Question about PNY 2GB microSD Memory Card
Computer wont reconize my 4gb micro sd card
I put the micro card into the adapter and put it into the card reader in my computer but my computer wont recognize it nor can i find it anywhere???
i dont have anything on it yet im trying to load music and pictures onto it
    President:
  • 942 Answers
Try to plug it in another port at the back of your CPU plug it directly to the motherboard, if it does not work try to use another card reader, check your micro card if it is put correctly to the card reader,
Posted on Jul 01, 2009
How do you put your micro sd card in the computer?
if theres a slot for an sd card on your computer you need a micro sd card adapter. if it doesnt have an sd card slot you need to buy a usb memory card reader (making sure it takes a micro sd card first)
both are widely available in supermarkets/electrical outlets or on ebay/amazon/play etc and are very inexpensive.
(micro sd adapter)
(memory card reader)
Aug 02, 2011 | Kingston 4GB Secure Digital High Capacity...
My micro sd card won't be read by my computer anymore
Try to use a different card reader because the error pertains to a bad card reader. You might as well try to plug your card reader to a different computer. If you have no important data on your SD, you can simply reformat the card.
Jul 25, 2009 | Cell Phones
Micro sdhc card reader will not recognize 8gig card
You problem is most likely to be the fact that your micro chip is a HC chip. HC chips have a new program that is not backwards compatible to regular sd host ports. This is a simple fix, however. If you don't trust downloading programs for it on the internet, just go to target or walmart and get a USB SD card reader, and a SD adapter if you don't already have one. The usb adapter should only be like $10 at most.
Jun 07, 2009 | SanDisk 4GB microSD High Capacity Memory...
Motorola SLVR won't format my memory card.
I am not sure this will work, just a suggestion
Try inserting the micro sd card in the larger sd adapter that will allow you to put it into your computer reader. Try formatting it there instead
Apr 14, 2009 | Motorola Mobility SLVR L7 Cellular Phone
How to sink micro sd card with player
You should probably just copy the mp3 files directly from their source folder over to the micro sd. To do this, put the micro sd into some type of adapter that will allow the computer to read/write to it. There are usb sticks that do this and there are SD adapters you put the micro into so you can use a media reader/writer with it. Once you have the card seen by the computer, just drag and drop your MP3's into the drive letter corresponding to the memory card. After that is done, put it back into the player and turn it on. I should find all your songs and make them available to you.
Mar 13, 2009 | SanDisk Sansa e260 MP3 Player
Kingston 4gb sd card won't read
I had a problem with lenovo's reader like this, because i put in the nokia 6600 card, correct format and all, but apparently too old and not yet ment to be read by a computer ...
sd could still be hc ... the system of names is still not set up right. if you got a small black attachment for the card that makes it longer, put it on and try inserting the card again.
check if all the drivers are like they should be.
if you've got a friend with a card reader, make sure the card is ok. and if you've got a friend with a card, make sure the reader is like it's supposed to be
post a feedback, ok
Feb 23, 2009 | Dell Inspiron E1505 Notebook
Micro sd card not working
I'm having the same problem with a Transcend 4GB microSDHC card / microSD adapter. I have also found it probably has something to do with the card reader...either the card reader is an SD card reader trying to read an SDHC card OR the card reader is not able to read high-gigabyte SD cards (over 1 GB in some cases).
Jan 23, 2009 | SanDisk 4GB microSD High Capacity Memory...
Pc not recognizing sandisk micro sd
The Card Reader you are using is probably not compatible with SDHC Memory Cards (High Capacity SD). You may need to get an SCHC compatible reader or check the website for your product to see if the is a driver update. You can get a new reader for about $20 bones if needed. I had the same issue.
Dec 30, 2008 | SanDisk 4GB microSD High Capacity Memory...
Card reader
Because your reader doesn't support SDHC (4Gb or more)
If you buy a USB SDHC compatible reader, it will be fine.
Aug 24, 2008 | Computers & Internet
PNY 2GB microSD Memory Card Logo
416 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Sandy Moore
Sandy Moore
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
