Question about Sony FD Trinitron WEGA KV-27HS420 27" TV
Pin cushion problem for KV-DZ29M61
Picture caved in on both side, fuse R6845 fused
  • 69 Answers
Caps in the vertical are weak
Fair cost for a shop 145.00 no more.
Posted on Jul 01, 2009
How can I fix picture reduced bowing on rt and left sides in CRT TV Model LG 29FD7 RGE-TR
Pin cushion distortion problem. This not a user repairable fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Mar 28, 2015 | LG Televison & Video
Picture is too large to show on screen
Check its "Pin-cushion" section circuit for the fault. An IC is used there to control the pin cushion distortion. If this IC has got faulty, this type of fault can occur. This is actually a skilled work. If you are not ahndy, seek any technicians' support.
Jun 18, 2012 | Sony KV-36XBR400 36" TV
SONY KV SW 212 M80 Screen sowing pin cushion distortion. Screen is squeezed on the side and the side is curved inward.
Hello
Its pin cushion distortion circut had some trouble with it. There is an Ic and one transistor wich controls the pincushion effect. In most cased the trasistor that fitted on a heat sink, will have loose soldering at its terminals. this transistor will heat up during working, and repeated heating an cooling will make solder terminal loose contacted and it is normal fault. locate this transistor, very near to the LOT, resolder its solder terminals by applying a little more solder. It is best to resolder most of the surrounding solder terminals of high watt resistors, without making any solder bridge in between the solder points. If these does not helps you, replace both the IC [an eight solder terminal one, small IC] and the pin out transsistor described earlier at the same time. this will solve your TVs problem. OK.
May 22, 2011 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Vertical pinch on left hand side of crt
You mean the picture on the left side is curved out? Or is it restricted to the very top and very bottom?
If you have the curve problem, look in the menu and see if there is a pincushion control and a pin cushion balance. Adjust the balance until both sides curve the same, then adjust the pin cushion control to remove the curve.
If you are only having the problem in the corners, look in the menu for a corner correction control and play around with it to see if it corrects your problem. If the monitor has no OSD (on-screen-display), then it may be too old to have these controls. You may have to open the unit and see if there are any physical adjustments (little potientiometers). You might want to leave this to someone who knows what they are doing since the high voltage circuit can have 25-35 kV. Considering the price of CRT monitors, you might be able to find a new one for under $50.
Jan 22, 2009 | NEC MultiSync XV17 17" CRT Monitor
SONY KV-DZ29M61 horizontal deflection problem
Use Sony Parts only all others will not work or hold up.
Dec 01, 2008 | Sony Televison & Video
You cannot use sub parts on sony use sony parts only. Same with hori output transistors. USE SONY PARTS ONLY.
Dec 01, 2008 | Sony FD Trinitron WEGA KV-30XBR910 30" TV
Sony Picture Squeezes In On The Sides
Your TV has dry solder joints in "Pin Cushion" area, Its part of Horizontal deflection stage in TV and it requires resold work.
A tech person will understand above technical advise easily.
Need further info, let me know please.
Sep 30, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony FD Trinitron WEGA KV-27HS420 27" TV Logo
254 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
