Question about General Electric WDSR2120J Top Load Washer
We have a GE top load washer with the model number WDSR2120J. It new (almost 13 months old so the warranty has just expired.) When we turn it on, it won't stop filling up when it is full. Bubbles then come up by the agitator and the water starts flowing out of the bottom. I'm guessing there is something wrong with a sensor, but I have no clue how to fix it or what to do. Any help would be appreciated. Thanks!
  • annakauzlari Jul 01, 2009
    Thanks! For the help. How do I take the washer apart to find the tubes?
  • 97 Answers
Hello Friend, You either have a bad water level/pressure switch or your water inlet valve is bad. If you unplug the washer from the wall and the water stops filling into the washer, then it's not the water inlet valve. If it only continues to fill when wash cycle is started then you will need to replace the water level/pressure switch behind control panel. Also, the pressure supply tube connected to water level/pressure switch may have a hole in it or a bad connection, or possibly plugged up. This rubber tube must have an airtight seal at both ends to perform properly. be sure to check this item also. Happy to help, Tim.
Posted on Jul 01, 2009
WDSR2120J washer will not fill in rinse cycle
possible 3 solutions for this problem 1 could be the cold fill solenoid 2 could be brushes in motor 3 could be main pcb
Feb 20, 2013 | Washing Machines
Have a 6 mounth old top loader washer GE and the spin will not work
A six month old washer should be under warranty. Did you register the product and do you have your receipt? I would call the place where you purchased it first and see what they have to say.
Dec 16, 2010 | GE WBSR3140DW Top Load Washer
GE WDSR2120J wash cycle sound
It's possible that the tub suspension system is out of position. Open the cabinet top (use a thin putty knife in each front corner to release a spring clip) and watch the mechanism while washing. Try shaking the assembly to see if you can spot something rubbing. Hope this helps!
May 23, 2010 | General Electric WDSR2120J Top Load Washer
GE Washer Model WCVH6260HWW, Fabric Softener Won't Dispense/Drain
I took the tray out and placed it to the side. Then I ran a common pipe cleaner through the nozzle that supplies a water spray to the tray. So far, so good.
Jan 28, 2010 | GE Energy Star WCVH6260F Front Load Washer
How do you remove the front panel on a ge model wdsr2120j5ww
Use a small putty knife. Put the putty knife in between the front panel and the top about 3 inches in on the left and right side. You will be inserting it straight in toward the washer and this will release 2 clips and allow the panel to rock towards you. Note some pressure must be applied and will not always release easily. Once the panel rocks toward you there will be 2 clips on the bottom. Just pull off of the clips and you are done. To reassemble allign the panel with the bottom clips and push the top back in, again with a little pressure.
Thank you
Please rate this post
Jan 23, 2010 | General Electric WDSR2120J Top Load Washer
Water valve P/N 8577407 failed after 13 months
If you ever buy anything from Sears, always keep a warranty,we do and had to use it alot.
Jun 28, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
GE Front Load Rips Clothes
clothing tearing is usally from foreign objects in or on clothing such as zippers fastners belts etc try making sure all those things are fastened should help
May 29, 2008 | GE Energy Star WCVH6260F Front Load Washer
Oil on floor under washer
Oil is generally not a good sign. It means that the tranny seal is blown OR it means that the tub seal is bad which allows water to enter the tranny (water is heavier than oil... if water gets into the tranny it will displace the oil and force the oil out)
This being a GE? I'd wager that a tranny job is in order. If the machine is less than 5 years old it's under warranty so you'd call GE at 1-800-GE CARES. If it's more than 5 years old? Your washer is no more than a boat anchor. Get a new washer, preferably a Whirlpool. The repair cost for a new tranny will out-weigh the value of the machine.
Hope this helps.
Mar 23, 2008 | Kenmore 22642 Top Load Washer
Washer does not spin
I had the same problem in october- my had a bad wiring harness, some board problem, and a bad sensor. if it hadn't been under warranty the cost of parts alone would have been over 1000bucks.
Dec 19, 2007 | Whirlpool Cabrio WTW6600SBT Top Load...
General Electric WDSR2120J Top Load Washer Logo
341 people viewed this question
Top General Washing Machines Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a General Washing Machine Expert? Answer questions, earn points and help others
