Question about KitchenAid KUDS01FKSS Dishwasher
DISHWASHER WILL NOT START! KithenAid KUDS01FKSS1
DISHWASHER IS USED VERY LITTLE, AND IS IN AN OUTDOOR OPEN AIR ROOFED CABANNA. IT HASN'T BEEN USED FOR ABOUT A YEAR. WHEN YOU OPEN THE DOOR THE RINSE ONLY GREEN LIGHT BLINKS ON AND OFF, ALONG WITH THE CANCEL GREEN LIGHT THAT ALSO BLINKS AT THE SAME TIME. PRESSING ANY OTHER BUTTON WILL NOT CHANGE THE LIGHTS BLINKING ON RINSE AND CANCEL AT THE SAME TIME. I HAVE TRIED SHUTTING OFF POWER TO SEE IF THE DISHWASHER WOULD RESET, ALL LIGHTS STOP BLINKING, BUT AS SOON AS YOU PRESS WASH AND START, THE LIGHTS START TO FLASH ON THE RINSE AND CANCEL LIGHT ON THE DOOR. CAN YOU HELP ME?
SOURCE: Kenmore Ultra Wash Dishwasher - Blinking Quick Rinse Light
My guess is that the foil that the buttons are mounted to is defective.  The control module "reads" the buttons that are pushed by the fact that the resistance between two pins on the circuitboard becomes zero ie. your pushing the button shorts out two pins.  the foil could have moistire damage or the resiistance of the tracks could be too high.  Solution for both would be to replace the control panel button foil.
Posted on Oct 17, 2007
  • 1314 Answers
SOURCE: Kitchenaid Dishwasher Control Panel lights - some don't light up
about the only thing to try would be to remove the inner door panel to get to the control bd then you will see a mylar ribbon looks like a fat piece of scotch tape pull up on the plastic connector that holds it in and pull the ribbon out then get a clean pencil eraser and gently clean the ribbon and put it back in dont forget to push the locking tab back down then try it again and let me know
Posted on Feb 12, 2008
yalmer
  • 552 Answers
SOURCE: Kenmore Dishwasher #15769
Try this solution first
Push the Hi-temp and then push the Sani-rinse. Go back and forth multiple times on these two buttons. I found that after a handfull of pushes that a "1" came up on the display. I continued to keep rotating the two buttons and then a "2" came up on the display and the dishwater started it's "drain" phase. I then hit cancel to clear and then I selected the cycle I wanted. The washer started up just as normal at this point.
Posted on Feb 16, 2008
  • 338 Answers
SOURCE: the flashing light blinks 7 times on the clean
ok well usually it is not sensing a temperature change in the water or not getting hot enough. so you can reset the dishwasher and try running the hot water in the sink before starting the dishwasher. if it fails again there is a heating element and control board kit that would need to be installed. you can reset the dishwasher by pushing "high temp wash" and "heated dry" back and forth until all the lights light up then you can hit the cancel and drain button twice.. put detergent in and run it.
Posted on Mar 04, 2009
  • 949 Answers
SOURCE: The dishwasher will not Start and the Clean Light keeps blinking
This blinking indicates the water did not heat up properly in the heated wash part of the cycle. I have put together some instructions on resetting the control so you can use the machine and some details on why it might have happened. Follow the link and if you have any trouble let me know.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
Posted on May 03, 2010
Car stalls out at idle. Whether its just left running in a parking lot or I come off the highway, stopping at my first traffic light. I repalced a very dirty air filter, but it hasn't solved the...
mafs cleane it it is on your air flow tube that conects to your carberator just be care full not to drop it spray it with mafs cleaner start the car but dont press on the gas on use carbartor cleaner on the carberator only ok dont press the gass at all let it start on it's own and when it starts use a pice of some thing to hold the carb open and spray it a little at a time..do it in a well open area..
Sep 14, 2011 | 2004 Chevrolet Cavalier
Just purchased a home in Sc. had been vacant some time! Aircondotioning unit was' nt hooked into power pane, just did that, provided call for air con via thermostat and extirior unit kicked on nice as...
It probably hasn't been serviced in a while. You need to check the outdoor coil and make sure it isn't stopped up with dirt. Let me give you a good website that will take you through a typical servicing of an outdoor unit. Also make sure you change filters in the indoor unit. If you do all this, and it still doesn't cool, you will need someone to check the refrigerant. Here is the website: www.familyhandyman.com
Hope this helps let me know if I can help you any more. Mark
Jun 27, 2011 | Ruud Heating & Cooling
My electric sun roof is open 3-4 inches and will not open or shut although increases to open a little each time i use car
plastic lining on runners tend to crack and lift causing roof to stick. can remove plastic but roof will rattle when closed. to close manually, open small cover on roof lining in front of sunroof and crank roof closed with an3mm allen key.
May 12, 2010 | 1994 Audi 100
I am an appliance repair technician. But, this one is stumping me. Kithenaid DW. Overfills and runs over onto the floor when NOT in use. I have replaced the inlet valve and disconnected the wires from the...
What??!! That is bizaro? If you have done that then logically it must be leaking BEFORE the solenoid, yes? OR the solenoid is some how Stuck Open? I mean that all I can think of, as if it is a NEW solenoid, the in non-operation mode is NC, AND the drive wires are OFF, then?? I know this may sound ODD, but maybe the new one is stuck open too. Give the solenoids a good whack or two & a soak in CRC, WD40 or the like? see if that somehow frees them up.
Feb 19, 2010 | KitchenAid 24 in. KUDS25 Built-in...
KUDIO1IL8L6 Kithenaide dishwasher. Water remains in bottom of dishwasher about 1 inch deep afeter all cycles are complete. I have checked to see if it drains and it does twice although it seems slow to me....
You have a restriction in the return of the unit. This also leads to sanitation issues. Pull the bottom basket, remove the lower arm and using a screw driver, remove the return cover. Clean out any obstruction and reassemble. If you are still having problems, your pump may be worn to the point it will not remove all the water at the end of the cycle.
Oct 03, 2009 | KitchenAid Dishwashers
AC repair on a 2005 Dodge Sprinter Van
system needs serviced possible low on ac fluid.
Aug 25, 2009 | 2005 Dodge Sprinter 3500 Standard Roof
Kithenaid dishwasher door pops open
Your door latch may just be getting weak and the temperature and air pressure differentiation when the cycle is complete (it's hot inside) may be popping the door. If you have had the door seal replaced recently that may also be a factor, they can take awhile to settle in.
Jul 21, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
Kitchenaid Superba Dishwasher clogged or jammed with broken glass
You will probably have to get at it from the bottom, possibly the back of the washer. Here is a link to your repair manual.
http://kitchen.manualsonline.com/manuals/mfg/kitchenaid/kitchenaid_dishwasher_product_list.html
Feb 02, 2009 | KitchenAid KUDS01DJ - Multiple Color...
This is a duo derm roof top air conditioner, possible compressor freezing up
If the compressor is not even trying to start you have an electrical problem in the circuit for the compressor. The thermostat could be open and not supplying power to the compressor or the thermal overload device could be open.
Nov 06, 2008 | Dometic Rooftop RV Air Conditioner
PHKJ048-1 outdoor fan stopped
This is nothing but a bad fan motor. Probably caused by rain down pouring off the roof into the unit. Try adding channel diverters that diverts water (a lip on the edge of the roof) >!
Sep 05, 2008 | Goodman PHKJ048-1 Air Conditioner
KitchenAid KUDS01FKSS Dishwasher Logo
80 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
