I have a sanyo tv where the channels skip from 47 to 94,with no channels in between.i cannot get my sattelite to come in without a certain channel...help
  • 1,056 Answers
Out an antenna and do an auto program
Posted on Jul 01, 2009
I have a manual, but cannot remove unwanted channels on my DP19649. How do I do this????
As far as I understand, some TV's don't have the skip channel feature. If your TV has the 'Skip Channel' feature, you first select channels that have no signal (either a blue screen or snowy screen) then press the up -down arrows to select the 'Skip' and Ok button on your Remote. The Manual should explain how it is done.
Oct 18, 2014 | Sanyo DP19649 LCD TV
How do I remove channels ?
Select the channel you want to eliminate, select one by one, and skip them by pressing the skip button on the remote control. Skipped channels will not appear later.
RCA XL 100 Commercial Skip TV
Only thing I can think of here is to get a Universal remote, then try these pins to Sync your TV with URM:
RCA - 000,003,004,005,007,009,011,015,048,082,092,094,
096,098,101,102,103,107,113,125,129,067,179,187,188,191,194
May not work 100%, depending on remote functions.
Instead of just buying any, you could maybe borrow one from a friend first of all.
Oct 11, 2017 | Televison & Video
I have a Sanyo tv ( model #DS19330 ) and using a Sony remote to operate it. I am trying to restore channels 14-69 by scrolling through the channels with the remote. I can punch all channels in by...
It sounds like that the TV was set to skip certain channels. You need to rescan for channels or manually edit the channel list. To manually add channels, press Menu on the TV (or the equivalent key on the Sony remote if you found a code that works). Then use the Up/Down arrows (channel change keys) to select Ch Scan Memory + . Then enter the number of the channel (numerically or up and down arrows). Press + (volume + key) to change the setting from Deleted to Added or vice versa. Since you do not have the original remote, I'm not sure if the Sony remote will match the Reset key of the original remote. Unfortunately without that key being pressed twice, you can't reset the entire channel list and cause the channel search to begin automatically.
The manual for the DS19330 TV is here: http://www.sanyotv.com/DS19330%20%28ESF%29%203764--.pdf . (I'm assuming you haven't recently added cable after only receiving only OTA signals. If you have changed inputs like that, you need to go through the menu and change the source.) Menu > Cable or Air .
I hope this helps.
Jul 27, 2011 | Sanyo Televison & Video
We have a SAnyo HDTV LCD Model DP19649 and can't
I have a sanyo dp-19649 tv and it's hooked up to a panasonic sound bar model# sc-htb10,and it's hooked up to a sony blueray dvd player. the sony player works on the sound bar but the tv doesn't.
Nov 12, 2009 | Sanyo Televison & Video
13'' Sanyo tv skips from 47 to 95.
will probably have to have the remote or a universal will work.....cable tv remotes can be programed to work with most any tv. occasionally you can hold certain button configurations on the tv it's self to bring up the menu then do an auto search
Jul 07, 2009 | Televison & Video
Menu
I think, Your TV menu item to auto-program has been locked. read its user manaul to unlock it. Many companies gives such lock facility in tv to avoid miss use.
Jun 14, 2008 | Sanyo DS24425 24" TV
Sanyo ds25830
There is a button under the bottom edge of the screen (with the controls) that has the options "Normal" and "CATV" - press this and it should solve your problem.
Tracey
Feb 23, 2008 | Televison & Video
TV problem
Are you using cable to get the picture? If you are, make sure the TV set is in the cable mode,If it is then you most likely have a bad tuner in your set. Good Luck
Mar 21, 2007 | Sanyo AVM-1306 TV
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
