Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Renting, trying to use self cleaning
When door is looking makes a terriable noise and I get a code f9 I can not even screw it and forget cleaning it because it trys to lock again. HELP
  • 15,935 Answers
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#^%$#^#
Posted on Oct 01, 2010
MODEL NUMBER CPLEF398CCB. I tried to use the self clean and I received the f9 message. I am able to unlock door and you see the lock moving from lock to unlock. It unlocks every time i clear and restarts...
you either have a bad latch assy. or a bad computer board or a broken wire.this can be an expensive fix and the problem with self cleaning ovens is when you self clean them the temp. gets up to 1000 degrees and this damages the electronics in the machines,personally i would never use the self clean feature i clean mine by hand with easy off.people do this near the holidays and then the oven doesn't work parts have to be ordered and it could take up to 5 to 10 days or longer to get parts.don't ever self clean your oven when a holiday is coming up so this doesn't happen.if you can still use the oven just forget about the self clean if the error keeps you from cooking you'll have to find out what part is bad to fix it it sounds like your latch is working this code means the computer board thinks the door isn't locked if you want to change out the latch motor it's pretty easy,unplug the oven,pull it out and remove the back wall,the motor will be on the top right hand side looking at the unit from the back the part number is 316464301 this part is around 55 to 75 bucks depending where you get it now if it still does it the clock assy. is around 300 bucks part 316207600 so i would change out the latch assy. first if you need this repaired.hope this helps you out one more thing did you try unplugging the oven it could reset the computer board,leave it unplugged for 10 minutes and then plug it back in,don't try to self clean it,put it on bake and if the code doesn't come back great who cares about the self clean
Nov 12, 2017 | Frigidaire 30" Self-Cleaning Freestanding...
40494 / 40495 / 40499 Electric Single Oven: have a kenmore self cleaning electric range it was...
May 16, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Self clean cvode F9
Hello there:
F9 Problem with door lock circuit such as pinched wire between Electronic Range Control (ERC) and door lock switch Check wiring and test operation of switch
replace parts as necessary
May 15, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Oven door locked.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!$%!!!%!%
Oct 26, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
F9 code comes on frigidaire stove when self clean operation starts, i cleaned around door lock, what should i do next
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!#!#!#
Oct 13, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven door is open, but F9 now signals, trying to turn on
HI. this F-9 code is signaling a major door mechanism malfunction. the best action is to replace the entire door latch assembly. this will heel the F-9 alert and, fix the problem you are experiencing at this time.
Please rate and, have a great evening:)
Jun 16, 2009 | Amana AOCS3040 Electric Single Oven
Stove door locked and continues to beep and flash code F9
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$%^^%$
Mar 27, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Door lock lites keeps flashing but the door is not locked
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$@#$%
Mar 02, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Self Cleaning error F9
Oct 21, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven clean 'dr', F9, door lock flashing
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&&&&^%$%^
Jun 19, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
64 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
