Question about JVC Televison & Video
Sears (jvc 57-14367) service values changed
Service menu values changed by grand kids while playing with remote where can i find this data
  • 1,056 Answers
1 go to menu. 2 select clock set. 3 set it to 3:21am. while flashing hit the mute, and volume up/ volume down button. This will get you to the service mode again so you can change the parameters.
Posted on Jul 01, 2009
GREEN SCREEN
Try initialize the TV. If works, great. If not, doesn't hurt. Worth to give a try.
I had whole redish/pinkish screen on my 50v500 starting a few days ago, then I read through each of the threads on this site for the samilar problems on my model. I found TVtechmaniac's solution (pasted below) solved my problem. Thank you TVtechmaniac!
Enter the I2C Service Menu, be sure the power is OFF.
1. On the front control panel, press and hold the INPUT button.
2. Then press the POWER button for two seconds.
3. You may keep the INPUT button depressed until you see the OSD with the Service Menu displayed.
4. If you don't see the service menu, please repeat Process making sure you wait until the Power blinking LED stops.
5. Execute the Memory Initialize operation after the adjustment values have been written on a sheet of paper. Highlight "MEMORY INTI", arrow to the right and hold the button to the right (approx 5 sec.) until a check mark appears in the box. This activates the Memory Initialization.
6. After the Memory initialize operation has finished (10~15 sec, the channel will revert to CH 3.) the pink image symptom should be fixed.
7. Write back the adjustment values from your notes to their respective adjustment parameters in the adjustment mode. (In other words, set the Data Values back to the the Data values written down before the Memory Initialization procedure). NOTE: Make sure the SELECT Button is pressed on remote after every change to the values. Failure to do so will result in the data values not being changed.
8. Exit I2C menu. Press exit repeatedly until you go back to the normal picture.
9. Turn the set off-on and Confirm the picture remains in a good condition.
BE SURE TO COPY DOWN DATA SETTINGS BEFORE INITIALIZING I2C SETTINGS
Jul 12, 2012 | Hitachi 50V500 50 in. HD-Ready LCD...
Tip
Service menu codes jvc
I provide this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes.
-Press the {MENU} button and go to the User Menu screen, make sure
that the indicator (arrow) is pointed and highlights the "Picture Control".
- The buttons on top of the remote are set to TV & VCR respectively.
- Set sleep timer to "0" minutes and while it is displayed, simultaneously
press the {VIDEO STATUS} & {DISPLAY} buttons.
- The main service menu will be displayed with choices #1 through #9.
- Press one of the corresponding number keys to enter that menu.
- Use the {CH+} {CH-} buttons to navigate within a menu.
- Use the {VOL+} {VOL-} buttons to change the values.
- Use the {MUTING} button to memorize the changed value.
- Use the {BACK} button to exit the service menu.
Turn the TV on.
Using the remote control:
- Press the {INFO} & {MUTE} buttons at the same time.
- The Service Menu will be displayed
- Use the number keys to select the category.
- Use the {VOL+} {VOL-} buttons to enter the category.
NOTE: Some models don't have category selection.
- Use the {CH+} {CH-) buttons to select item to be adjusted.
- Use the {VOL+} {VOL-} buttons to change values.
- Press the {INFORMATION} button to exit.
Turn the TV on.
# Press {DISPLAY} & {PIC MODE} buttons at the same time.
# The Service Menu will be displayed
# Use the number keys to select the category.
# Use the {UP} {DOWN} buttons to enter a category.
# Use the {LEFT} {RIGHT} buttons to select items.
# Use the {UP} {DOWN} buttons to change values.
# Press the {DISPLAY} button twice to exit
# Press the {MENU} button.
# Select "Clock Set".
# Set clock to 3:21 AM and press "Start Clock".
# While a "Thank You" message is displayed on screen, press the {MUTE} and {MENU} buttons.
# The Service Menu will come up.
# Use {UP} {DOWN} to select items.
# Use {LEFT} {RIGHT} to change values.
# To exit, turn the TV Off.
on Apr 29, 2015 | JVC Televison & Video
What is the code of jvc tv
Mar 02, 2012 | JVC Televison & Video
I need the codes to unlock my j.v.c blue ray nx-db3. Thank you
Turn on JVC TV, simultaneously press DISPLAY and VIDEO STATUS in JVC remote control .
To select items, press MENU UP / DOWN (upload / download). To change values MENU LEFT / RIGHT (left / right). To exit factory mode press EXIT.
Write down all settings before change all TV system value seting.
Feb 28, 2011 | JVC Televison & Video
I need to get into the service mode for this television please.
Hello
Try this.
Feb 21, 2011 | JVC AV32F476 32" TV
UNABLE TO RECONNECT WITH SERVICE ON TV
Hello
You wants to get into the service mode of JVC tv, I thinks from your ad and powts this solution.
To get into the service mode of most of JVC TVs do the folloing:
This information is for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes.
NOTE: If you are not qualified and familier with adjusting service mode adjustments, Please don't get into it.
