Question about Samsung CLP 300 Laser Printer
Samsung paper jams very frustrating
My Samsung CLP 300 has constant paper jams. Follow the troubleshooting guide to to avail. I will not buy this brand of Printer again, piece of junk!
Unplug the unit and remove the paper tray. Flip it over. Be careful of the floppy paper catcher--don't let it break off as you're setting the printer down.
Look towards the back of the unit, and you'll see a dark grey to black rubber tread about 1.25" long, in the center of a shaft. This is the gripper that pulls the paper into the unit. It needs cleaning.
I used VHS tape head cleaner (amazing--I still have a VCR!) but you could use rubbing alcohol. Put a few drops on a Q-Tip and scrub away at all surfaces of the rubber piece. It won't move, rotate, etc. and don't try to make it do so. The swab will get dark. Use the other end of the swab to scrub the piece dry. Pick away any loose cotton.
Turn it back over, plug it in, and it'll probably work. Did for me after much frustration that I thought was due to bad paper or my paper getting weird from humidity. I didn't think it was a roller, because I had hardly ever used the printer, but that may have been the problem...
Posted on Jul 01, 2009
Why is red light on samsung clp- 315 and it is not printing
Does one of these situations apply to you?
The Status LED light is Red and the Toner lights are OFF (Check Smart Panel for message)
  • A Paper Jam has occurred.
  • The Front, Top, or Back Cover is open.
  • There is no paper in the Paper Tray.
  • There is a problem with the Waste Toner container.
  • A major error has occured.
The Status LED light is Blinking/Flashing Red and the Toner light(s) are Red
  • The Toner cartridge(s) that are Red need to be replaced. (Can still be used to print, but quality is unreliable)
The Status LED light is Red and the Toner light(s) are Red
  • The Toner cartridge(s) that are Red need to be replaced. (Printing is not available)
  • The Toner cartridge(s) are not installed properly.
Source: samsung troubleshooting guide for CLP-315
Sep 25, 2010 | Samsung CLP 315 Laser Printer
Samsung CLP300 - All LED lights red and getting very hot when on
drl1069.dyndns.org/Public/CLP-300.pdf Ok above is your service and repair manual, inside is all troubleshooting procedures used by the engineers to troubleshoot and repair these units.
May 11, 2010 | Samsung CLP 300 Laser Printer
Status light on printer is constantly red & USB status is not ava
Unplug printer and wait a few and then plug back in and turn on. Should reset printer.
Mar 29, 2010 | Samsung CLP 300 Laser Printer
Almost constant jamming ...
You need to check for bits of paper which could also trigger the sensor for the paper jam error.
If you cannot find any, then try to do a quick maintenance of the printer. Clean the printer head, initiate the print head alignment utility.
If it still not solved after these, post back so that we can help you further.
Aug 14, 2009 | Samsung CLP 300 Laser Printer
Samsung CLP 300 printer jams when using legal size paper. I've changed the paper size in the properties menu and it still jams every time. Help.
Make sure the paper setting in the printer driver software is set correctly. Sometimes that can cause this problem.
Aug 04, 2009 | Samsung CLP 300 Laser Printer
Paper jam at exit
The rollers at the exit area are worn out. They can be changed, in the mean time you can use something like sand paper to rub across the rollers to take the smoothness out of them. That will help them get a grip on the paper as it is exiting.
Jun 02, 2009 | Samsung CLP 300 Laser Printer
Samsung CLP 300 Laser Printer Logo
412 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
