Question about Canon EOS-1D Mark II Digital Camera
Canon err 01
I have a cnon 1d mk2 and 5 d both have registered a error err01
  • 121 Answers
This error means "Communication between the camera and lens is faulty. Clean the lens contacts." If you are using the same lens on both cameras, the problem is with the metal contacts on the rear of the lens where it communicates with the camera body. You can gently clean these contacts by using a clean pencil eraser. Make sure you hold the lens "bottom down" as you clean it so that the eraser debris falls to the table instead of inside the lens!
Posted on Dec 12, 2008
I keep getting error 99 message and tells me to turn camera off then back on.
No solution on youtube for you? or is that only the Err01 Err 99 for the 17-85 IS lens?
That happens when the zoon lens got stuck.
Nov 02, 2013 | Canon Rebel Cameras
Canon 50mm 1.8 error 01
Have a look here
Seems to be a connection problem Clean to connectors on both the lens and camera with a pencil eraser.
Aug 30, 2013 | Canon EF 50mm f/1.8 II Lens
My 60d finding ERR 01 with my tokina 12-24mm lenses. I try to clean the contact but after a few shoot the problem remain
I have the exact same problem, it's the aperture flex cable which have a design flaw. At 12mm the flex is stretched at maximum and over the years loses its flexibility and breaks. Mine works fine from 24 to 15mm. Below 15 the camera always reports err01. All flex cables in the tokina are welded -IMHO you need to take it to a professional.
Jun 20, 2011 | Tokina 12-24mm /f4.0 for Canon
I have Canon 17-85 lens but it is giving a problem err01 and i cant operate this lens fro mtwo day. I cleaned lens contact.
Based on my web search for this error code, Error 01 is related to the camera's ability to communicate with the lens, and seems to be most often because the IS has failed. If your lens is still in warranty, I suggest you contact Canon service for info on where to send/take it for repair. If it is out of warranty, you could still contact them for repair. Or, check with a local Canon authorized repair shop and see what they recommend (repair or replace?).
Sep 20, 2010 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
What does error 01 mean
Error 01: A communication problem between the lens and the body. Try cleaning the the area between the objective/Lens and the body. If that doesn't work, try another lens. If that doesn't work, try the first lense in another body, and if that works, it's most likely the body that's broken.
Jul 29, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Canon 400D I have an error code Err01 I have cleaned contacts between the camera and lens but still have the error code
I had the Error 01 message on my 400D
I changed the support battery ( CR 2016 3 V) which is placed inside the main battery compartment.
This did the trick.
Jan 18, 2010 | Canon EOS 40D Digital Camera
My Camera is Canon 40D with EFS 17-85mm lense. I am having 2 problems,1.when I zoom the lense at 85 at 'AF' it doesn't get the focus, some times it get focus but picture got blurred.2 after capturing some...
Your flex cable to the Iris is broken. Have a look at my gallery at I have the same symptoms. At 28 or 35mm it make work ok. try Av mode and f8 aperture to see if you get an err01 because the aperture does not move either.
Jan 02, 2010 | Canon EOS 40D Digital Camera
Error 99 on screen cant take picture intermitant
Error 99 is known as Abnormal Mirror operation. Follow the link for help;EOS-1D Mark III/EOS-1Ds Mark III: AF Accuracy Adjustment
EOS-1D Mark III/EOS-1Ds Mark III: Abnormal Mirror Operation (Err 99)
It should be noted that the AF accuracy adjustment advisory is in addition to the previous EOS-1D Mark III AF mirror adjustment service notice. Free repairs are being offered for customers affected by the "Err 99" mirror problem, and Canon is also providing free AF accuracy checks and adjustments for customers experiencing problems with soft focus when using any but the central AF point.
Finally, Canon Japan has published a new manual entitled "EOS-1D Mark III AI Servo Auto Focus Manual" aimed at helping owners understand and get the most from their AF system.
Jan 01, 2010 | Canon Cameras
Canon EOS-1D won't save pix to CF card. G.
The E99 message usually ends up being a shutter box that needs to be replaced. The 1D shutter box should be good for 100,000 images or more, you can probably find the estimated lifespan on Google somewhere.
If you can"t save pics to the CF card then you might have a bent or broken pin on your CF card reader. Look down into the CF slot, does it look ok?
We are an online digital camera repair shop but we haven't done any 1D cameras before.
Thomas D,
Owner; Darntoothysam com
Oct 02, 2009 | Canon EOS-1D Mark II Digital Camera
AF and shutter release failure
There was a lot of discussion of this when the Mk II was new. Many people "fixed" it doing just the things you did. Also, some reported that mounting the lens on another camera "fixed" it. IIRC, in the end it ended up being a lens issue. IS module. Canon can repair.
Mar 19, 2007 | Canon EOS-1D Mark II Digital Camera
Canon EOS-1D Mark II Digital Camera Logo
2,469 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
