Question about Refrigerators
Refrigerator is freezing things at low settings
The thermostat was just replaced and since then the refrigerator is running to cold. It's usually set at 5 (freezer and Refrig), but now we have it set a 1 and the refrig side is still at 26-28 degrees. The freezer is set at 3 and the temp on that side is -10.
  • 19 Answers
The thermostat ???? Without knowing what the original problem was, I can only guess that this the original problem.The cold control is only as good as the devices circulating the air in the refrigerator. You probably have a damper control problem. Make sure the damper between the freezer and the fresh food sections is operating properly.
Posted on Jul 01, 2009
Refrigerator only works on max
Usually when a compressor is running low on gas it will freeze up on any setting but if it only works on max the thermostat is most likely no good cheapest thing to do would be to order a new thermostat 90 present of the time it takes care if the problem
Mar 12, 2014 | Sanyo SR-290 Compact Refrigerator
I have a true double door commercial refrigerator. it stay below freezing even though I set the temperature very low. it is freezing everything.
thermostats on those things are notoriously bad. probably a bad thermostat. should have numbers 1 - 9 and usually set on 5
Aug 18, 2013 | True Refrigerators
Frigidaire side by side freezes in the Refrigerator side
The temperature control thermostat, alson known as the colds control thermostat has gone bad and basically isn't converting electrical/temperature signal properly and needs to be replaced
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 16, 2012 | Frigidaire Refrigerators
Bad defrost timer/ thermostat???
It definitely sounds like you have a bad defrost timer, that is the reason the coils are icing up on you. The next issue, which may or may not be related is the freezing of items in the refrigerator. Usually the cold air is transferred, through a vent with a damper, from the freezer and into the refrigerated section. The "thermostat" for this section is actually usually just a lever to adjust the position of the damper. That being said, usually when you have a problem such as you are having, it is either a stuck or broken damper (or damper component). Hope this helps
Nov 16, 2009 | Kenmore 21.9 cu. ft. Bottom Freezer...
Food in my refrigerator freezes I have a top freezer maytag
There are 2 things to check - Your cold control dial - to rule out a thermostat problem lower it to 1 gradually and slowly until you hear a click and it shuts off - If it does not shut off, and only shuts off if you set it to the OFF position, then you have a thermostat problem and your compressor is continually running, freezing things in your refrigerator. If lowering your dial you hear a click and compressor shuts off, then the solution is to lower your dial, you have it set too cold - There is a thermostat in your refrigerator that should shut things off when it is cool enough it's either not working properly or your dial is set too cold.
Sep 05, 2009 | Refrigerators
Refrig temperature running cold. As low as 25
ASK TECH TO REPOSITION SENSING BULB FURTER FROM EVAP ON THE SUCTION LINE
Aug 23, 2009 | Dometic RM2852 Refrigerator
Refrigerator side temp keeps dropping below freezing.
Set the freezer temp control to MAX cold and see if it improves.
If not replace the off/on thermostat.(cold control)
May 24, 2009 | Kenmore Refrigerators
Fridge compartment too cold.
Most bottom mount freezer units work by diverting some of the cold freezer air up to the refrigerator through a duct that vents to the top of the refrigerator A thermostat in the refrigerator closes a flap in the duct when the refrigerator is cold enough.
It seems like the thermostat or flap is not working in your refrigerator. You can troubleshoot this by turning the refrigerator to the full warm setting and turning the freezer knob in the cold direction until you hear the refrigerator turn on. Place your hand near the vent at the top of the refrigerator, if cold air comes out that means the flap is not closing like it should.
If the flap is not closing, it might be frosted open. Pop the plastic vent off (they are usually held in with snaps) and inspect the flap. It should open when the fridge knob is turned in the cold direction and close when it is turned in the warm direction. If there is no frost jamming the flap, and the flap is not moving, the thermostat is likely defective. See the pictures below, one is flap open and the other is flap closed.c0498df.jpg67c95ca.jpg
Dec 15, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freeing food in refrigerator, even vegetables in vegetable tray
You have 2 dials in the refrigerator. One is the thermostat setting the cold temp in the freezer, the other is a damper that allows cold air from the freezer to the refrigerator. Set the thermostat to the middle then try closing down the damper, most say colder or warmer refrigerator. If the damper is closed and your refrigerator is still freezing, then I would guess that the thermostat is bad. A thermostat runs about 40 to 60 dollars wholesale. Retale should be about double.
Oct 20, 2008 | Samsung RS2534 Side by Side Refrigerator
Refrigerators Logo
125 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
