Question about Dometic Rooftop RV Air Conditioner
The ac runs and does not stop. the thermostat will turn the ac off but the temperture setting doesnt work. I have already replace the thermostat. Is there some other type of relay on the unit that may have went bad?
  • 1 more comment
  • ben7784 Jul 01, 2009
    yes
    yes
  • Jeff Myers May 11, 2010
    What is the model unit of the air conditioner and the part number of the thermostat? The AC is running fine otherwise? If you turn the thermostat all the way up to 99, the AC just keeps running? Is it a digital or bi-metal thermostat? This information will help me to troubleshoot your problem. Thanks
  • 3 Answers
Was it doing this before you changed the Tstat?
Posted on Jul 01, 2009
High temperture
Have you check the thermostat?
You might want to remove it and install a new one see it still overheats.
May 27, 2008 | 2006 Chevrolet Cobalt
AC has stopped working. CT3500 thermostat. Had "replace battery" indicator on. Replaced batteries with fresh new ones. Now the blower is not working when AC is on. If I set the thermostat to Fan ON,...
Possibly - the fan is supposed to work in conjunction with the compressor. Otherwise the evaporator will freeze up.
Check to see if the thermostat can be reset to factory defaults because it definitely is not working right.
Sep 14, 2017 | Honeywell Heating & Cooling
My American Standard Heritage 11 unit was not working properly when i came home from work and the temperture in the house according to the thermostat show the temperture in the house to be 85 degree&#
the dual run capacitor is bad located in main panel of unit size of small red bull can it will be swelled up on top indicating it bad get on at electric motor or electric supply house most ac stores wont sell it has a rating like 35/5 370
Aug 27, 2012 | Heating & Cooling
Same problems need answers
i think the fan is supposed to do that and the a c might have to much or too little pressure
Jun 30, 2009 | 1992 Chevrolet Corvette
Honeywell thermostat display has flashing snowflake /ac not working
the flashing snowflake is it telling you its in % min delay if it doesnt stop flashing within 5min it may be a bad tstat. if it goes solid and the unit is still not working its probably not the stat
Jun 13, 2009 | Honeywell Electronic Programmable...
Over heat
Take it in for diagnosis.. .seems to me you don't know anything about vehicle maintenance... perhaps you need to replace the thermostat and flush the cooling system... not a bad idea.
May 26, 2009 | 2002 Buick Century
Air conditioning won't work. Thermostat says it's in 'recovery mode'
by the outside unit, you will have a shutoff. pull out the shutoff, and unscrew the cover. 2 cylinder like fuses are inside. It is likely that one or both are bad. When you turn on the AC and the outside fan does not turn on... this is likely this is the solution.
Apr 28, 2009 | Honeywell Electronic Programmable...
Radiator fans and a/c compressor doesnt turn on
for the over heating prob i would check the thermostat hell just replace if has been done already there cheap for the ac get a gauge n check ur freon add if its low on the lowside servive valve
Jun 07, 2008 | 1995 Pontiac Grand Prix
Dometic Rooftop RV Air Conditioner Logo
326 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
