Question about Saeco Magic De Luxe Espresso Machine
Poured water into coffee grinder
Poured water into coffee bean grinder by mistake into Saeco Magic Deluxe and now the beans won't grind
  • 867 Answers
Easiest thing to do is put it outside to dry or use a blow drier to dry it up, it should be ok
Posted on Jul 01, 2009
Two weeks ago I paid > $100 for a full service (Saeco Magic Deluxe) and now the machine won't grind the coffee beans. Any suggestions so I can be a bit "knowledgable" if I need to take it...
Hi
If the grinder is spinning your grind set is too fine. Push the lever below the bean hopper to the back. It can go to a coarser setting anytime but the grinder has to be spinning to make it finer. They may not have set the grinder correctly. Have them walk you through the process. It also takes about 2 to 3 times before the grinder fills to work.
Apr 13, 2011 | Saeco Magic De Luxe Espresso Machine
Tip
Fix Saeco Magic De Luxe Not Grinding problem
If you leave the machine for a while, the residual ground beans in the grinder stick and clog the grinder.
- thus "timing out" with the "No beans" light.
After taking apart the grinder and cleaning it out, it still didn't grind. -
Then we ran some ground beans through it a couple of times, and then put fresh whole beans on top of the preground, and it took.
Worked great after that.
on May 06, 2009 | Saeco Magic De Luxe Espresso Machine
The grinder grinds too long, then stops and then the bean refill light goes on, ---there are plenty of beans but no coffee being made. I think the grinder is not working somehow. Its a 5 year old Saeco...
The lever under the bean hopper is set to low. Push it all the way to the back.
There is a leverbehind the door in the middle top. Pull it to the minus and try again.
If that doesn't work you are going to have to take the grinder apart and clean it.
Jan 05, 2011 | Saeco Royal Cappuccino Espresso Machine
Our bean grinder has stopped grinding. It spins but the beans do not grind. The machine works fine on the ground coffee option.
Did you put water in the grinder by mistake? If the grinder is wet it won't grind anymore,have to cleaned the blades physically .
OR are you using the beans from the fridge? It's a NO NO.
Jul 30, 2010 | Saeco Magic De Luxe 30092 Espresso Machine
Machine has major problem with grinding beans.
Try removing all beans from bean holder - then use a vacumn machine to remove the bits down amongst the grinder "teeth'. You may have had a small stone in your coffee and if so it may have jammed the grinder.
Once it looks clean, try making a cup of coffee without the beans in the hopper - you should be able to see and hear the grinder revolving and also hear the brew unit moving between the grinder outlet and the water inlet. If it all seems ok now, then add a small amount of beans back into the beans hopper and try making a coffee. If it still will not work, get it serviced. There's not much the average person can do inside these units other than to do more serious damage or kill themselves with an electric shock.
Nov 05, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco magic de luxe grinder problem
Hi Cindy,
Make sure you not get any water in the grinder, if you get water in the grinder then it bean smeary and will not grind the beans.
You have to clean the grinder if you get any moisten in it.
/Mirran
Aug 17, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco magic comfort coffee machine grinder
Make sure you not get any water in the grinder, if you got water in the grinder then you have to clean it.
You can try to set grinding to coarse and try to make 3 cup of coffee.
Jul 22, 2008 | Saeco Magic De Luxe Espresso Machine
My Saeco won't grind the beans
There's moisture in the grinder & it's clogged - just dismantle the grinder & clean it, then ensure you don't splash water into the bean hopper when you fill the water tank.
Mar 29, 2008 | Saeco Magic De Luxe Espresso Machine
The Coffee bean holder
You may have accidentally dropped water into the grinders. Email me your email address and I'll send you grinder cleaning instructions.
If the grinder cleaning does not work.. You may have to have to machine serviced.
Please include the model of machine and that you would like the grinder cleaning instructions.
Email: support@cerinicoffee.com
Oct 06, 2007 | Saeco Magic De Luxe Espresso Machine
Help....we poured some water into the bean grinder/container
You have to take off the bean hopper, turn the ring on grinder anticlockwise to you see the claque. Take out the middle off the grinder and clean everything carefully.
After that you have to put it back again, when you have the middle off the grinder back you turn the ring clockwise to the end, after that you turn it anticlockwise 14 "tick".
Sep 04, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
650 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
