Question about Lasonic PDL-305 Portable DVD Player
Dvd player turns disk slowly and gives wrong disk message..won't play
Are there any scratches on the cd? If there aren't. then you might want to bring in your dvd player to the service that you recieved it from and get it fixed.
Posted on Jul 01, 2009
Why is my dvd player always saying wrong disc
When it says wrong disk there must be a reason why. To test the system, you should put in a bought DVD, not one you burned yourself on the computer. If that DVD does not give a message, you know the player is 100%.
What could be wrong with self made disks?
First a normal DVD has a silver or gold layer to reflect the light coming from the laser. A disk you can burn yourself, has a dye, which changes colour when the laser burns its info. It ls less and less reflective, compared with the silver or gold plated ones.
Then when you have burned the DVD's from your computer, with a video format, other then the DVD format, most DVD players can't play that. There is only one DVD format and there are hundreds or different (not with DVD compatible) video formats, you can play on computer and MP4 players.
I hope this is enough info for now.
Apr 19, 2015 | Spectroniq PDV-70X
Get message This disk can not be played. Please check the tv system from bdp1500 blue ray player. Disk plays well on another dvd player. What's wrong
Happening to me as well.. I have burned dvd-r that I made myself.. and it will not play.. I have all kinds of different dvd-r's and none of them worked.. ran the latest firmware.. nothing!
May 20, 2010 | Samsung BD-P1500 Blu-Ray Player
Keep say wrong disk
First, are you trying to play a burned disk, like a CD-RW, or DVD-RW style disk? Sometimes certain DVD players will not play burned disks. Check your owner's manual. If you don't have one, go to the Memorex website and they may have s section where you can download a PDF version for free. Most sites do. Just type in your model number. Second, have you tried other disks, and are they ALL saying the same thing? If so, then it's possible that there is dust or dirt inside near the laser eye, and it's giving you the "wrong disk" message as an error. Try making sure that you have a clean disk, and pick the one in your collection that has the least amount of scratces/imperfections on the shiny side. If it still gives you that message, you can try either using one of those cans of compressed air to blow any dust or debris out of the DVD player and try it again. If that doesn't work, you could try a DVD Player cleaning kit, which you can get at Walmart, or Radio Shack, etc pretty cheap, then try it again. If it still doesn't work, there may be a problem with the unit itself, and you can consider making a claim on the Warranty if it's still covered, taking it in to an electronics repair shop, or just buying a new one. Hope this helps you out. Good luck!
Mar 10, 2010 | Memorex MVD2022 DVD Player
"wrong disk" message appears after load time
If this happens on more than one DVD, it might be necessary to clean the lens of the DVD player. Safe commercial products are available at local drug stores for around ten dollars.
The "wrong disk" message is usually associated with Data disks, i.e. those having computer files rather than DVD movie files.
If this is an older DVD player, the DVD may have been written on a high-speed DVD writer which creates smaller data spots which may not be read correctly on older DVD players.
Barring these problems, it is probably just broken. DVD players, although not having as many moving parts as VCRs, do not last indefinitely.
Oct 06, 2009 | Televison & Video
Region problem
HELLO!
TRY THIS!
Turn on the player
Make sure disc tray is Open.
Press 9 9 9 9 on the remote, do it slowly.
Press what region you then require.
Press 0 (zero) for multi-region/region free playback.
When you are trying to play back a disc other than the region the machine is set up for, you will get a Wrong Region message.
ENJOY! (:-)
Oct 04, 2009 | Philips DVD625 DVD Player
The DVD recorder quit finalizing the disks
try cleaning the lens, if your cd's are ok.
May 27, 2009 | RCA DRC8300N DVD Recorder/VCR
Wrong disk
I looked at everybody's ideas, and none of the ideas seemed to fit my situation. My DVD player has been working fine for one month. I got a new DVD today in the mail. It froze, and then began to display the WRONG DISK message. Then, nothing would play on the player, All of the DVDs that had worked fine before, now would not play. They all said WRONG DISK. I tried reaching under and trying to clean the laser lens, but that did not fix the problem. I am not saying that this will fix your problem, but this is what fixed mine.
1. Place the DVD player on a table
2. Plug in the DVD player.
3.Push the OPEN button so that the DVD platter extends outside of the player (It now looks like it does when it is ready for you to put a DVD in it to play it.)
4. Unplug the DVD player. (Now the power is off, and the platter is still extended.
5. Remove the cover of the DVD player being careful not to damage the extended platter.
NOTE: With the platter extended, looking slightly from the rear, under where the DVD is spun, you will be able to see the Laser lens. It will be covered by the mechanism that spins the DVD. The lens will be connected to a mechanism that that has two rails on either side.
6. Grasp the plastic surrounding of the laser lens area and pull the entire mechanism toward the rear of the DVD player.
CAREFUL: DO NOT YANK THE MECHANISM BACKWARDS as this will break off the laser unit. This mechanism is being moved with the resistance of many gears. PULL SLOWLY AND FIRMLY, and the entire mechanism will move on the rails until the laser unit is clearly visible to you and completely from under the spinning mechanism.
7. Since the lens was clearly visible now, and easily accessable, I carefully and lightly cleaned the lens with a Qtip and alcohol.
8. Replace the cover on the DVD player
9. Place a DVD on the platter.
10. Plug in the DVD player
You will find that you no longer get the WRONG DISK message and your DVDs will now play properly. As I said, just reaching under and cleaning the laser lens did not seem to fix the problem. It was only when I moved the entire laser unit from under the spinning mechanism, and forced the DVD player to realign itself when it powered on, did the DVDs begin to play again.
May 23, 2009 | Sungale DVD-2026 DVD Player
The player gives a "cannot play" message for all types of media
Unit probably has a defective disk motor that is in border line failure. When problem again arises, have the motor replaced
Apr 16, 2008 | Sony DVP-NS575P DVD Player
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Lasonic PDL-305 Portable DVD Player Logo
75 people viewed this question
Top Lasonic Televison & Video Experts
JOHN TOPLISS
NOEL
NOEL
Joe Ball
Joe Ball
Are you a Lasonic Televison and Video Expert? Answer questions, earn points and help others
