. The printer is idle.
The POWER (top) light is blinking. The printer is busy printing.
Allow enough time to print. When a document has many fonts or graphics or uses complex color such as a color photo, it takes longer to begin printing. c00123902.jpg
The PRINT CARTRIDGE (bottom) light is blinking. Possible causes:
  • The front cover is open. Make sure the front cover is completely closed.
  • The print cartridge is missing. Make sure the print cartridge has been installed correctly.
  • The print cartridge is broken or incompatible. Lift the front cover, and wait for the print-cartridge cradle to slide out. Check the part numbers on the print cartridge:
Black: 51645A
Color: C1823D,
If the print cartridges are compatible and correctly installed, they may be defective. Try replacing the print cartridges.
If none of the above suggestions fix the problem, and, if the error message still occurs, it may be a hardware failure. Call the HP Customer Support Center.
11helpful
2answers
Canon i70 LED
The problem is your wasted ink tank it either needs to be replaced or you need to reset the error code like this
Try This
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button.
(Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button.
(Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power and Resume/Cancel buttons.
(Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
During initialization, the LED blinks in
green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
After the function (menu) is selected, press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
*** 4 times Green Waste ink counter resetting Both the main and borderless print waste ink counters are cleared.
Bad printing
just for info my printer wasn't printing much of anything black and color. If you hold down the middle button till the light on the top blinks twice it will give you a color test page. it should give you a grid to the right and to the left it should have the letter H and two blocks. If it doesn't you hit the middle button until the light blinks once and that is the cleaning. I have had to do almost 25 cleanings just today to finally get some results. Hope this helps you.
Paper & Power button blinking after each print
Sure, there is a utility program called SSC utility for epson. IT allows you to override errors, freeze ink levels, and more. I'd say download it, and on the menu, go to extras and choose "soft reset". Only do this out of warranty though, as it will void your warranty. BUT it works GREAT!!!
k24674
Grand Canyon Tech
Grand Canyon Tech
