Whirlpool washing machine fills with water then hums then quits. has burning smell coming from pump. what to do?
    President:
  • 1,136 Answers
Hi, It sounds like onr of 3 things might be locked up. It could be the motor, pump, or transmission. If you try the drain/spin cycle, does it stil hum or will it work?
Most cases is the pump has a sock or something in it. I would need to know make/model # to give you more instruction. Please let me know if I can assist you further.
Vic
Posted on Jul 01, 2009
My whirlpool ultimate careII quiet wash washer stopped working in mid cycle. It won't agitate, drain, spin, fill with water, nothing. The washer makes a humming sound and an electrical burning smell.
If your smelling electrical burn.. It's most likely to be the motor is bad.. Or just stuck, new washers made today are DC motors and contain a circuit board in the motor.. And are not serviceable.. Just replace them..
Dec 02, 2016 | Whirlpool Washing Machines
Estate Washer Model TAWX700JQ0 Washer fills when started... Does not Wash, Spin, Rinse, or Drain. during the wash cycle the water fill solenoid sounds like it is energized but no water is entering the...
You say washer fills and then you say no water is entering the washer?? Burning smell is most likely motor overheating due to maybe something stuck in drain Pump.
Nov 14, 2017 | Estate TAWX700JQ Top Load Washer
My washing machine will fill up with water but it will not agitate or spin to drain the water all it does is make a humming sound like its trying to and if I let it hum for a while I start to smell...
This is most likely going to be something hung in the water pump. On this pump I end up changing the pump because it is hard to get it unclogged without damaging the pump. This page should help. http://www.appliance-repair-it.com/Whirlpool-washer.html
Sep 16, 2010 | Kenmore 22932 Top Load Washer
Machine fills with water, then hums.
sounds like the timer may be heating up!
Jan 01, 2010 | Whirlpool LSQ9610L Top Load Washer
Water will not drain humming noise
Humming sound could be jammed pump.Remove th filter and check pump Blades are free, nothing is stuck in it....
Nov 25, 2009 | Washing Machines
No water running through cycle once filled....making humming noise once clicks into cycle
pump should be checked for restriction of movement,is there something blocking it?does the capacitor smell?if it does its blown(or meter check-more accurate),hope this helps
May 27, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool Thin Twin washer won't start, just makes humming sound
The belt is broken and needs to be checked for any other part that has failed causing the belt to burn.
May 26, 2008 | Whirlpool LTE6234D Top Load Stacked...
Crosley washing machine
the drain pump is blocked and will need to be cleaned out as the humming is comming from that pump motor by the sounds of it
so check that
cheers
Mar 15, 2008 | Crosley CAWC529JQ Top Load Washer
Washing Machines Logo
115 people viewed this question
Top Washing Machines Experts
