Channel skip from 47 to 94 ,with nothing in between
  • 26 Answers
Need to do another channel scan on your tv
Posted on Jul 01, 2009
Skip channel function not working coreectly
db:: 4.90::Fios tv VMS1100 skip not working correctly k3
www.hivmr.com/db/k37cmjfzkk71s913ksf3j7xfxsz3zc37
DB:4.90:Fios Tv Vms1100 Skip Not Working Correctly k3 ... Pressing Play on the remote has no effect, but changing the channel fixes everything. ..... The functions Skip Forward, Skip Backwards, Next Chapter and Previous Chapter all skip ...
The Secret Method to Skip Commercials with One Button on ...
Dec 28, 2015 | Televison & Video
How do I remove channels ?
Select the channel you want to eliminate, select one by one, and skip them by pressing the skip button on the remote control. Skipped channels will not appear later.
Oct 18, 2014 | Sanyo DP19649 LCD TV
We have no remote. Is there a way that I can get my tv to stop on channel 3? It just goes from channel 2 to channel 4 and does not allow 3 to come on -- skips right over it . I just need to use it for a...
it simply means that channel3 has been set to skip/go to the tuning menu and select manual search.select channel position3 and cancel channel skip function.
Oct 05, 2013 | JVC AV-32F703 32" TV
No signal at night
What you are hearing during the day must be what is called "skip". Skip is active during the day where you will hear radio operators from hundreds of miles away. Their signal is bouncing off an atmospheric layer well aboe the earth's surface. At night this atmospheric layer degrades and then so does the skip. Unless there is someone close to your vicinity transmitting on the channel you are listening too, you will not hear much at all. Try changing the channels until you pick up a conversation.
Dec 13, 2012 | Cobra 29WXNWBT CB Radio with Bluetooth &...
I recently bought an Xbox 360 and plugged it into the back of my TV. However, the TV refuses to show anything from the Xbox 360. I tried Autoprogramming it, and it erased all of my channels except for 1,...
MOST of their older sets are set up where the AV inputs are channels 90-93 ; if you had no signal other than the game the set will skip all those channels out.
If you have a working remote for it direct enter 90-93 one at a time .
Nothing hooked to cable fitting means set will see no signal and skip them out when auto program is engaged.
SD TECH
Sep 23, 2011 | RCA F25254GY 25" TV
I have a Cobra 19 here in Northeast Brazil. I have it in my car. I can only hear an awful lot of 'skip' and voices in the distance, nothing that seems close to home. Is that because there is no-one close...
Skip is an interesting phenomenon. When it kicks in full force, it pretty much kills any chance of local talking. Especially if you are on what are called "super bowl channels" these are channels where the big boys run. From 10k watts and up. Here in the USA these channels are 6, 11, and some times 26. If you are on any of those channels, you will hear nothing but them while skip is in effect.
There could be people in your area, but when skip is going you would never know it. And even if you did hear them, how could you know with all the noise going on.
Your radio is most likely setup correctly. If you are hearing the skip, then it is working. Give it a day or two for the skip to let up and give it a try.
I'm not sure how the channels in Brazil, as in the trucker channel. Over hear all of the truckers use 19, so if you are near a major truck route, you can always hear some one on 19.
So when it gets quiet again, go on the channel that truckers in your country/area use, and see if you can hear them/talk to them.
Nov 11, 2010 | Cobra 19 DX IV CB Radio
Whats skip mean?
It allows you to skip that channel when surfing using the up and down channel buttons. You can still punch the channel in with the number pad to get to it though.
Jan 24, 2009 | RCA Televison & Video
Quasar tv remote.
Sounds like you need to go to the main menu and run the automatic channel selector again. It will take note note of which channels are not in use and then skip over them when you use the channel advance. Use your remote to get into the main menu and select the "TV" submenu. Then run the auto channel select. After that's done, you can also manually choose to skip channels you don't like. I believe the channel numbers appear in green if they're to be included, and yellow if they're to be skipped. Even if a channel is skipped, you should be able to get to it anytime by punching in the number on your remote.
Jul 08, 2008 | Quasar VV-2002 20 in. TV/VCR Combo
Direct TV/Olevia 247 audio skipping
I have the same problem with comcast HD, completly useless talking to them, they do nothing to assist
Mar 26, 2008 | Televison & Video
Televison & Video Logo
142 people viewed this question
Top Televison & Video Experts
