Question about Casio EXILIM ZOOM EX-Z60 Digital Camera
How do I remove a stuck battery in my Casio exilium z 60 camera
Battery stuck in battery compartment
SOURCE:
  • 3 Answers
SOURCE: Won't reset to zero (60 sec.) after battery was replaced
You need to "Reset" the watch's computer, this is done by removing the case cap, (Same as battery replacement) Look for a imbosed "RESET" and using a paperclip, Push gently in the reset hole for five seconds, Remove the paperclip, You should then have all funtions restored to "Factory Settings"
Posted on May 20, 2009
upajos
  • 24 Answers
SOURCE: For Casio F-91W how do I replace battery? I see 4
Most of these resin-case F-series Casio sport watches use a fairly large lithium coin cell battery. Once the four screws holding the watch back are removed, you should be able to just pop off the stainless steel spring clip that holds the cell in place and pull it out, without having to remove any more screws. Be careful when replacing the clip, because it is asymmetrical and goes in only one way. Also be careful not to lose the tiny spring contact that connects the watch movement to the piezoelectric sound element glued to the watch back. If you lose the spring, the watch will still run, but the alarm won't sound anymore.
Posted on Sep 01, 2009
BillB-SA
  • 2761 Answers
SOURCE: also a battery proble?
There may be something more serious wrong with the camera, but the problem you describe is frequently due to corrosion on the battery contacts inside the camera. Remove the batteries and wipe the camera contacts firmly with a clean dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during the cleaning, wipe both ends of the batteries with the cloth, and reinsert them into the camera. This clears the problem about 90% of the time - I hope it works for you.
Posted on Sep 09, 2009
escapement
  • 2338 Answers
SOURCE: I have a Casio AQ-47 watch. I removed the battery
This little spring is called coil spring and must be inserted in to the hole in movement. Usually there should be writing on movement with an arrow pointing to that hole. If you can not find the writing, then try to put coil spring in different holes one after another, till you hear the watch beeping again.
Rate me, plz.
Posted on Jan 11, 2010
SOURCE: Casio module 2273 battery change
did u ever figure out how to get the retaining clip?
Posted on Mar 13, 2010
I own a Casio Exilim and every time I turn it on it says lens error and the lens constantly get stuck. Please help with this problem.
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks
Jan 17, 2011 | Casio EXILIM Card EX-S770 Digital Camera
I have a Cannon EOS 30D. There is no response whatsoever when the power switch is turned on. I have tried 2 separate fully charged batteries with no change in the problem. Can you help me? ...
There is a small Lithium coin battery on the side of the battery compartment that is the memory battery for the camera functions. Remove the battery pack first, then holding the camera with the lens facing your body look at the top back ledge of the battery compartment and see lettering CR2016. slide your finger down the back ledge and feel the ridges. with slight pressure slide the compartment up and take out the CR lithium coin battery. replace with a like new battery. If you ever need to reset a stuck program in the camera, remove this battery for a few minutes and the camera will re-boot to factory settings. This battery last for about 5 years.
Sep 19, 2010 | Canon EOS 30D Body Only Digital Camera
My batterie died on my casio 10.1 mp exilm camera , when i charged it back up and turned my camera on the 3x optical lens is stuck and will not retract can you help please .. thanks nathan
If the camera has recently been dropped you may have lens damage that's preventing it from powering up. If it hasn't been dropped your problem may be due to corrosion on the battery contacts inside the camera - which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then clean both ends of the batteries, place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Jan 04, 2010 | Casio Exilim EXS10BK Digital Camera
The lens on my casio exilim ex-z20 is stuck.
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your camera may have a problem that requires professional repair.
Oct 14, 2009 | Casio Exilim EX- Z200 Digital Camera
I charged my battery and my camera won't turn on. It is a casio elixim. What is wrong?? It is only 2 years old.
Your problem may be due to worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries need to be replaced because they're just too worn to properly power the camera. And then, of course, there's the possibility that your camera may have a problem that requires professional repair.
Sep 26, 2009 | Casio Cameras
Also a battery proble?
Sep 09, 2009 | Casio Exilim EX-Z57 Digital Camera
Power button will not work - it did not pop up when depressed. I removed battery and card and re-inserted but button is still stuck. Any suggestions?
Found out that if battery needs charging, camera will not turn on at all. I guess I had a senior moment. Button was not stuck just no power to turn on camera. After charging battery everything is fine.
Feb 28, 2009 | Casio Exilim EX-Z750 Digital Camera
The light on the battery charger of my casio ex-z77 light is flashing. The battery is not charging and I have checked the connection of cables and have switched outlets
from another thread, posted by theslug. This worked great for my camera.
"Hi,I just found a soultion on another website and it appears to have worked for me.Apparently the battery loses it memory when fully discharged,to fix this take a 9v battery and place the terminals + to + and - to - with the camera battery for 30 seconds or so then put the battery back in the camera and charge as normal.I just did this and it seems to be charging and the red light is solid.hope this helps."
Apr 25, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Parshiv Luthra
Steven Wander
Steven Wander
Are you a Casio Camera Expert? Answer questions, earn points and help others
