Question about Champion 2000+ Household Juice Extractor
It leaks from the screen at bottom how do I stop this?
    Champion:
  • 356 Answers
WHAT LEAKS?
Posted on Jul 02, 2009
How to stop gass from going into mufler on a 6500 champion generaitor when it is not running
there should be a fuel tap directly under the fuel tank. It should not be leaking fuel through unless there is a problem in the needle and seat ( staying open and not sealing off)
Feb 12, 2015 | Champion Juicers
A small slice of cabbage got stuck at the bottom of the funnel where the vegetable goes onto the blade. The motor stopped immediately and is now not working. This same mishap happened about a year ago...
A small piece of cabbage should not stop this machine. If it did stop, look for the red reset
button on the bottom of the juicer. I've been using mine for 21 years and occasionally it will
stop when run for an extended period especially if vibration is present. In each case I waited
a few minutes and pushed in the reset button.
Mar 29, 2011 | Acme 6001 Juice Extractor
My jack Lalanne juicer just suddenly stopped working.
Mine stopped working after only a few uses. It turns out that the safety microswitch button wasn't being depressed. The little button on the bottom of the pulp collector had broken off. (Image #1) I put a 1/4 inch piece of a shishkabob skewer in the hole before putting the pulp collector on. (image #2) It works fine now. It's still safe. The motor will not start unless the pulp collector (receptacle) is in place and locked in. Be sure to unplug the machine before doing this. 3717db6c-91bc-41ee-b452-1ed06578f280.jpgjack-lalanne-juicer-just-rgzqoe2q2f3mnxiw25vk3yhi-4-2.jpg
Mar 07, 2011 | Jack Lalanne Power Juicer 250 Watts
My juicer is about 10 - 12 years old and still works okay but lately when I am juicing it sprays juice everywhere from around the top and leaks out the bottom of the blade piece. Is it just wearing out?...
You might have been able to find a replacement seal for the top but if the bottom is leaking that means the seal is gone there as well and that means replacing the container. The real problem is finding any of these. And when you do the cost is going to be as much as a new unit.
I'm afraid the best advice is to replace the entire unit. The only thing is to make sure you buy a quality unit if you want to get any useful life out of them. A cheap unit is going to start leaking within a year or two (about 30 seconds after the warranty runs out) a good unit will give you hopefully another 5-10 years of use.Might cost more now but you won;t have to replace it that quickly either.
Feb 01, 2011 | Breville JE900 Juicer
Champion Juicer leaking a lot; from screen holder!
I'm having the same problem, the blank screen just doesn't fit the main body that well (I think the body on mine may have been warped by someone putting it in the dishwasher). Since I'm only going to be using my Champion as a front-end for a hydraulic press, I bought some food-grade silicone sealant (from McMaster-Carr or EMI Supply) and I'm just going to permanently attach the blank screen to the juicer body and slide the screen holder over that. There's a new O-ring for the back where the body attaches to the motor that might be needed as well.
May 02, 2010 | Champion 2000+ Household Juice Extractor
Stuffed parsley into the juicer and the motor stopped
Push red reset button on bottom of juicer. The
juicer is not designed for leafy produce, only
apples, carrots, celery, etc.
Apr 22, 2010 | Acme 6001 Juice Extractor
Need Power Juicer manual
If you go onto the website powerjuicer.com scroll down to the bottom of the screen and click on customer care. You can then select the option Power Juicier Manuals and select the model you have and print it. Hope that helps!
Nov 09, 2008 | Jack Lalanne Power Juicer 250 Watts
Everything leaked all over the countertop
You have one or two choices. You have every right to return to product to the store you purchase it within 30 days with a receipt. Now if you feel you want to keep it try to place the gasket on right. This should stop the leaking. If you did not get a gasket, then return this product for another one. Sign, Spurs21
Jun 12, 2007 | Jack Lalanne Power Juicer (Stainless...
Juicer stopped working
Fuse may be blown. Take off bottom, it is soldered to the circuit board. Unsolder and replace (I use a fuse holder) to make it easier
May 07, 2007 | Breville JE95XL Juicer
Champion 2000+ Household Juice Extractor Logo
162 people viewed this question
Top Champion Juicers Experts
David Payne
David Payne
ray gallant
Are you a Champion Juicer Expert? Answer questions, earn points and help others
