Question about Orion1934 19" TV
Orion tv without input/output plugs
I've got an Orion tv, that has no input/output plugs to connect to a dvd player. What additional connector should I use in order to connect a dvd player to this tv?
  • 26 Answers
From the looks of the picture you have one audio video input port on the front of the tv. The connectors are yellow and red or yellow and white. Yellow is video and red or white are audio. Find those same connectors on the back or your dvd player, hook it up to the tv and there you go. You'll have to go to game mode or input 2 on the tv to see the dvd player.
Posted on Jul 01, 2009
CD player connect to TV
totally depends on what the player has for output and tv has for input plug holes .
Mar 10, 2015 | Toshiba Televison & Video
RCA DRC247N DVD Player No Audio
The separate DVD player has three output cables: video (yellow), right audio (red) and left audio (white?). These connect to the corresponding inputs on the TV. If your cable box also has three similar output cables, you probably do not have a second set of inputs on the TV so what to do? You can purchase three Y adapters that combine two female RCA connectors into one RCA plug and plug everything into your one set of connectors on the TV. However, if your cable box output connects directly to the TV antenna input, the solution is simpler. Post a comment if this approach is not going to work
Oct 13, 2012 | RCA DRC247N DVD Player
How to hook up my dvd player
if you want to hooked up your dvd player to a tv unit, you can use an rca connector. usually 3 wires for video and L/R audio. to connect with in the tv plug one end of the connector to the component input jack of the tv ( video/audio L/R ). and the other end of the connector just plug to the video/audio output jack of the dvd player.
Sep 17, 2012 | Televison & Video
I have a DVD player (Digitron) which I want to connect to my new Phillips TV but I don't know how to make the connection. Someone told me that I must use the remote control to do this but there is no
First with the TV and the DVD player off, connect the cables with the best possible connection that you can. The cable with the red,white and yellow plugs on both ends is a Composite Video cable. If this is the best output on your DVD player, connect the cable to those jacks and to the matching color connections for a composite (or A/V) in on your TV. Alternatively, use two (usually the red and white plugs) for your audio connection and get a separate S-Video cable and connect that to your TV and DVD player. Composite and S-video both carry only an standard definition (480p) video output.
Your DVD player may have other connections. You will need to buy the other cables to connect these but you will get a better picture (high definition video) if you can use component or HDMI cables. The component video cable uses three plugs (usually red, blue and green) to carry the video signal. You also use the RCA audio cable (red/white) to carry the audio between the TV and the DVD player. HDMI cables carry the video and sound on one cable and looks somewhat like a large USB cable (the side that connects to the computer - rectangular). These cables are available at many stores that sell electronics but you can find them at better prices at online stores that sell cables.
Once you have these cables, turn on the TV and look for a button on your remote (or the TV) that says Source or Input. Press this button several times until you are at the input that corresponds to the one that your DVD player is connected to. (Some of my TVs have more than one of a given input; so you have to match AV1 or AV2 for example.) Then turn on the DVD player. (Note for some TVs it is possible to delete inputs from the source list when they aren't used. You may need to edit this list to see the correct inputs.) If this doesn't help, try turning off the TV then turn on the DVD player first and then the TV and locate the correct input.
Without knowing the TV or DVD player models, I can't identify all of your inputs and how to determine the best one for you to use. If you add a comment with the model information, I'll give you additional assistance if I can.
I hope this helps.
(the inputs on all of my TVs have labels in a small font. Often each input choice is surrounded by a box so that you don't accidentally plug in the audio cable at Component 2 and the video cable at Component 1. You may want a magnifying glass to make sure that you correctly identify the source that you need to find in the input list.)
Dec 17, 2011 | Televison & Video
How to connect samsung dvd to samsung tv
Follow these steps: Component Video Connection 1. Get a component video cable. This cable has 3 sets of connectors, one each for the red, blue and green color signals.
2 Match the connectors to the appropriate video output jacks on the DVD player. Component video outputs will normally be labeled Cr/Cb/Cy. The Cy output jack is matched to green, Cr to red and Cb to blue.
3 Run the cable from DVD player to the TV. Most TV connections are made from the back panel, but this may vary.
4 Match the connectors to the appropriate video input jacks on the TV.
If using S-Video Connection
1 Get an S-video cable. This cable has a single round connector with 4 pins.
2 Attach one end of the S-video cable to the S-video output jack on the DVD player.
3 Attach the other end to the S-video input jack on the TV.
Composite Video Connection 1 Get a composite video cable. These types of cables are frequently bundled with two-channel audio cables. Composite video cables are tipped with yellow plugs.
2 Plug one end of the composite video cable into the composite video output jack on your DVD player.
3 Plug the other end into the composite video input jack on your TV.
May 14, 2011 | Samsung Televison & Video
How do i connect a DVD player?
