Question about Emerson EWL2005 20 in. LCD Television
We have an Emerson 20inch tv that suddenly lost it's color.
This morning when my husband went to work the bedroom TV was in color but when I turned it on this morning it was in black and white and has been ever since. We have it hooked up to DirectTV, as well as the living room tv, but the living room tv is fine. Not sure if it has to do with the satellite box or the TV. When we searched the menu on the TV the menu options show up in color and if you change the channel on the tv, not the satellite, the channel number shows up in color. Any suggestions?
    Top Expert:
  • Emerson Master
  • 75,767 Answers
Do a reset to this TV and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Posted on May 26, 2017
  • 374 Answers
SOURCE: Lost satellite signal after hooking up an hdtv
Provided you did not make any changes to the cabling through out the house there is no reason that you would have lost satellite signal except if something is in front of the dish, some one moved the dish e.g. child bumping into it if it is on a pole, or there is a major storm in your area e.g. blizzard, hurricane etc. You also may have snow build up that may have caused this issue or a form of wildlife that has decided to use the dish as a perch and is blocking the LNB's. The most likely result would be trying to split a signal that is coming from the dish going to another satellite receiver or the multi-switch. There are a few ways to get a signal to that TV.
1. RESTORE THE SYSTEM TO ITS ORIGINAL CONFIGURATION.
2. Either come off the multi-switch in the attic or outside the home and run new lines to the new receiver if you have one for this TV.
3. You can run new lines from the dish to the new TV if your system has an available port(s).
4. This is the least preferred by most homeowners as it will result in two tvs viewing the same programming- You can put a splitter into the line going from a receiver to the tv and run one of the out ports to the new tv and the other back to the original tv.
I hope this assists you and thanks for using Fix Ya. If I can be of further assistance please let me know.
Jim
Posted on Nov 10, 2008
SOURCE: Emerson LD195EMX - just bought from Walmart,
Hey, most stations are not broadcasting analog anymore. That is why you are only getting 10 channels.
Posted on Dec 08, 2009
budmrtn
  • 11361 Answers
SOURCE: I have a friend whose Emerson Flat Panel LCD
How do hook it up? Are you using composite video (Yellow video cable) from DVD Yellow RCA video out to the TV AV1 composite video Yellow RCA jack and RED and WHITE cables for sound. Or you are using component video hook up using RED, BLUE, and GREEN Video cables and the RED and WHITE cables for sound. Please post back and tell us how you have it set up. You just have to match the color of jacks and plugs, unless there is problem in the TV.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Posted on Jul 02, 2010
MattCasdorph
  • 44 Answers
SOURCE: I have a new Emerson LC320EMX 32
Similar to mine, only my tv you can change channels. We either need someones help or atleast a service manual (not user manual)
Posted on Jul 14, 2010
maatmartin7
  • 1229 Answers
Your TV is still in the factory test mode. To remove from the tech service mode try this.To exit the service mode, grab the original remote. Press the cursor left followed by the cursor right button. Now press the off button on the remote or on the TV itself. Hope this helps. Thanks for asking and show a few hands of support!
Posted on Nov 11, 2010
Sudden loss of color
If you are sure your cables are tight and not defective, then your main board is defective or your signal source is defective.
Mar 15, 2013 | Emerson LC195EM9 19 in. LCD TV
Digital Lifestyles 42" LCD HDTV
How many hours has the tv been used ... approx... as this will reveal further solutions..
Jun 09, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
TV is suddeningly turning volume up and down
That could be one of two things first being the front keyboard and possibly a main board. However the keyboard is usually the cause of those two issues. You can get replacement boards with free tech support for diagnosis to determine which board you actually need at www.tvrepairworld.com just hit the contact us button and enter the model number and symptom
Aug 05, 2012 | Emerson LD195EM8 19 in. LCD TV
I have a JVC model HD-52G886 tv. that loses sound.
Replace or have replaced the Audio board in the set----a lot of them fail.
Mar 12, 2012 | JVC HD-52G786 52" Rear Projection HDTV
I have a new Emerson LC320EMX 32" TV. The suddenly stopped working right. It will not turn off. There is no picture, only colored screens. When you change the channel it just shows a different color...
Nov 11, 2010 | Emerson LC320EM8 32 in. LCD TV
Different color vertical lines on screen Sony KDF-E55A20
Go to the last page of troubleshooting in the manual and perform the system reset procedure. Basically hold the Wega "arrow up" as you manually switch the TV off. It will automatically switch back on and reset. I had only vertical colored lines on the screen, with audio but no response to any remote control functions. The rest worked perfectly.
Aug 06, 2009 | Sony KDF-E55A20 55 in. LCD Television
Sony KV-36FV27 too dark, pink or green tint, 5 blink error,
Fuzzy,blury picture in CRT tv tube.Tv in long use not repairable.Tv tube is dying,it junk.
Mar 27, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Color messed up on tv since lightning strike
your tv may have ben magnetized by the lightning strike.
tv's have an automatic degaussing circuit that demagnetizes
the pix tube when the set is turned on. this degaussing circuit
may not be working or magnetism may have been too strong for
the internal degaussing to correct.
contact local tv repair shop in your area see if they can manually
degauss your set , it should be a min. service charge around $25.
roland
Mar 22, 2008 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Emerson EWL2005 20 in. LCD Television Logo
96 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
