Question about Panasonic CT-36HL43 36" TV
The tv has no power ...happened before 2 years ago. Atech came out and spent about 5 minutes behind the TV and it was fixed. I believe it was a fuse. Is this something I can fix myself??
  • 69 Answers
Yes , just find the blacken fuse
or if none appear to be black ,look
very closley at the fuses and you
should be able see the broken wire
inside the glass houseing pull it
take it to raido shack replace it done.
Hope they didnt charge too much.
Posted on Jul 01, 2009
Hi, my problem with our Samsung HLP5063 WX / XAA is that ever so often it decides to buzz. The buzzing sound is coming from the back of the tv and happens at different times. Sometimes the buzzing starts...
Bryce.
My experiance with what you are talking about is sounding like the color wheel going bad. Same thing happened to mine and it was the color wheel. Right around 120.00 and is a easy do-it-yourself job.
Feb 06, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
I purchased my tv 2 years ago. Watched it
Try leaving the TV unplugged for 30 minutes so theTV can reset itself.
If that doesn't work, most likely the TV has a power supply board is the problem. Or, it's just a fuse that blown inside the TV.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20. And most cases the new part cost less than $15.
I hope I shed some light on the subject for you.
Jul 05, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Buzzing TV- Polaroid 37" FLM-3732
i fixed one by put 2 new caps in c112 and c113 1000uf 10v
Jun 13, 2009 | Polaroid FLM-3732 Television
Vizio 50'' Plasma AV1 & 2 Ports Unresponsive
Put off the TV Using the remote .Then unplug the TV 's power line from power source.Allow this for Just Over one minute .Then plug back the powerline and your TV should be okay.
i had the same problem with wii and this fixed it .
Nov 26, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio, Model P4, manufactured in 2003 -- worked fine until 5 minutes ago
I have the same tv and the same problem. The power switch in the front flashes a bunch of times, but nothing else happens. Have you had any success in getting yours fixed?
Sep 08, 2008 | V, Inc. Vizio P4 Plasma Television
Sony Wega kdf-55wf655 rear projection set keeps turning on and off
If picture quality is poor, be sure you aligned the bulb in the correct manner and be sure the cover for the bulb is not loose. Also, you might want to re check you picture setting as it might have gotten reset when you pulled the plug (I hope you pulled the plug when replacing the bulb).
Heres another solution (maybe temporary) to the problem of no picture and no sound for 30 seconds. I had my tv's power saving setting on "standard" before. After I switched it to "reduced", the problem was fixed. It has been almost two weeks without the problem. I think its a good fix until the new bulb comes in the mail.
Jan 18, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Mitsubishi WS-55859
Check any/all fuse devices in power supply.Let me know.....T.
By the way,the tv serial # is 107543. I assume the model # is
as stated==WS-55859.
Oct 21, 2007 | Mitsubishi WS-55859 55" Rear Projection...
The screen went black
I tried to see where you come from but it was unspecified. If you are in the States you might be lucky....go here and have a look they might be able to fix your screen up.. http://lcdrepair.net
Sep 11, 2007 | Sony FWD50PX2/S 50 in. Plasma Television
Fuse blown
the fuse will always blow if there is a shorted component. the horizontal output transistor may be the most likely culprit, if you are not a technician, have it service by a qualified one.
May 15, 2007 | Samsung TXR3079 TV
Panasonic CT-36HL43 36" TV Logo
232 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
