Question about Mtd Garden
Engine revs up and down on MTD 13.5 HP Yard Man lawn
I just bought a used MTD 13.5 HP Yard Man lawn tractor that seems to have an engine problem. After choking, starting and running for a few minutes (perfectly), the engine then begins to rev up and down by itself. It does this at nearly any throttle setting, but it dies at the lower settings. It won't mow grass because it dies.
It may not be relevant, but it sounds excessively loud at the exhaust. Also potentially irrelevant might be that the tractor came from California originally.
I checked gas, lines, air filter, carburetor for obstructions. The guy who sold it says it needs a new carburetor. He says the two wires running to the bottom of the carburetor open the gas flow. He thinks that electrical part is bad and the gas isn't flowing consistently.
  • 2,418 Answers
Hello ctacket You may have 1 of 2 problems. First the carb. may just be dirty. It should have a 1/2 inch bolt directly in the bottom of the Carb. bowl. turn off the fuel pecock. Remove this bolt and carefuly remove the bowl. It has a rubber gasket at the top becareful not to damage that. ck for dirt or gummy old fuel and clean with spray can brake cleaner. 2nd problem may be a bit harder to find and fix. it sounds a little like a speed governor spring may be missing, out of adjustment or has gotten very weak with age. This is located on top of the carb. and hooks to another rod on the engine. as engine load increses the engine slows down (cutting into thick grass, no matter what speed you have set the engine at will slow down the engine down, then this gov. moves the speed rod on the carb to increse engine speed to over come the load) I hope I this makes sense. Ck for dirty carb bowl first, then dig into the gov and spring. I will try and help you out if you need more.
Posted on Jul 01, 2009
Yard man model series 760-770 Lawn Tractor was smoking a lot. Has oil, grass was thick and a little wet. Could either of these cause the heavy smoking?
over working the engine could have made it over heat that would make it smoke and also damage the engine
Jul 31, 2012 | Mtd Garden
Looking for schematics for a yardman lawn tractor model 760-770
Use the MTD part finder website and get the diagrams as you are seaching for the parts.
http://www.mtdparts.com/webapp/wcs/stores/servlet/ARIPartFinderView?storeId=10101&catalogId=19502&langId=-1#/MTD_Merged_Data/13637-8_(1988)/Lawn/010103700-A/0101037000001
Jul 01, 2012 | Yard Man Yardman Riding Lawn Mower 38in...
How to increase the land speed
bigger back wheels,otherwise you cant,unless you increase engine revs.should be about 3600 revs
Jul 04, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
MTD 46" Yard-Man Lawn Tractor battery connection problem!?
the battery for a garden tractor should have the holes already in it if not you can buy a clamp that you can use that has a hole for what you need. good luck
Apr 11, 2010 | Mtd 46" Dozer Blade, Fits All & Yard -...
Yard man mtd 20hp 46"cut hydrostatic drive lawn tractor,model"13AU69H401 deck belt need diagram to put it back on?
go to the online web site for the yardman this will give you the guide on how to replace the belt.
Jul 12, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
I have an old Columbia Garden tractor is this a MTD
go to partstree.com put your make and model# in and click the year you need from the engine window it should get you close to what you need .hope this helps
Jul 11, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Engine Pulley 660 MTD Yard Machines
make sure the narrow side of the belt goes in the pulley; you may have the wrong belt; make sure all the pulleys for that belt are the same height , if one is higher than the others that may be the problem
Jun 12, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Lawn Mower won't start
Its a thing of beauty to see problems solve themselves. It seems to me this trial and error approach is very taxing and could have been avoided if 1, your small engine repair guy/Craftsman/Sears had sold you the right parts from the start, or 2, you had bought the right part... from the start.
Oct 21, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
527 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
