Question about Maytag Atlantis MAV6000 Top Load Washer
How can I either bypass the lid switch or replace it myself
  • 1,056 Answers
You can bypass the switch by putting the two wires together that run into the switch. This is okay temporary , while you order a new switch. Don't leave it this way because this is a safety feature. In fact I don't really recommend bypassing it, because if you accidentally turned on the washer while loading it, you can get injured. I assume no responsibilty for this, as I am just answering your question.
Posted on Jul 01, 2009
Can a lid switch on a maytag bravos quiet series 400 model MVWB800VU0 be bypassed for testing, lid switch passes continuity tests but machine won't finish a agitate cycle?
the switch can still be bad manually even though it shows good electronically. How ever if its bad you seldom get some agitation then goes off unless ur opening and closing it? once its bad u get nothing, hence ur problem may be elsewhere. but Im u pics on how to jumper it, I myself think ur problem is in the timer perhaps sticking? if u have no agitation then check the water pressure switch and the door switch
Jun 22, 2015 | Maytag Washing Machines
Bypass lid switch
Never ever bypass lid switch. Legal liability forever. Any future owner of machine has 2 years from the day they discover bypass to sue the crud out of you for injuries. Not worth it for cheap lid switch. Do it right. If you discover bypassed lid switch on customers machine, fix it or leave machine inoperable.
Jan 12, 2015 | Whirlpool WTW6400SW Cabrio Washer
Can you bypass a lid switch
Yes. You need to determine if the switch is normally open contact or closed contact after which you bypass it. The hard bit is probably finding a spot where you can get at the wires to by-pass the switch. If you can find this spot, remove the wired, place an ohm meter across the switch and open and close the lid a few times. I suspect you will get a reading when the lid is closed, meaning you just join the wires together to bypass the lid.
Sep 22, 2014 | Washing Machines
Won't Spin
Sounds like a bad lid switch. Test my solution test by bypassing the lid switch. If the machine spins after bypassing the lid switch, replace the switch. Remember, this is a safety switch and needs to be on the machine.
Please rate this solution
Sep 06, 2009 | Whirlpool LBR4121JQ Top Load Washer
Lid switch is out
I would recommend you replace the lid switch rather than by-passing it. The following link explains how:
http://www.fixya.com/support/r385198-replacing_lid_switch
The lid switch is a safety feature that is to protect the consumer from the high speed rotation of the wash tub and the agitator. If you by-pass it, you will need to push in the timer PRIOR to opening the lid in order for the tub to stop. I would recommend by-passing as a last resort (temporary repair) while awaiting a new switch.
To by-pass a lid switch, follow the steps in the link provided to open the console. Make sure the washer is UNPLUGGED. Locate the white lid switch connector and unplug it. Remove the washer exterior case and remove the lid switch from under the washer casing. With the lid switch in your hand, cut the connector plug off, leaving about 2 inches of wire. Remove the green (center wire) from the plug and crimp the two black wires together. You have just made yourself a by-pass plug. Plug this back into the connector on the timer and the washer will now operate without the lid switch.
As I stated before, you will need to push in the timer prior to opening the lid to stop the tub. You can save the plug for future use, but use only as a temporary fix.
Replacement switches are available at searspartsdirect.com, appliancepartspros.com, repairclinic.com, and pcappliancerepair.com. They don't cost much and I provided you with easy instructions to follow.
If you have any questions, please let me know. I hope this helps you.
Jul 06, 2009 | Kenmore 24032\24036 Top Load Washer
Hello, i have a top load Kenmore Washer that has stopped draining, when you turn it on it will fill the water and sgitate but does not spin or drain. the model details are as follows: Model number 20642 2...
Yep - your lid switch is faulty.
You have to remove the outer shell to access the switch.
This video is not model specific to yours, but is helpful...
CLICK HERE for additional helpful links on bypassing to check - and knowing that the switch is bad - even though it's resistance checks good.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 22, 2009 | Kenmore Washing Machines
My washing machine does not have a spin cycle
I just solved this problem myself. It's the lid lock mechanism which is located under the top cover. When I manually moved the aluminum locking tab over my washer prompty drained and spun. There are four wires total going to the switch. Well, the solid white and the white/red wires control the lid lock mechanism. You can either replace the entire switch or bypass the lid lock by wire nutting the two wires I previously mentioned together. Now, if you bypass, be forewarned the lid will open while the washer spins very fast which presents a potential danger. For immediate use, bypass until you get the replacement switch. Hope this helps your problem.
May 10, 2009 | Westinghouse WWS833ES Super Capacity Top...
How to bypass Lid Switch Admiral Washer
The only way to bypass this switch is fist pill the plug, gain access to the switch from under the hood. put a jumper wire on the 2 wires on the switch. that will do it. I hope this helps you out.
Nov 28, 2008 | Admiral AAV7000A
Washing machine lid switch
Can you bypass the lid switch on a roper washing machine?
Oct 15, 2007 | Washing Machines
Maytag Atlantis MAV6000 Top Load Washer Logo
739 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
