Question about Dishwashers
My dishwasher makes a burnt plastic smell everytime I run it. I have checked all the possible places for things to get stuck and find nothing.
  • 10,515 Answers
Refer to :-
http://www.ehow.com/how_4677286_remove-melted-plastic-odor-dishwasher.html
Thanks.
Posted on Jul 01, 2009
Hotpoint DWF31 dishwasher went bang mid cycle and mild smell of burning plastic. Still powers on, lights on correct setting but stuck at 77 mins with nothing happening. Water still inside. Any ideas
Sounds like you have burnt something. May have shorted out. Shut it down and pull the plug or could maybe cause a fire. Get a professional to look at it.
Dec 19, 2016 | Hotpoint Dishwashers
Burnt plastic smell (per tenent) during dry cycle. I saw no melted parts on heating coil. Where to look next?
Hello Jon, thank you for your post!
Based off what you have described the Frigidaire dishwasher is giving off a burnt smell. You may need to check under the dishwasher to verify all the components are in proper working order. The element may have touched the tub or spray arm and this may have caused the smell. I would suggest having a professional technician out to your home for proper diagnosis and repair. Hopefully this information is helpful to you. -Matt
Feb 16, 2016 | Frigidaire FPHD2491KF Dishwasher
My dishwasher model FGHD2433KB1 has a burnt smell
Check for plastic etc. on the heating element in the bottom. It will likely look similar to an oven element.
Jan 19, 2012 | Dishwashers
Motor does turn and smells like something burning
there is nothing that can smell like burning such as a slipping belt in dishwashers, but there is a heating element (the metal element loop at the bottom of the machine (inside where the dishes go). Check to see if a plastic item got stuck to this element. If not, then you need a professional to check the underside of machine for bad connections. Good luck, Macgivor.
Dec 07, 2009 | GE Nautilus 24" Built-in Dishwasher
Bosch dishwasher stopped rujnning
Your dishwasher may be pluged into a gfi plug and need to be reset ,you might have wiring short posibly do to a pinched wire. Make sure your door was closed good,that could be the problem,If its a wiring problem call an aplliance repairman or electrician.
Dec 02, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
A burning smell and steamy smoke come out when we open the door.
Normally, the last part of any cycle involves using the heater element inside, and at the bottom of, the dishwasher to give dishes a final hot rinse. Possibly some small plastic-type material has become melted and stuck to the element - which will remain hot even after all water is discharged. Hence the smell.
Nov 17, 2009 | Whirlpool 24 in. GU980SCG Built-in...
I think our dishwasher is burning our dishes
Your pump is clogged.
Remove racks and inspect pump at the bottom center of dishwasher. Remove pressure arms.and clean out debris from tips.
Remove screen and cover to impeller and wet vac out all the grunge, especially plastic and glass pieces.
Good Luck
Jul 29, 2009 | Whirlpool GU2200XTSS Built-in Dishwasher
Burning plastic smell, big flash & now its dead - Bosch SHU8805UC
remove the water and, the burnt plastic that probanly melted on the dish drying heater coil
close and, lock the door turn the dishwasher back on and, reset the circuit breaker to see if the motor will run or, is damaged
Jul 01, 2009 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Dishwasher does not do rinse cycle
I,do not have solution for this problem. I,need solution
Sep 03, 2008 | Tappan 18 in. MDR251RE Built-in Dishwasher
Odor will not go away.............
hi there,
i would let you try putting a small can with charcoal in it inside the dishwasher. However, you cant use it for about 1 weeks' time.
Charcoal absorbs trapped smell.
hope this helps.
Feb 04, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
213 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
