Question about ASUS Eee PC 900 PC Notebook
Battery pack showing not charging whats wrong
  • 197 Answers
Try taking out battery and plug in power. If it works, battery is faulty. If not,
Try taking out your hard disk plug in power, if it works, hard disk is faulty. If not,
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs..
Posted on Jul 01, 2009
Bantum rocam 1.6 not charging battery. the no charging warning light does`nt show any mulfanction. is there any fuse or relay related to battery charching ?
removing the battery lead when running is a very good way of blowing the rectifier pack, voltage regulator or line diode
take it in for a charging system check to see what was done wrong
Jan 20, 2018 | Cars & Trucks
Wont turn on
On all Panasonic Toughbook Models,
if the unit will not turn on try the following:
Step 1: Unplug the unit.
Step 2: Take OUT the Battery Pack.
Step 3: Plug-in the unit.
Step 4: Turn On the unit.
The battery pack acts like a giant capacitor and can
prevent the unit to turn on, especially when the unit
was previously used on battery pack and was allowed
to fully discharge to below 5%.
When the unit is turned on WITHOUT a battery pack,
then a single Green light should show on the front
edge of the unit when the cover is open facing you.
When the unit is plugged in WITH a battery pack,
then you should see a yellow, orange or green light
which shows the battery is charging. When the unit is
turned back on, then you should see two (2) lights,
one green and the other yellow, orange or green.
If the unit is plugged back in and either with the battery
in or out you see no lights whatsoever, then chances are
that something is wrong with your AC Adapter/Power Supply.
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Toughbook Authorized Dealer since 1989.
Feb 18, 2014 | Panasonic Toughbook Computers & Internet
I have a car booster pack that when plugged in to the wall it shows it is charging, but when you check on charge status it has not charged at all. What could be wrong with it?
Those things are like a little garden tractor battery inside
If it went dead over time and got frozen the battery may
be bad ,whey don't seem to do well unless used often.
Feb 26, 2013 | Cars & Trucks
Bell and howell dnv900hd won't power on with battery packs
The battery pack might be "dead". Get a new one.
Aug 14, 2012 | Bell & Howell Cameras
Ryobi charger model # 140295003 has a red and yellow light. When charging red light is on what does the yellow light mean? Also how long should the battery be left in the charger?
Completely wrong. Quoting from the user's manual:
"The charge indicator light (LED), located on the charg- ing stand, will light up red and glow when the char- ger is properly connected to power supply. This light indicates the charger is operating properly. It will remain on until battery pack is removed from charging stand or charger is disconnected from power supply.
After normal usage, 3 hours or less of charging time is required to fully recharge battery pack.
If both red and orange LED indicators glow, the battery pack is deeply or completely discharged, and 6 hours or longer of charging time is required to fully recharge battery pack.
Note: If charger does not charge battery pack or orange LED continues to glow after more than 30 minutes of charging, return battery pack and charging assembly to your nearest Ryobi Authorized Service Center for electrical check."
So to summarize: red = charging. orange (yellow) = fully discharged battery. orange after 30 minutes - bad battery or bad charger.
Apr 23, 2011 | Garden
I have a cordless KX-T7885 and can't get the battery to charge. i replaced the batteries and both phones but they both will not work. They sat for two years and I have just recently tried to use them. They...
If you have a multi-tester, check the voltage on the battery packs. The voltage should be equal to or greater than the voltage listed on the battery pack. If the voltage on the packs is too low, either the battery packs are defective or the charging systems of the phones are not operating properly. If the phones are not charging properly, it is likely not cost effective to try to get it repaired.
Oct 10, 2009 | Panasonic KX-T7885 Cordless Phone
They charge gets over very soon,even replaced the batteries
Please provide the correct camera model. If it is the Sony model mentioned then it uses an Infolithium battery pack which is charged in a very different manner then the one detailed above.
If the model is wrong and you have regular NIMh batteries then charge them for atleast 10 hours if using 2100 mah or above
Aug 21, 2009 | Kodak EasyShare Z710 Digital Camera
Engine on the aerobird swift plane keeps cutting out
the battery pack needs to be fully charged, it may take charging it 5 to 10 times in order to achieve this.keep an eye on it while charging and when warm to touch it should be charged.
Aug 18, 2009 | Hobby Zone Aerobird 3
Batteries show charged but no pwr
Clamp one side of [power line of your charger insert baterry pack,if amphere increase the battery pack was ok.select battery good one still run impact diver insert to the charger amphere increase good charger and battery pack. Two only the problem Battery pack or charger, if charger not function , the power transistor will be replace or buy new charger.
Dec 25, 2007 | Makita 18V LXT Lithium - Ion Cordless...
ASUS Eee PC 900  PC Notebook Logo
201 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
