Question about Kenmore Washing Machines
Tub will not go into spin cycle. it is a kenmore model #110.18522790 serial ch0809062 transmisson will not kick it in
  • Kenmore Master
  • 8,220 Answers
That would be the lid switch. GUIDE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 01, 2009
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
Kenmore 22622 washer tub will not spin during spin cycle, burnt smell
Sounds like the belt between the motor and the tub is slipping or the tensioner spring may have failed.
Dec 14, 2013 | Kenmore 22422 Top Load Washer
Kenmore model 23832100 washer will not spin in rinse cycle kenmore model 23832100 washer fills, agitates, and drains, but will not spin. Makes noise after draining. BUT if I manually turn off the machine...
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Mar 30, 2013 | Washing Machines
Just purchased used a Kenmore stacked washer/dryer: tub spins during aggitation cycle. So my clothes are spinning around in water but not being aggitated. Now Im aggitated!! Grr!! How much will it cost...
Sounds like the plastic spacer between the transmission and the tub has broke. Part is no more than 5-10 bucks. Labor, not sure. Did you buy the warranty....I think you still have time to buy it if it's new... But I think Kenmore may guarantee for 30 days but you may want to call where you bought it from new.
Dec 14, 2017 | Kenmore Washing Machines
Spin cycle doen't work on control-water accumulates in tub-its a kenmore
I'm guessing that the mechanism for putting the tub in the spin cycle is worn out. These can be either electro-mechanical switches for older models, or electronic switches for newer models. At any rate if your tub is not spinning, you will have to have someone come out to look at the problem. BTW, I have a Sears washer and dryer, and had to have the dryer serviced once. They were very good and did not rip me off.
May 16, 2010 | Kenmore Washer Timer Control Knob 3362624...
My Kenmore Series will Agitate, then there is
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump
removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
This sounds like a pump problem.
There are gears in the transmission that keep it from spinning for a while until the pump has drained most of the water out. It sounds as if the gears and transmission are doing the job but the pump isn't.
See the following for how to remove the cabinet to gain access to and check the shaft from the motor to the pump and the pump itself. One or both of the hoses may be blocked or the pump itself may be shot.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=134
Apr 09, 2010 | Kenmore Washing Machines
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series washer wont spin or drain at end of cycle
POST ME THE MODEL NUMBER. AND ALWAYS POST MODEL NUMBERS WHEN NEEDING ASSISTANCE PLEASE:)))
Apr 17, 2009 | Washing Machines
Washing Machines Logo
43 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
