Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
Runs for 25 minutes then shuts down like its out of fuel
I have the same problem with a 2 year old Wheel Horse XL 380H. I replaced the plug and the magneto. Now the shop says, maybe it needs the valves adjusted. It has the B/S 16hp Intek engine with OHV and AVS. And, mine too backfired a couple of times when shutting it down earlier this season. Crying shame, spend $2300 on a "new" lawn mower and get more problems from it in two years than the 17 year old cub cadet it replaced.
If blowing black smoke, before exploring costly parts, check the choke, if shut then will send fuel laden exhaust. believe is associated with the throttle/idle system.
Posted on Apr 27, 2012
Try taking the plunger off the fuel shutoff solenoid on the bottom of the carb
Posted on Jul 07, 2009
How do I find a wiring diagram manual?
well you might wanna check with TORO as they purchased wheel horse many years ago...
Sep 14, 2014 | Garden
1990 dakota engine shutting down randomly
I had a 1988 dodge Dakota ,and it did the same thing. I fould that the o2 sensor was bad. I am a self employed mechanic
Oct 28, 2012 | Dodge Dakota Cars & Trucks
Wipers do not shut off all the time on delay they sometime run regular and won't shut off for as much as 45 minutes
ask around other owners but i think your switch is falty 9 years old not much of a job to fix 1 hour 2 if you know nothing about it
Apr 27, 2012 | 2003 GMC Yukon XL
My 25 horse kohler starts when I put gas in the carb, then shuts off. I have gas from the fuel pump--HELP!
first check for power going to the solenoid on the bottom of the carb its a anti backfire valve if you have power there when the key is cranking and when turned on the solenoid might just be stuck if that works maybe the gas that was left in the carb turn bad
Apr 10, 2012 | Husqvarna Garden
During the summer time it will cut off sounds like it is loosing fuel pressure will turn over, but wont start back up until at least an hour later. Drives perfect during the winter time no problems,...
What causes this is ussually the oxygen sensor. It works when the engine heats up and if its no good, it will run your engine lean or even shut it down. check them and replace them. They should be done every 2 years.
Jan 06, 2011 | 1991 Mercury Topaz 4 Door
Mower starts and runs about three to five minutes, then dies
That is certainly fuel related. This may be due to (1) a clogged fuel filter, (2) restriction in the pick up or (3) an improperly vented fuel cap.
Change the fuel filter. Completely drain and clean all fuel lines. Check the tank pick up for blockage. Completely drain, clean and refill tank with fresh gasoline.
Make sure air filter is clean.
If none of these steps are successful, then I would suspect the carburetor.
Otherwise contact your local service center or directly here:
Husqvarna Customer Support FAQs AnswerArmy Community How To Videos
Feb 05, 2018 | Husqvarna 25HP Hydrostatic 54"Cut Garden...
Honda GX160 runs fine for 5 minutes then dies like out of fuel.
I would look for the fuel filter. Blow it our. I know you have a new tank of gas, but you might want to empty it out and make sure the clean and put in new. Even with Stabil in the gas you might just have to much condensation in the tank
Sep 07, 2009 | Master Heaters MASTER HONDA POWERED...
19.5 HP brggs engine (craftsman) shuts down after long runs.
Sounds like the coil,pull the shutoff wire off the coil and try it.if you still dont have spark replace coil.
Mar 17, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
692 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
