Question about Dishwashers
Disintergrating black cardboard material related to water leaking
Re our Kitchenaid Undercounter Dishwasher KUDK01TKBL0 - Upon witnessing water pouring out the front lower door area, found pieces of black, sticky cardboard material, loose and falling out the bottom of machine behind door. Appears to be breaking into pieces and getting caught in door when closed. Can't find reference to this material in any parts list. What is it, and is it safe to run dishwasher with this material seemingly disintergrating. Help!
  • Dishwashers Master
  • 2,005 Answers
It is sound proofing and, your dishwasher is safe to use
Posted on Jul 01, 2009
I have a two drawer KitchenAid KUDD01DPPA. Upon pushing the start button on either drawer the dishwashers will start. then within a minute they turn red and beep non stop and the dishwashers do not run
Usually this indicates a leak. Open the bottom drawer and look underneath and behind it in the base of the frame and see if there is water sitting in there. If so, dry it out with towels. Once all the water is dried out run the dishwasher again. If the same thing happens and the water returns you will have to find the source of the leak. Sometimes its just a temporary leak from a tall item obstructing the lids from closing and sealing all the way.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
Feb 27, 2015 | KitchenAid 23 in. KUDD01DPPA Stainless...
Need trouble codes for a Kitchenaid dishwasher
If you are getting a particular code then I could help you find the solution.
However, the full service manual can be purchased for about $10 from here and would have all the codes.
Dec 31, 2012 | KitchenAid UnderCounter Dishwasher...
KitchenAid Dishwasher Leaking
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Jul 16, 2010 | KitchenAid KUDC25CH Dishwasher
BUZZING SOUND WHEN RUNNING
It sounds as if there is something in the bottom part of the dishwasher arm (it sprays the water around the bottom of the dishwasher). I would suggest that you take out the baskets and then remove and clean all of the parts that water comes out of as well as the bottom drain. If this works or does not, I would also suggest that you run an empty load using 1/4 cup vinegar. Hope this helps!
Mar 16, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
KITCHENAID dishwasher will not dry the dishes
kitchen aid mod kud101dl does not clean dishes well. lot of scum on door.
Feb 26, 2009 | KitchenAid Dishwashers
Water leaking from botom of Door
see if float cup is free on bottom of machine so it is not overfilling. take old toothbrush and clear any accumulated soap buildup from bottom of door and gaskets.
Feb 16, 2009 | KitchenAid Dishwashers
KitchenAid KUDR01TJ Dishwasher Cleaning Problem
Sinder...this sounds more like a water temperature issue than anything else. First, turn on your hot tap. If you can't hold your hand under it after it fully heats (over 125)...you should be okay. If not, raise your water temp or use the sani cycle to raise the temp. Change brands of detergent. Salt...I don't think so. You're using detergent...not soap...which would have been affected. Pressure should not be an issue...once the unit is filled, it makes its own pressure recirculating with the wash pump.
Oct 13, 2007 | KitchenAid KUDR01TJ Dishwasher
Dishwashers Logo
133 people viewed this question
Top Dishwashers Experts
