Question about Whirlpool ET8WTKXK Top Freezer Refrigerator
About every 2 months the defrost drain gets plugged
Whirlpool - refrigerator
M/N ET18PKXGW01
S/N EJ2725708
The refrigerator was new in 1999.
About every 2 months the defrost drain gets plugged with ice. The collector pan inside the freezer fills and freezes into a sheet of ice. Then the entire frig begins leaking water onto the floor.
Is there a way to keep this drain from freezing shut?
Is there some kind of defrost feature that is not working?
Scott
  • 4,070 Answers
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Take a bare copper wire and wrap it around a fin near the heater and put the other end a few inches down the drain. The heat convection may prevent it from freezing.
Posted on Jul 01, 2009
Freezer seems to work ok. The refrigerator gets warm and we loose all the food. Is this a thermostate issue?
Mountain Meadows
Posted on Jul 19, 2010
I have Whirlpool refrigerator without ice maker, It leaks water down inside of the crisper drawers . What can be wrong with it
The most common problem is the defrost drain hole is plugged or frozen over.And the defrosted water from the evap coil is leaking in the fridge compartment,You may have to remove the back panel in the freezer compartment and defrost the evap coil and drain area.
Jan 07, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
The defrost drain tube freezes and i have to thaw it out at least once a month
Here is what is really happening and it is 100% repairable...
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 10, 2010 | Whirlpool Refrigerators
My refrigerator is drain tube IS PLUGGED
The drain is normally not accesible for customers. Contact an appliance service company to clear the drain.
Feb 10, 2010 | Whirlpool Refrigerators
Same problem with defrost drain
The drain is plugged. Try running coathanger up drain. Make sure the hole on bottom of drain is open wide. Some have rubber nozzles on them and you can cut the hole bigger.
Aug 27, 2009 | Whirlpool GD2SHGX Refrigerator
I have water dripping into my refrigerator.
the ray below yur freezer gets full cuz of ice dropping down.. 4this yu will have 2 clean the tray wen yu autofrost.please make sure that it doesnt overflow...and even the drain box at the bottom ... empty it by using a sponge once a month.
Jul 08, 2009 | Whirlpool GS6NBEXR Side by Side...
TOP-MOUNT REFRIG, FREEZER ICES UP AND HAS TO BE MANUALLY DEFROSTE
I recommend you call me and i can really help you over the phone to get a good understanding Whirlpool Parts
Apr 26, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer drain plug
Self defrosting refrigerators as well as freezers all have a defrost drain system. This drain system can become plugged or frozen causing defrost drain water to back up into the refrigerator or freezer compartment. The water may gather under the crisper drawers on top freezer models. On side by side, bottom or stand alone freezers ice will build up in the freezer at the bottom and eventually leak out the door.
Plugged Defrost Drain - Freezer on Top (Water under the crisper drawers)
At the top of the refrigerator next to the temperature controls there usually is a cup-like part that carries the defrost drain water into a tube and out the back of the refrigerator to a defrost drain pan behind the unit. Pull the cup out of the tube and clean the cup with hot water and soap. If there is no cup, pull the refrigerator out away from the wall, go behind it and disconnect the drain tube to clear it. If the drain tube is not accessible from the back or the drain can not be cleared from there the main back panel in the freezer can be removed to access, thaw and flush out the drain under the cooling coil.
Use a turkey baster to flush HOT water into the tube to clear any obstruction. The water squirted into the tube should end up in the defrost drain pan.
If the tube will not clear with hot water try blowing it out with compressed air.
Put the cup back on and make sure it is all the way on or in the tube.
Plugged Defrost Drain - Side By Side, Bottom-Freezer Refrigerator or Stand Alone Freezer
The defrost drain pan is located at the bottom of the freezer compartment behind the back wall of the freezer. On some models, the pan is accessible without removing the back panel and others are not. After you get to the defrost drain pan use a hair dryer to melt the ice from the pan.
Once the ice is removed use a turkey baster to squirt HOT water into the drain hole to clear the drain.
When the drain is clear you should hear or see the water you are squirting into the hole enter the pan under or behind the refrigerator.
TheRepairGuru ---- www.repairclinic.com
http://www.repairclinic.com/Whirlpool-Refrigerator-Parts
Jan 26, 2009 | Whirlpool ET9FTKXK Top Freezer...
Leak water on floor once a month
This likely a defrost cycle issue. Your drain tube is likely clogged. Get under there and clean it, clean your condenser while you're at it. Cut down door openings, open liquid in the fridge.
Jan 03, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool ET8WTKXK Top Freezer Refrigerator Logo
772 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
