Question about RIM BlackBerry Storm 9530 Smartphone
Blackberry curve shutting down.
My phone shutting down unexpectedly. During the calls, I'd hear static sound and humming then will shut down. to power up again i need to connect the charger......
  • 136 Answers
You have to get the updates for it off the internet
Posted on Jul 01, 2009
I have a blackberry curve 8330 and suddenly today when calling out or receiving a call I can't hear them nor can they hear me, the phone rings on both ends though. The phone does not work with a blue tooth...
First, download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues, like volume issues.
If the issue is still present, then it could be hardware related, and may need to be repaired or replaced. I would then suggest contacting your Provider for Hardware Support.
Nov 04, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Blackberry Curve loud static when making calls
Very common problem with 8300 series. My phone started doing it too. Don't mess with the OS. That's a last resort thing. The cause/solution that seems to resolve it for most cases is replacing the battery. I picked up one on Ebay for $7 INCLUDING shipping.
Phone now charges to 100% and stays there for a while as opposed to
dropping to 60% quickly. SO far my phone is behaving. One thing I noticed is that if I used the phone with the charger still plugged in, the phone did not shut off which was yet another indicator that is was power related. It is sad that most of the responses from Blackberry give the impression that this problem seems new to them and that it is probably a hardware problem and you need to take it in, as opposed to just saying that this is a common occurance... try replacing the battery and if that does not fix it THEN bring it in for repair...
Aug 24, 2009 | AT&T Blackberry Curve 8300 Smartphone
Shutdown preceeded by static
Not true. I replaced the battery and it now woks like new. Try it! Order a battery online. They are less expensive.
Jul 27, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
8320 shuts down in the middle of calls or rather does a restart as if you press alt shift delete keys. Only happens when talking on the phone. Happened maybe once a month for the first few months and...
Once the BB 8320 shuts down in the middle of calls, more likely it's the battery. There were times that you would see that the battery is fully charged, but once the call comes in, the battery is starting to discharge quickly and unexpectedly.
And after it dies, it would try to re-gain a small amount of power. But you need to isolate the problem, try using different battery to test it. Some repair shops let customers use their spare batteries for testing purposes.
Or contact Blackberry manufacturer for second opinion.
Have a great day!
Jul 25, 2009 | RIM BlackBerry Curve 8310 Smartphone
OMG Mine's doing the SAME thing!
sounds like there may be a physical problem with the device. I would recommend contacting your cellular provider (att, verizon, sprint) to see if they can repair/replace the device.
Jul 11, 2009 | RIM BlackBerry Curve 8310 Smartphone
Placed password shut phone down
Which model are you wanting help with - You mention both the 8300 and 8900?
In any case - The 8300 doesn't have a reset button? On the 8900 it may be behind the battery cover if so you will need a paper clip.
The following advice is general to Blackberry's and will help clear the memory and reset issues - These are both the soft and hard reset.
You can do a soft reset using Left Alt, Right Shift and Delete - Hold down keys simultaneously for a couple of seconds.
If that doesn't work - Try power down, remove the battery for a minute or so, re-insert battery and then power back on.
Let me know how you get on with the above - If they don't work - Can you also clarify which model no as I have given you generic advice for both models...
Jun 03, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
BB Curve keeps shutting off while on telephone calls
I would suggest downloading the lastest handheld software for your BB and using the desktop manager backup your data and install the new software.
here is a link to thier site:
https://www.blackberry.com/Downloads/entry.do?code=577BCC914F9E55D5E4E4F82F9F00E7D4
Hope this helps, if it does please rate my solution,
Thanks,
David
Mar 11, 2009 | AT&T Blackberry Curve 8300 Smartphone
what you need to do now is take the phone to a mobile service center and have the mainboard fix or flashed....jun error means that the unit is going bad.
money_kohil - after the passowrd was enter incorrectly 10x then take the will blank and reset to its default and clear al saved data.....if it s not powering up after that then you will need to take the phone to a mobile service center.
Dec 27, 2008 | RIM BlackBerry? Curve 8330 Cellular Phone
Original BB Curve shut down
I had a similar issue and here are some things to try.
Replace your battery.
Back up your pictures, 3rd party apps, contacts and calendar data. Wipe your system with the Desktop manager and reinstall.
Upgrade your operating system on your Curve. The latest at the time of my post is the 4.5.xxx. Go to www.blackberry.com for the link to the latest operating system software.
Jun 18, 2008 | RIM BlackBerry Curve 8310 Smartphone
RIM BlackBerry Storm 9530 Smartphone Logo
272 people viewed this question
Top RIM Cell Phones Experts
Longtime User
ismael castillo
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
