Question about Panasonic Viera TH-42PZ85U 42 in. Plasma TV
Our tv has lines running thru it until it warms up a while
  • 1,056 Answers
Just leave it alone. That is not a consumer repairable problem. It cost too much to repair that TV at least you can still use it.
Posted on Jul 01, 2009
Our AC keeps cutting out. It runs for a few minutes then stops. have to switch off and restart. Any idea why? Have emptied water and cleaned filter recently
Look for:
  1. the ac needs air flow thru the indoor and outdoor radiators
  2. the outdoor radiator coil should get warm/hot and produce warm air.
  3. indoor radiator coil needs should get cold and produce cold air.
The ac needs the fan motor(s) working and compressor running and pumping. Compressor skinny copper line hot and thick line cold.
Jul 21, 2015 | DeLonghi Heating & Cooling
White horizontal lines covering picture on Toshiba 51HC85
The set uses a Hyper board inside that processes all signals, it is well known for this issue, board no longer available=reason is quite simple : about a dozen tiny surface mounted filter caps on that board with age dry out, at first it will work after warms up as poor caps regain some capacitance and seem to be ok.
Buy a new set, you can send that board out and have it repaired/rebuilt but the last one I saw which was under extended warranty cost about 200 just for the board rebuild.
In the last 4 years Here on Fixya I have encountered only 2 people who were able with instructions had the skill to remove the board and replace those caps, both were top notch computer repair techs.
Dec 09, 2012 | Televison & Video
How to flush heater core in 2006 sebring
Locate the two 3/4 inch black heater hoses running into your firewall remove clamps and stuff a chunk of the same size hose and run boiling water through it.it works with cool water but not as good.the clamps are real fun
Nov 28, 2012 | 2006 Chrysler Sebring
2005 softail,runs excellent warmed up but when its cold,it takes a long time to warm up and I have to ride with choke partially open
Hi Deuce, you may need to go through you carb for contamination. for more information about your question please visit the website below. Good luck and have nice day.
Harley Davidson CV Carburator rebuild and float adjustment ep 18 eng Roma...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 02, 2012 | 2005 Harley Davidson FXSTD - FXSTDI...
Radiator capacity 2002 SES Taurus
poor it in until it is full. Make sure you use a mixture of water and coolant. make sure car is running and turn the heater on, let it run until it is warm and the heater is blowing warm that way you know that the coolant is running through the system. also don't forget to put coolant in the reserve, to the hot line when hot, cool line when cool.
Apr 17, 2010 | 2002 Ford Taurus
LG 32LCD LCD TV Problem
It turn out to be a $10 diode on the mainboard, which cost me $100 to have troubleshot and repaired
Jan 19, 2009 | LG 32LC2D Television
2000 silverado 4.8 v8 runs bad when it is cold out side.
Try replacing the coolant temperature sensor for the injection system.
Jan 05, 2009 | 2000 Chevrolet Silverado
Luke warm heat
YES, THEIR IS A HOT WATER CONTROL VALVE, ITCAN BE OPERATED BY VACUMN, OR CABLE, VAC, TYPE WILL HAVE AVACUMN HOSE TO IT, PLS CHECK IT FOR CONDITION, CRACKS, SWELLING, IF OK, THEN WITH ENGINE RUNNING, HEATER CONTROL IN HOT POS. PULL HOSE OFF VALVE, PUT FINGER OVER END, FEEL FOR VACUME. IF THERE IS, MOST COMONLEY RESULT IS THAT VALVE NEED TO BE REPLACED.
Oct 01, 2008 | 1999 Jeep Cherokee
Cannot record thru line 1
If you could but now you cannot then this is a circuit break down- although check your set up , but I feel it is the machine beginning to die
Jun 15, 2006 | Sony RDR-GX315 DVD Recorder
Panasonic Viera TH-42PZ85U 42 in. Plasma TV Logo
137 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
