Question about Maytag Dryers
Dryer does not start I already replaced the timer
  • Maytag Master
  • 2,005 Answers
First check the dryer push button on switch; next, meter the start relay and, the centrifugal switch on the front of the motor (this switches the start motor winding on; then off as the run winding takes over
Posted on Jul 01, 2009
Dryer does not stay running
Replace the timer...
Mar 08, 2014 | Dryers
Dryer timer not Advancing
does it get almost to off but doestn go off or does it not move at all?
Jul 14, 2013 | Dryers
LE6090XS Dryer timer open
Timer part # is 696434. But, as you already know, it is no longer available. You might try doing a ebay search for that timer.
Sep 01, 2017 | Dryers
Kenmore 500 washer wont spin or agitate
Have you checked on the belt or belts that drive the tubs action?
Jun 21, 2012 | Kenmore 500 6952 Dryer
Magic chef dryer wont start, doing nothing, bypassed all fuses that i know of and door switch, replaced timer, ck voltage both ends of cord, and both sides of timer, what am i missing?
Hi
Thanks for using FixYa. As you have already checked everything else then the issue seems to be with the Thermal fuse going bad needs to be replaced. It is mounted to the exhaust duct inside the back cover panel. Also, often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. You can check it for continuity with an ohm meter, no continuity means it is bad and you need to replace it. If you have also checked this fuse already then the issue is with the control going bad and should be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 13, 2010 | Magic Chef CYE4000AWW Electric Dryer
My dryer won't start. it will heat and timer
Check your motor to see if it is faulty.
Good Luck.
Rate me please
May 12, 2010 | Dryers
Kenmore gas dryer doesn't stay on
I think it is probally the thermocouple not holding letting gas valve work properly, timers do not go out very often, its not getting hot enough to release the gas, valve wont let it, chheck thermocouple, let me know im not there, but its in the heat not getting hot enough
Feb 25, 2010 | Kenmore Dryers
Dryer timer not working Model#76812690
Ok, the dryer timer is not working......Would you like us to stop by and replace it for you ? You already know the problem, so, there is nothing for us to do. Either replace it yourself, or call a preofeesional,.///[
Jan 31, 2010 | Kenmore 84052 Dryer
Hi I have a whirlpool gas dryer and it heats up when you 1st start it up but after a while it runs cool. Also the timer does not advance so it just runs aimlessly. I already cleaned the vent and lint chute...
The timer is the Principal initiator of the entire heating cycle. it authorizes the needed current for proper element functions. you have stated that the timer fails to advance, or rotate properly. this will cause inadequate heating, therefore, not allowing optimal dryer performance.
replacing the timer will fix this issue.
((I would also like to recommend replacing the running thermostat as well. this is good preventive maintenance. its located on the dryer blower housing or vent duct.))
Sep 02, 2009 | Dryers
Dryer won't start and smells like something is burning
I'm having the exact same problem verbatium! did you ever figure it out. I already replaced the motor and the belt, but it's still doing the same thing.
Feb 17, 2009 | Maytag PYE2300AY Electric Dryer
Dryers Logo
101 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
