Question about Refrigerators
Outer portion of divide between freeze & fridge where door seals rest when doors are closed very hot
  • 19 Answers
This normal. The heat you feel is very important in keeping the influx of warm from infiltrating the refrigerator. The barrier ensures that you will not experience any frost or icicles in you freezer.
Posted on Jul 01, 2009
My Samsung French Door, Bottom Freezer Model RFG297AARS was leaking into the refrigerator & pooling under the deli drawer.
Freezer /fridge water/ice in fridge and or freezer
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
Apr 05, 2015 | Samsung RFG297AARS Bottom Freezer French...
Water freezing on floor of lower draw under ice maker
Dec 05, 2014 | Refrigerators
Rfg293hars condensation coming from refrigerator
Freezer /fridge water in fridge
Oct 04, 2014 | Samsung RFG293HARS
Samsung RS275. Water pooling under bottom drawer and freezing. What doesn't freeze, leaks through the door to the kitchen floor. What is happening?
Jun 26, 2014 | Samsung RS275AC Refrigerator
Freezing around door of freezer
Jun 01, 2014 | Samsung Refrigerators
Rs 265lbbp fridge is freezing everything fridge portion no ice on coils
This unit has a heater on the damper door. Sometimes the heaters go bad our just weak, causeing the damper door to freezer close. You can try thawing our damper by removing it to see if the issue happens again.
Aug 18, 2012 | Samsung RS265LBBP Side by Side...
What's your problem?rs2630sh samsung fridge center hot
Do you mean the divider? It's hot to stop the door freezing to it. Nothing to worry about!
May 18, 2012 | Samsung Refrigerators
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator, should i unplug it?
Aug 25, 2009 | Kenmore 53642 / 53644 Side by Side...
Right hand door pops open when closing left hand door
The dool seal is not sealing completely on your fridge door . Maybe pulled in corner , split somewhere . If looks ok , then magnetic portion is not sealing against cabinet somewhere . Once you find the area , use a hairdryer to soften the rubber while door closed and it will pull itself down due to the magnet .
Jul 18, 2009 | Refrigerators
Fridge Condensation
Check the seal of the rubber gasket, if there are improper seal of the magnet, pour hot water along it to soften the rubber. (be careful when handling hot water). When the rubber is soften, try to stretch it a little by pulling it. close the door and the magnet will keep the seal in place.
May 09, 2009 | LG LRFC25750 Refrigerator French Door
Refrigerators Logo
121 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
