Did it work previously, or is it a new installation? Open control panel/ printers, and ensure it appears.
Ensure you have it selected, when you go to print, if you have any other printer(s) connected.
Did you install the correct driver? there ar 2, 1 for parallel connection and 1 for USB.
Is anything flashing or lit up on the control panel, other than the ready lamp? It should go through its setup and heating process, before finally lighting the ready light.
Powering on and off could reset any possible error problem, or attend the problem indicated.
I assume you do have it switched on! The switch on the right side down low?
By pressing the start button 3 times, it should print a test page. If that prints, you have something external to the printer as a problem, most likely.
I have used this printer for 3 years & it has generally worked fine. Now, the red paper...
(More)
I have used this printer for 3 years & it has generally worked fine. Now, the red paper light comes on even though there is paper in the tray.
The toner light on my Brother HL2040 stays on, even after a new cartridge has been installed. Some...
(More)
The toner light on my Brother HL2040 stays on, even after a new cartridge has been installed. Some solutions mention pressing the GO button during the fixit process. Duh...I don't have a GO button, or I don't know where it is located. Is it perhaps labeled something else] or unlabeled??? Jim
will not print certain Lotus word pro documents. Ready light flashed as it is receiving data,...
(More)
will not print certain Lotus word pro documents. Ready light flashed as it is receiving data, printer starts to hum like it is ready to print, but then red paper light starts flashing. Same document does same thing on HL5240 model.
