Question about Sony Handycam HDR-HC3 HDV Digital Camcorder
Doesn't play or record tapes. Get a C.30.41 error. Will load tape. Tried resetting.
  • 72 Answers
Dear
u need to rate me for that ..ok dude....
actuallythis error is related to Head assy. i.e, the (head)drum motor is not completing its fg in proper time. try to use cleaning tape 1 st and then play back your normal tape.
if the problem persists then u need to go to the near by service center as they will clean the head assy. manually.
Posted on Jul 01, 2009
Not all cd tapes play clearly out of 12 tapes ,4 sound ok ,8 soundwrak
Are these all commercial pre-recorded tapes? Or are they tapes that were recorded at home? Is the tape deck one that the tape loads in from the short side and must be flipped around to play the other side....or is it one that the tape loads in with the tape facing in and is auto-reversing? Pre-recorded commercial tapes should work on most machines without problems. Home recorded tapes can be a problem, especially on the type of deck that the tape must be swapped over to play the reverse side. Many users use C90 or C120 tapes to home record. These tapes are thinner than normal tapes and are prone to getting overly tight and then can break and/or stretch. This causes jamming in the deck and distortion of the playback.
Jan 18, 2015 | JVC Car Audio & Video
Error message "push the reset switch"
Pull the battery out to reset it. Get a DV tape cleaner to clean out the tape deck.
That should solve both.
Aug 20, 2008 | Panasonic PV-GS300 Mini DV Digital...
Toshiba dvr670ku - vhs tape won't play, shuts recorder off
look to see if tape will fully load and if FF or REWIND work, if not a transport problem, drive mechanism not moving the tape, unit will sense this and shut unit off----even a problem in the loading mechanism for the VHS tape not loading the tape all the way will do the same thing.
Oct 14, 2012 | Toshiba M754 VCR
I've had a DR-MV5S DVD video recorder & video cassette recorder for years to transfer DVD over to VHS tapes. Something has recently happened where I can't record VHS tapes. Can't play VHS tapes on the...
Register and download the manual for free audio.manualsonline.com
http://portablemedia.manualsonline.com/manuals/mfg/jvc/jvc_dr_drmv5s.html
If it won't PLAY VHS tapes it must have a serious mechanical problem (if it even loads) or its heads are glommed up, so it obviously won't record them either. When's the last time you ran a cleaning tape through it?
Solve the load or playback problem and it will probably record.
Time and poor storage conditions are the mortal enemies of tapes. Store the in a 'played
Feb 26, 2011 | JVC DR-MV5S DVD Recorder/VCR
Sony HVR-A1U "Reinsert Cassette" Error pops up frequently
I have had this error on my 3 year old Sony A1E and it has resulted in glitched picture and audio, despite not showing a poblem whilst recording. It came up with C:31:23 error. Start of the tape seemed ok and the end seemed to get pixellated. A friend said the PD170 had the same issue and had to have her tape heads changed. I've tried cleaning mine but problem still there. I'm looking at getting new NXCAM as I've spent a lot of money last year getting it fixed.
Jan 06, 2010 | Sony HVR-A1U Camcorder
F11 error message in ag dv2700 during play.
I've been working for hours on this machine, cleaning and lubricating the mechanism and trying various adjustments to fix related problems. If I recall correctly the F11 error is due to tape mistracking, indicating damage to same. Someone posted a suggestion that the F08 error indicated a drum relay problem, requiring professional servicing; but it also comes up on my machine if the tape tension is too high and the mechanism cannot overcome it when loading the tape. I only realised this after finally tracking down pretty well all of the bearings needing lubrication; then adjustments to the tape tension could be detected. I've got to the stage that my AG-DV2700 will accept tapes that have been recorded on that machine; playing them instantly, after the usual auto tape tensioning where the tape is FF a few seconds and then RW a similar amount, if the safety shutter is enagaged; and merely accepting them in the normal fashion otherwise. Up until this point it would throw up the F08 error whatever tape was put in; if you switched the recorder back on instantly the tape would slow FF, ie not its usual whirlwind winding, and be available for use after auto rewind at the end. If a tape NOT recorded on it is put in it still stops with the F08 error. I would suggest that trouble with this recorder is likely due the loading mechanism becoming stiff. All you have to do is dismantle it - but there's lots of tricky bits and bobs in there to watch out for.
Mar 09, 2009 | Panasonic AG-DV2700 Mini DV VCR
Lines through the tape when recording or playing back
It could need a head adjustment. Any camera store can do that for you.
Feb 11, 2009 | Sony Handycam DCR-VX2100 Mini DV Digital...
Code 31 22 t reel error
Look i first hit reset for a second and it work for a second. Then it went back to the same problem. I turned the camcorder back on and i held the reset but while it was on. I held the reset button for like a minute, then every thing worked we recorded, the tape ejected fine, we watched what we had recorded and kept on testing it and everything still works give this a shot.
Dec 27, 2007 | Sony Handycam DCR-TRV460 Digital Camcorder
Panasonic NVDS60 "no tape error"
Clean the heads - search the Net for 'wet' versus 'dry' tapes.
Sep 19, 2007 | Panasonic NV-DS60 Mini DV Digital...
Sony Handycam HDR-HC3 HDV Digital Camcorder Logo
144 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