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Mar 28, 2011 | Toshiba 22AV600U 22 in. LCD TV
Some DVD's sound fine whilst others have background sounds but no voices. I do have an old model TV that has mono sound.Would that cause it?
" Some DVD\'s sound fine whilst others have background sounds but no voices. I do have an old model TV that has mono sound.Would that cause it? "
I wrote a short article for someone who had a similar problem a few days ago.
I will edit it for you so that it fits. Here it is.
Your DVD player should have output connectors in the back of it to plug your amplifier or receiver into. If you have a Stereo system (no surround sound speakers, or front center speaker) connect the DVD Audio Cables on the back of the DVD player to the STEREO (or MIXED ) Output Jacks. If it is connected to the Left Front and Right Front jacks of the "Surround Sound" output jacks instead of Stereo(or MIXED) then the dialog will be sent to the CENTER channel output. If you have no center channel speaker you will not hear it. Thus no dialog.
NOTE: In your case for the TV that is mono, here is the solution.
1 Connect a stereo pair of RCA cables (red and white "male" connectors at each end) to the Mixed or Stereo Output of the DVD player (NOT ANY SURROUND OUTPUTS).
2 Purchase an RCA type "Y" connector that has 2 female to a single male connectors on it. Walmart about 3 dollars.
3 Plug the single male plug of the Y connector into the back of the TV set's single mono audio input.
4 Connect the stereo RCA pair from the MIXED output of the DVD player into the Y connector that is now on the back of yourTV.
5 Run your yellow Video output from the DVD into the Back of the Set's yellow input.
That should do it. The sound should be clear and correct with dialog, effects and music.
Hope this helps,
Best,
Mark
Jan 27, 2011 | Audio Players & Recorders
Have an RCA F27636BC TV. Can u hook a DVD player
How to hookup TV
If you have a TV with only a single coax input and you want to hook up components like DVD players and VCRs, here's how to do it.
What you need to connect your DVD player or game players to a TV that only has a VHF/UHF 75-ohm F-connector ("coax antenna input").
1.) RF Modulator with Stereo Audio Inputs.
2.) 6 foot long coaxial cable with male "F" connectors. This cable goes from the modulator to the TV. The modulator also has a coaxial input to plug in your antenna or your VCR.
3.) 6 foot long Video and Audio Cables with "RCA" plugs. The cables connect the yellow, red and white outputs from your DVD or game player to the yellow, red and white inputs of the modulator.
Works with X-Box, PlayStation, Nintendo or other devices that output audio/video via the RCA plugs and you want to connect them to your coaxial only TV.
Nov 24, 2009 | RCA F27636BC 27" TV
I change Component Cable Video & Audio 6 cables
I might sound stupid but Double check that you`ve connected the correct connectors as in All Inputs plugs being used or All outputs plugs being used. If you have one of these leads with 6 connectors on one lead, (Audio Input L+R, Video Input, Audio Output L+R, Video Output) You need to make sure that if you get sound from the audio input plugs, then you must use the video input plug and vice verse. Ian
Jul 22, 2009 | Panasonic PV-D4732 DVD Player / VCR Combo
Need instruction to hook up dvd player
You will need a TV or monitor with audio/visual inputs. The better ones have what is known as an S/VHS input, which separates the TV picture signal for better color reproduction. You will need to be able to switch your TV, usually by the channel selector, to the proper input for audio visual signals. Sometimes this is known as Video 1, Video 2, A/V etc. These are usually below Channel 2. Maybe your remote has that option. You will need an a/v cable. This is a three-connector cable with RCA plugs on each end. Connect the DVD player to the TV as follows: 1. Yellow cable, from video OUT on the DVD player, to video IN on the TV. Video is ALWAYS yellow. 2. Red and white cables from audio OUT on the DVD player to audio IN on the TV. 3. If you have S/VHS capability, buy an S/VHS patch cable which will have the three plugs mentioned, plus a round 4-pin plug. Select S/VHS OUT on the DVD player, and S/VHS IN on the TV. When using S/VHS, ignore the yellow connector. It is for composite video and not needed. Here's a hint: Your YV audio/visual inputs will usually be on the back of the set. Some better units have a/v inputs in front. What if my TV doesn't have a/v inputs? If your DVD player as an RF output, connect an RF "f" cable from that output to the antenna in cable on your TV. Otherwise buy an RF converter (about $20 or so at Radio Shack). Connect your a/v cable (yellow, red and white) from the DVD player to toe converter, then connect an RF cable (like the kind your cable box is connected with) to the antenna input on your TV. This signal usually comes in on Channel 3. Let me know if your problem is more complicated, It seems like a lot of wires and connections, but it is really straightforward, Remember, yellow is ALWAYS video. The two audio cables can be connected without worrying about color.
Dec 13, 2008 | Televison & Video
Orion1934 19" TV Logo
537 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
