How to open the P wireless optical mobile mouse to change the batter? There is no door or button or compartment to open. I tried pulling off the top portion, but it wont come and I am afraid I will break it if I pull and force it open.
SOURCE: HP wireless optical mobile mouse
Try changing the batteries or charging if it is rechargeable or try re-syncing using the syn button.
SOURCE: Mouse doesn't work
LOOK FOR A BUTTON TO RESET THE MOUSE AND THE USB CONNECT SHOULD ALSO HAVE A RESET SWITCH ON THE USB CONNECT YOU NEED TO PUSH BOTH AT THE SAME IME SO THE CAN GET INSINK OR THE CHANNEL TO SET. SOME TIMES THE MOUSE HAS TO BE TAKEN APART AND CLEANED JUST LIKE THE OLD MOUSE BALL ONE, AND RESET THE MOUSE SETTING IN CONTROL PANAL, UPDATE DRIVE MAY ALSO HELP IF THERE IS ANY NEW FIXS
ROD
PS SOME TIMES THE LEAD TO THE BATTARY CONNECTION NEED THE THE SPRING PULLED OUT A LITTLE OR THE OTHER END WITH METAL TAB ON IT NEEDS PULLED OUT BECAUSE THE PLAY IN THE BATTERY COMPARTMENT IS LOOSE AND THE CONNECTION IS INTERMITTING A VOLTAGE CHANGE AND CAUSES THE MOUSE TO LOOSE ITS SIGNAL TO THE TRANSMITTER OR SET FREQANCES.
ROD
SOURCE: changing the batteries in a hp optical wireless mouse
I had this problem too. I couldn't figure out how to change the battery. On my HP Precision Laser Tracking mouse all you have to do is simply press on the button near the HP logo at the bottom of the mouse. It will open up the compartment where the battery is. Hope this helps.
SOURCE: wireless mobile mouse 4000, usb gets hot, and usb not recognized
I have this same problem right now... What did you end up doing?
SOURCE: Help me make this wireless mouse work!
I had the same problem and after hundreds of tries i push the button on the receiver and quickly the red connect button on the optical mouse for about 5 seconds and it work... i don´t know if it´s a final solution but this time it work´d
