Question about Panasonic Televison & Video
H07 display - Panasonic Televison & Video
  • 158 Answers
SPINDLE MOTOR FAULTY-REPLACE IT
Posted on Jul 27, 2009
Dvd rv32 keeps saying hot and wolnt play dvds
I think you mean the front display shows 'H07' which means the laser/spindle motor assembly (as one part - also known as a traverse unit) has failed. H07 is a common error code with the Panasonic series of DVD playback decks. Because the traverse unit is a multi-operation device, and because the player is a budget model, the repair/replacement of this part to restore your player back to fully functional condition as well as labour costs could prove expensive - hardly worthwhile. It seems Panasonic have been using substandard components within their products for years now, designed to fail just outside their minimum warranty period.
Feb 10, 2011 | Panasonic DVD-RV32 DVD Player
DVD stops spinning displays code H07. Repair procedure?
H07 is the error code for Disk not Spinning. Open the case, open the DVD rack. Put 2 drops of 3-in-1 Oil on a Q-tip and rub the side of the spindle (located under the optical "eye"). Don't drip! Then close the DVD-rack with a DVD in it. Work the DVD in clockwise direction. Hopefully it will start to spin again.
hope this helps
john
Jan 21, 2011 | Panasonic DVD-RV32 DVD Player
My Panasonic dvd-rv32 player (8 years old) functioned perfectly for last 8 years and I cannot get it to PLAY again. I inserted another DVD tonight (actually 3 DVD'S in case the DVD's were defective) and...
Spindle motor/laser assembly is faulty. This part is not repairable - it has to be replaced by an authorised service centre. It may not be economical via this route, since the unit is not a DVD recorder. H07 is an indication of the above issue. Cheaper to buy a new DVD player or recorder than trying to get the faulty one repaired outside warranty.
Jan 19, 2011 | Panasonic DVD-RV32 DVD Player
Panasonic DVD player RV62 H07 message - disc
You can try to clean the laser by opening the unit and wiping gently with a cue tip or cotton swab, but if you are getting a H07 errorit may be somethng more serious and require a replacementof the dvd drive.I hope this helps. Good luck.
Sep 03, 2010 | Panasonic DVD-RV62EBS DVD Player
Player "reads" the DVD and then the display says "H07" and ends.
The "H07" is an error code, this particular error code refers to the dvd spindle drive motor. Effectively the spindle motor that spins the DVD isn't turning correctly and on occassion this can be that the spindle & bearings need lubricating due to partial siezure. But really this should only be done by somebody with a bit of technical know-how to avoid further damage to the machine or indeed an electrical injury to the person under taking the task. I can only suggest that you contact a Panasonic repair shop and to see if it is cost effective to repair.
Hope this helped,
James
May 02, 2010 | Panasonic DVD-RV32 DVD Player
Panasonic dvd cv 52
REPLACE THE SPINDLE MOTOR
Jul 04, 2009 | Panasonic Televison & Video
Error message or something
it means that your unit needs to be serviced and cleaned
May 07, 2008 | Panasonic SC-DK20 System
Dvd
I opened it up and sprayed silicone on the center where the disc snaps on. I also sprayed from a side angle to try to aim it towards bearings/works underneath. It worked!
Jan 24, 2007 | Panasonic DVD-RV32 DVD Player
Error Message H07
You can reset this fault by holding in the reverse, pause, and the on-off button, all at the same time. If it comes back then the spindle motor is the bad componet, and unless you know how to disasemble a mechanism for a changer I would let a pro handle it.
Jun 19, 2006 | Panasonic DVD-S35S DVD Player
Troubleshooting -- Displays H07 code
While stopped, press and hold REWIND and PAUSE on the unit and then also press and hold OPEN/CLOSE on the unit until Initialized appears from the display. Turn the unit off and on again. If it is still not working, Panasonic Consumer Support recommends having the product checked by an authorized Panasonic service center.
Dec 23, 2005 | Panasonic DVD-CV37 Multi-disc DVD Player
Televison & Video Logo
140 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