OK
Jan 25, 2011 | JVC Televison & Video
Need code
Hello
You are looking for its service menu code I thinks and posts this solution.
Most JVC sets have the same procedure to enter its service menu.
OK.
Jan 24, 2011 | JVC AV-27D302 27" TV
JVC TV LT-32G80BU can't navigate in menu + all channels messed up
TV seems to reset it's settings for some reason (it happened to me with similar TV - LT-32A80SU). I have found the way to solve this situation - service menu.
Press button "i" and "mute" on remote at the same time - service menu should appear. Now press 8 and there should be menu that allows to change few advanced features. Pressing down and up arrows allows to navigate, pressing right and left arrows changes values. You have to change "dual HDMI" to YES (this will enable second HDMI port) and change "remocon" to other option available (this will change how the remote behaves). Save settings by pressing OK button. Now you can leave service menu by pressing "i" button twice. You should now be able to use your TV like before.
Remember - these are instructions for my TV and they worked for me but playing with service menu can be dangerous so you're doing it at your own risk. Ask JVS support if you're not sure what to do.
Jul 19, 2009 | JVC Televison & Video
Picture is too wide for TV
One of your kids has altered the setting for 'Aspect Ratio'. you will find it in settings menu, picture.
Aug 17, 2017 | JVC LT-23X475 23 in. EDTV-Ready LCD...
Sony K60XBR800
Model
KF50XBR800, KF60DX100, KF60XBR800
RESOLUTION
Yes. Try the attached procedure. This has proven to be very effective.
Enter the service mode by pressing Display, 5, Vol +, Power.
Press Menu and go to Setup. Select Image Revision and set to 1. Press Menu once to exit the menu screen.
Cycle thru the service mode using button 5 until you get to D-GM TG. Press number 1 on remote once. You should now be at the 1 POS CTL. Change data from 11->1.
Push the number 1 button on the remote 14 times until you are at 15 ENB POS. Change data from 5->23.
Push number 1 button on the remote 8 times until you are on item number 23 PRG POS. Change data from 0->2. Write the data to memory by pressing MUTE, ENTER.
Push number 2 on remote 6 times until you are at H POS SHIFT. Proceed with the following steps very carefully. 0 VAR POS-CTL=0. Press number 1 on remote. Change D-GM HP item 1 from 9->11. Write the data to memory by pressing MUTE, ENTER.
Press 4 on remote. Change to 0 VAR POS-CTL=1. Then press #1 on remote. D-GM HP ITEM #1. Change data from 9->11. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=2. Then press #1 on remote. D-GM HP ITEM #1. Change data from 8->10. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=3. Then press #1 on remote. D-GM HP ITEM #1. Change data from 8->10. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=4. Then press #1 on remote. D-GM HP ITEM #1. Change data from 7->9. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=5. Then press #1 on remote. D-GM HP ITEM #1. Change data from 7->9. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=6. Then press #1 on remote. D-GM HP ITEM #1. Change data from 6->8. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=7. Then press #1 on remote. D-GM HP ITEM #1. Change data from 6->8. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=8. Then press #1 on remote. D-GM HP ITEM #1. Change data from 5->7. Write data. Press 4 on remote. Change to 0 VAR POS-CTL=9. Then press #1 on remote. D-GM HP ITEM #1. Change data from 11->7. Write data. Press 4 on remote. Change to 0 VAR POS-CTL=10. Then press #1 on remote. D-GM HP ITEM #1. Change data from 11->6. Write data. Press 4 on remote. Change to 0 VAR POS-CTL=11. Then press #1 on remote. D-GM HP ITEM #1. Change data from 11->6. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=12. Then press #1 on remote. D-GM HP ITEM #1. Change data from 11->7. Write data. Press 4 on remote. Change to 0 VAR POS-CTL=13. Then press #1 on remote. D-GM HP ITEM #1. Change data from 11->7. Write data. Press 4 on remote. Change to 0 VAR POS-CTL=14. Then press #1 on remote. D-GM HP ITEM #1. Change data from 10->6. Write data. Press 4 on remote. Change to 0 VAR POS-CTL=15. Then press #1 on remote. D-GM HP ITEM #1. Change data from 10->6. Write data.
Press #5 on remote 6 times back to catagory D-GM TG INV CTL. Press number 1 on remote once to the Catagory D-GM TG 1 POS CTL. Change the data value to find the best setting where no double images, ghosts nor merged colors appears. WRITE DATA.
Press #2 on the remote 11 times to the Option-E O Lamp Time. Note the current value and write it down. Add 2000 to the value (ex if 1356, than 1356+2000= 3356). Divide this number by 100 and write this value to the Option-E 11 P CTL SHT1. For our example above we would have 3356/100= 33.56. So we can round to 34.
Now add 50 to this number. In our example we would have 34+50=84. Write this value to the Option-E 12 P CTL SHT2. Make sure to write the data.
Select AUTO in the menu for the Image Revision setting and exit the menu screen. Confirm that the picture is fine.
Feb 05, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Televison & Video Logo
124 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
