Question about Toshiba Satelite A10 Notebook
Toshiba a10 does not give me the option to put lan
I have been into the bios and set the cd-rom as first but it still goes to a PXE-E61 error. there is no way to set the lan to last with the cr-rom first, what can I do?, ideas please..thanks
  • Toshiba Master
  • 32,281 Answers
Are you trying to install Windows or reinstall Windows?
The PXE-E61 POST error means the BIOS cannot detect the hard disk, either a faulty hard disk or a faulty disk controller.
Check the BIOS and see if it has detected the hard disk, some BIOS also have a hard disk diags, if so run it to test the hard drive.
My guess is that you have a faulty hard disk.
Posted on Jul 01, 2009
I have a emachines w3615 and it wont boot error message is pxe e61
I disable the lan boot w/no pxe support in the bios and put in a new hard drive 30 gig and it is great now.
I believe the hard drive went bad and it then tried to load an os from a previous network, which caused the PXE error. The true culprit was the bad hard drive.
Jan 31, 2011 | E-Machines emachines (emachinees) CD-ROM...
Boot error PXE-E61: media test failure, check cable followed by, PXE-M0F: existing Broadcom PXE ROM followed by, Operating System not found
Hard drive has been coruppted. Hold alt f10 on statup to format and reinstall. If that dont work you may need to try install from cd's provided when you purchased laptop. If that dont work buy new hard drive and restore from cd's. Good Luck.
Nov 23, 2009 | Acer TravelMate 800LCi Notebook
Acer Aspire 5100-5674 won't boot. Keyboard won't work, mouse initializes. PXE-E61 : Media Test Failure then PXE-M0F : Exiting PXE ROM I really need some help, I just bought it. And would really like to...
PXE errors are generated by the network boot ROM. In other words, the boot process is attempting a network boot (your BIOS' 4th boot option), which means that your system was unable to boot from a HDD, CD-ROM, or USB device (the first 3 boot options).
PXE-E61 Media Test Failure, System won't boot:
1.Go to Bios Settings
2.Remove LAN booting from booting options...For laptop ,type "X" on the LAN booting option.
3.Save The configuration
Also verify if your harddisk is detected by BIOS
Jul 30, 2009 | Acer Aspire 5100 Notebook
Upon booting I get this error. for realtek
PXE means Pre-Boot Execution Environment. You see this message when the laptop trying to boot from a remote server using the network card. If you didn’t see the PXE-E61 message before, it means that the network card was listed after the hard drive in the boot order (you can set the order in BIOS) and the laptop booted directly from the hard drive. Now, when the hard drive has failed, the laptop cannot detect it and tries to boot from the next available device – the network card. Your laptop is not configured to boot from a remote server using the network card, that’s why you are getting PXE-E61 Media test failure error.
You have to replace the hard drive and reinstall the operating system?
Jul 09, 2009 | Toshiba Satellite P205-S747 PC Notebook
PXE-E61: media test failure check cable
"PXE-E61 Media Test Failure, System won't boot"
3.Save The configuration(F10)
This Will Solve this problem
May 25, 2009 | Compaq Presario-Notebook 700 Series, 2500...
PXE-E61
  1. Go to Bios Settings
  2. Remove LAN booting from booting options...For laptop ,type "X" on the LAN booting option.
  3. Save The configuration(F10)
May 25, 2009 | Computers & Internet
Boot up problem
this is a easy fix all you need is a windows xp installation disk.what you do is put the disk in and boot off of the cd option.if you need help with the xp cd installation i can write up a guide for you.also is the first harddrive new or came with the comp.if it is a new harddrive it might not have a operating system on it.email me if you have anymore qeustions or you want the guide.i can even make a video for you but it probably won't be good quality.
Apr 23, 2009 | Toshiba Portege 3500 Tablet PC
Receiving PXE-E61 media test failure/PXE-M0F exiting intel PXE RO
If you get this error in a black screen before windows xp can boot up....
CLIENT MAC ADDR: xxxxxxx GUID: xxxxxxxxxx
PXE-E53: no boot filename recived
PXE-MOF: exiting intel PXE Rom
Your network card's settings in bios have somehow been changed. PXE means Pre-Execution Enviroment. In other words, it allows your network card to connect to a network server to pull operating system images off the network and other files without having an operating system installed.
The Fix,
Go into BIOS press F2 or F12 whatever your PC's screen at bootup says. In Bios, reset your bios settings to the default bios settings, or original settings. This fixed my problem with the above error. Nothing else fixed it. Windows Recovery cd will not fix it, because you cannot boot windows if this error is still occuring, Your network card will keep prompting DHCP to search for a network.
Its a bios function not a windows function.
Jan 21, 2009 | Toshiba Satellite A135-S2276 Notebook
My Toshiba Satellite A135 is having a bad problem. it will not boot up. It says Media test failure check cable.. Does this mean my hard drive went out?
This message is primarily seen when the PC is attempting to boot from a network, and that network connection is no longer present. The error message would read PXE-E61: Media test failure / Check computer. Is this your message?
If it is, you need to go into the BIOS, and make sure that the sequence is 1) CD-ROM 2) HDD 3) FDD (if you have a floppy) 4) LAN (if you choose to leave the LAN there). Otherwise, switch option 1 and option 2. If the problem is the hard drive, however, putting the CD-ROM first will allow you to boot from your Windows CD.
Please post back if you need further help, otherwise thank you for using and rating FixYa!
Jun 29, 2008 | Toshiba Computers & Internet
HP dv8000 crashed last year
It's trying to boot from the LAN. Don't ask me why but it's got it into it's little brain that it needs to boot from the LAN before anything else. When it can't get a valid operating system image over the network, it gives up and reboots with that error message.
Happily the solution is pretty simple. Go into the bios by tapping F10 when you first turn the power on. From there go to the System Configuration, and into the Boot Options. If you still don't have a viable operating system, it's necessary to set the CD Rom as the first boot device, so it will read a Windows disk. Makes sure CD-ROM Boot is set to Enabled and Network Adapter Boot is set to DISABLED. Then set the boot devices in the following order:
ATAPI CD/DVD Rom Drive
Notebook Hard Drive
- all the other options can be in any order, just make sure these two are at the top.
Pop in a Windows disk or your system restore disk and it should go through fine.
May 25, 2008 | HP Pavilion dv8000t Notebook
Toshiba Satelite A10 Notebook Logo
91 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
