My air conditioner isn't cooling, instead it is blowing out hot air. I changed the filter and it still doesn't seem to work. Any help is appreciated.
  • ACSvcTechFL May 11, 2010
    is the outdoor unit running
  • 8,220 Answers
Check your condenser. if you cannot feel hot air out of it then the refrigerant is low. Check your fans. Clean your coils. Check your Capacitor
Posted on Jul 01, 2009
I have a Haier Wall Air Conditioner. It's on cool
Filter may be clogged. I have one and it has a filter which I clean regularly.
Sep 11, 2012 | Heating & Cooling
Cold and hot stiky air
try cleaning the filter and fan blades.
Jan 01, 2012 | Heating & Cooling
My 1999 Chevy Malibu runs hot? It started when it overheated. We changed the thermostat, then water pump, then temp sensor gauge and the temp gauge goes high but only when the heater stops blowing hot...
Air pockets will make the guage do that, and also cause your heat to come and go. Also, a poor radiator, as in rotting, or plugged up, will cause high temperature issues.
Sep 20, 2011 | 1999 Chevrolet Malibu
Jusrt bought a mobil home with an Interherm unit. I live in Louisiana. When the air was hooked up is didn't cool very well. The fan motor outside had to be replaced. I was told it was the wrong...
There are a few things you can try.Close the vents half way in rooms your not using often too force more air to where you want it.
Inside coil and filter may be clogged or dirty.Change filter and clean coil with a degreaser spray,simple green works well mixed with water.
Thermostat location? is it in a common area like the living room.If not it should be there.
May 10, 2011 | Intertherm P3RA-024K Air Conditioner
No Cold Air
it sounds as though the compressor is stalled or seized. if its seized a new will be required! If its stalled it may be down to a failed capacitor, if you have a voltmeter test for voltage at the compressor.
When shutting off leave it off for a good 24 hrs
All the best
Jul 05, 2010 | Danby DAC5071M Thru-Wall/Window Air...
Everstar mpm08cr bb4 will cool briefly then briefly blow hot air
check your filter and replace,, and that dont do it,, you need to clean coils,, and if that dont work it may be low in gas,, hope this help you
Sep 01, 2009 | Danby DPAC8020 Air Conditioner
Honeywell T8112 Air Conditioner Will Not Cool, But Blower Works
make sure the system switch is in the cool position, then press run program button and allow a couple of minutes for system to cycle on, if it doesn't come on press the button for lowering the set point, set it to 72 degrees and then press the hold temperature key.
May 27, 2009 | Honeywell ER150B Air Conditioner
Intertherm not cooling correctly
Sound like air flow problem to me, the inside and the outside. check the inside filter to see if it's clean and clean the outside condenser coils by washing it.
Aug 23, 2008 | Intertherm P3RA-048K Air Conditioner
Nordyne electric heater
If you have 24 + volts between common and w or w2 when your thermostat is calling for heat, you might have a or a couple of defective heat relays or sequencers.
Nov 26, 2007 | Heating & Cooling
Heating & Cooling Logo
105 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
