Question about Dometic Rooftop RV Air Conditioner
Brand new Duo Therm won't stay running
I just installed a new 13500 BTU roof A/C on my pre-wired 5th wheel trailer. This is a second air conditioner. When I fired it up, it ran and blew cold air for about 2 minutes and shut down both fan and compressor. The fan will still run in manual. I have got it to run again 2 times with the same results. I took the cover off the unit and the compressor seems hot to me.
  • th155487 Jul 02, 2009
    It has local manual controls and is not hooked up to a remote thermostat.
    Novelist:
  • 127 Answers
You really need an Ammeter to check this problem. Just because it is a brand new unit does not mean that there isn't a problem with it. Is it run off of a wall thermostat or manual controls? The compressor has a thermal overload switch on the top (under the plastic cover) that will take the compressor out of the circuit if it gets too hot. However, if the entire unit is shutting off, there is another problem. Selector Switch? Thermostat? Let me know what kind of controls you have and we can go from there.
Posted on Jul 02, 2009
  • Jeff Myers Jul 02, 2009
    The Compressor should feel hot if working correctly. It should be uncomfortable for you to keep your hand on it. Turn the selector switch to high cool, with the compressor running, turn the thermostat to the warmest setting. Does the compressor kick off? Turn the thermostat back to the coldest setting and see if the compressor kicks on. If you are running the AC and the fan and the compressor kick off but a breaker does not trip. Then I would say you have a problem with your selector switch.
  • Jeff Myers Jul 03, 2009
    If you have local controls on the unit, then the only thing that is going to make both the fan and the compressor stop at the same time is a loss of power to both. This can only be done through the selector switch. The switch controls power to the thermostat and in turn, the thermostat to the compressor. The switch also sends power directly to the fan motor via the capacitor. Check to make sure that the power connections are tight. How did you get power to the unit? Was the coach prewired?
    Sounds like it is a bad selector switch or loose wire on the back of the selector switch.
    Hope this helps.
Need a shroud for cooler manufactured in 1989 on innsbruck 5th wheel trailer
air conditioner cooler? what brand? duo therm?
Dec 07, 2016 | RVs
Fan run compressor run but no cold air
DuoTherm by Domestic-Fan runs, no cold air - iRV2 Forums
www.irv2.com > ... > RV Systems & Appliances
Jan 22, 2012 - 12 posts - ‎4 authors Duo Therm by Dometic 13500 BTU air conditioning with ducting, furnace. I. ... If the fan runs but no cold air and the compressor feels like it is ...
A/C just stopped blowing cold.....any ideas??! - RV Forum
www.rvforum.net > ... > RVing message boards > Trailers & Fifthwheels
Jul 27, 2008 - 23 posts - ‎6 authors We have run it continuos like this before without any troubles. Thanks for the help! ....When you switch the AC unit on, the fan runs, but the compressor doesnt fire up. You used to be able ... You can find Dometic here. Logged. Dometic Duo Them Air Conditioner Cycles
Jul 21, 2015
Dometic SL-135 A/C problem
May 29, 2012
Dometic ac compressor runs but fan does not on auto
Jun 5, 2011
AC blower runs full time w/ AC on
Sep 2, 2009
More results from www.rvforum.net
Nov 18, 2015 | Dometic 705600009 A-284, SMX II Retrofit...
I have a Duo-Therm 57915 (13500 BTU) that frosts up the bottom 1/4 of the coil and shows signs of a freon leak on the copper tubing (oily substance). I assume I have a freon leak. It a 2006 unit. Is it...
Buy a new one. Your repair will cost approx 2/3rd (or more) the price of your new unit. Your old unit has no warranty left while your new unit will have a warranty. :-)
May 03, 2010 | Dometic Rooftop RV Air Conditioner
AC compressor won't start
hi,you might need a new compressor...you will need need to go back were you bought capacitor...buy a hard start capacitor too..this might crank the compressor...hope this helps.if you buy it..call an ill tell you how to wire it...if it dont ,you need new compressor...call michael..doctor airr..appl.repair...843-384-8474...
Mar 27, 2010 | Dometic Rooftop RV Air Conditioner
Duo Therm RV air conditioner inadequate cooling
The rule of thumb is 20F difference (lower) than ambient temperature. Most manufacturers will tell you 20 F degress is about normal. In your case it does sound a little warm, but I need to ask, sorry. Was it working o.k. before in same basic temperatures? Have you cleaned coils & fins good on Evaporator & condenser recently? Have you removed filter inside & cleaned it as well, and looked to see if coils are frosting up by chance? Is this a ducted or non ducted system? I'm guessing on a 5th wheel, it is ducted, so make sure you have good discharge on all of those as well. Any blockage or restriction on the discharge side will also cause the problem. Keep me posted on what you find.
Aug 31, 2009 | Dometic Rooftop RV Air Conditioner
Duo-therm 13500 roof a c compressor will not stop running when temp is met however fan does stop
Sounds like a bad thermostat switch, (stuck close--or in run position).
Sep 04, 2008 | Heating & Cooling
Dometic a/c, duotherm thermostat, turns right back on after it reaches desired temperture.
I have a dometic 13500 BTU Roof mount a/c. It is set up with the duo-therm analog thermostat. The system cools fine. The problem is that the a/c gets down to the right temp, then it turns off like it should but turns right back on within a few seconds. Any help would be greatly appreciated.
May 13, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
325 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
