Question about Canon PIXMA MP830 All-In-One InkJet Printer
My canon mp 830 all-in-one printer says 6A00,
My canon mp 830 all-in-one printer says 6A00 on the screen, which I believe means paper jam, there is no paper jammed. I've unplugged it and left it overnight and when I turned it back on it still says 6A00 with the alarm light blinking. Is there a way to clear it and reset it? can anyone help me?
JC
    President:
  • 942 Answers
No need to reset your printer, the things your should do is you just open the over at the back of your printer, then you can see a paper hang on, then please remove it, then try to print, if it does not work open also the tray which is your bond paper stored, just see if there is also a bond paper hang, then remove it, then print again, that the cause of paper jam
 Good Luck!!
 Nice
Posted on Jul 01, 2009
My CAnon MP 610 has a service error 6A00. What is
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 25, 2010 | Office Equipment & Supplies
CANON MP 830 ERROR CODE 6A00
Hi there
This answers with a titch more detail.
Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move.
And yes I have found all those things in a purge unit.
The offending item needs to be removed or the purge unit needs replacement.
Incidentally, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model.
And it’s always a paper path error or purge unit.
The purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Also clean the purge unit out make sure all is clean.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Mar 05, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Alarm button flashes, check printer, press OK .Error 6A00 appears, Pixma MP 750
Solution 1:
Solution 2:
Solution 3:
Dec 14, 2009 | Canon PIXMA MP750 All-In-One InkJet...
Canon MP 830 showing error code 6A00. alarm light flashing, no lights on ink cartridges.
6A00 is AP position error.First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Nov 29, 2009 | Canon Office Equipment & Supplies
I have a error code 6A00 and alarm light flashing on my canon pixma mp 830
Canon lists the solutions for the error 6A00 as...
1.
Press ON/OFF switch to reset the multifunction device
2.
Press Stop/Reset and ON/OFF to reset the printer
3.
Removing paper jams
4.
The MP830 may require repair
5.
Unlock the scanner lock switch (MP830)
Oct 16, 2009 | Canon PIXMA MP830 All-In-One InkJet...
MP 830 flashes between the copy button and hazard light(triangle symbol with squiggle in it)12 x.then starts the same 12x after a short pause.It will not do anything..whats the problem?
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Sep 03, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Code 6A00 -
6A00 means that the purge assembly, thats the cleaning unit where the printhead parks when off on the right, is jammed and cannot move.Look for paper or foreign material stopping it from moving. Sometimes the squeegee unit needs to be pushed back if the pads get stuck under it.
Jun 24, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
On my MP 830 Canon Error on my computer 5C10 Error on printer screen 6A00 Print head moved top the far right and appears to be jammed Had removed and cleaned printhead, reinstalled printhead and inkwells...
Hi
This happens a lot
Solution 1:
Solution 2:
Solution 3:
Feb 27, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Cannnon mp-530 shows 6a00
Hi
This is same as the wat full
Solution 1:
Solution 2:
Solution 3:
Dec 23, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Pixma 830 error code 6A00
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Dec 24, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
373 people viewed this question
old marine
old marine
